@mika-nt28 : le démon ne fait que s’arreter et redémarrer,pas d’erreur dans les logs. si besoin je peux te faire un accès pour regarder
Ps: ah si, il y a un internal error au milieu du log.
[2019-12-01 08:48:28][DEBUG] : [FreeboxPassword]{"success":true,"result":{"logged_in":false,"challenge":"nDBDOgtDrHDA5hT6rIaFa20QyhbOVwQK","password_salt":"C\/BYEeD9L2r69361RE49a\/29ynmMpjmG","password_set":true}}
[2019-12-01 08:48:28][DEBUG] : [FreeboxOpenSession]{"result":{"session_token":"RAq+AOWC3sfEftriX4K+0ko9WsZSNzCuKAYNRLmf+sQ3MQoNLzWLfY3i1mOyNNCi","challenge":"nDBDOgtDrHDA5hT6rIaFa20QyhbOVwQK","password_salt":"C\/BYEeD9L2r69361RE49a\/29ynmMpjmG","permissions":{"parental":true,"explorer":true,"contacts":true,"tv":true,"downloader":true,"settings":true,"calls":true,"player":true,"pvr":true,"home":true,"camera":true},"password_set":true},"success":true}
[2019-12-01 08:48:28][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/storage/disk/0([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"idle_duration":0,"spinning":true,"table_type":"msdos","firmware":"SC16","type":"internal","idle":true,"connector":0,"id":0,"state":"enabled","time_before_spindown":600,"total_bytes":250050000000,"model":"ST9250311CS","active_duration":0,"temp":36,"serial":"6VCW9YR4","partitions":[{"fstype":"ext4","total_bytes":244950000000,"label":"Disque dur","id":2,"internal":true,"fsck_result":"no_run_yet","state":"mounted","disk_id":0,"free_bytes":50400000000,"used_bytes":182080000000,"path":"L0Rpc3F1ZSBkdXI="}]}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/storage/disk/1000([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"type":"usb","total_bytes":4000000000000,"connector":0,"id":1000,"active_duration":0,"partitions":[{"fstype":"ntfs","total_bytes":4000000000000,"label":"SAMSUNG","id":1001,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":1000,"free_bytes":1900000000,"used_bytes":3990000000000,"path":"L1NBTVNVTkc="}],"idle_duration":0,"state":"enabled","idle":false,"spinning":false,"model":"","table_type":"msdos","temp":0,"serial":"","firmware":""}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/ether-d0:e1:40:cc:ce:bf([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"l2ident":{"id":"D0:E1:40:CC:CE:BF","type":"mac_address"},"active":true,"id":"ether-d0:e1:40:cc:ce:bf","last_time_reachable":1575186506,"persistent":false,"names":[{"name":"iPad","source":"dhcp"},{"name":"iPad","source":"mdns"},{"name":"41DD0662-3B42-40D5-AE67-A598C3A18B98","source":"upnp"}],"vendor_name":"Apple","host_type":"tablet","primary_name":"iPad","l3connectivities":[{"addr":"fe80::6c:f990:df85:3043","active":false,"reachable":false,"last_activity":1570726115,"af":"ipv6","last_time_reachable":1570726078},{"addr":"fe80::815:ab6b:2de6:8d7b","active":false,"reachable":false,"last_activity":1570810159,"af":"ipv6","last_time_reachable":1570810024},{"addr":"fe80::8eb:b58b:a545:9cc0","active":false,"reachable":false,"last_activity":1572036926,"af":"ipv6","last_time_reachable":1572036926},{"addr":"fe80::1025:78a8:fb45:346d","active":false,"reachable":false,"last_activity":1574289918,"af":"ipv6","last_time_reachable":1574289862},{"addr":"fe80::14e8:1b18:157d:a828","active":false,"reachable":false,"last_activity":1574318990,"af":"ipv6","last_time_reachable":1574318984},{"addr":"fe80::ce1:be44:5852:49c3","active":false,"reachable":false,"last_activity":1575113349,"af":"ipv6","last_time_reachable":1575113349},{"addr":"192.168.0.164","active":true,"reachable":true,"last_activity":1575186506,"af":"ipv4","last_time_reachable":1575186506},{"addr":"fe80::1c5c:8688:1c08:4178","active":true,"reachable":true,"last_activity":1575186505,"af":"ipv6","last_time_reachable":1575186505}],"reachable":true,"last_activity":1575186506,"primary_name_manual":false,"interface":"pub"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/ether-60:33:4b:09:5a:82([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/system/([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"l2ident":{"id":"60:33:4B:09:5A:82","type":"mac_address"},"active":true,"id":"ether-60:33:4b:09:5a:82","last_time_reachable":1575186374,"persistent":false,"names":[{"name":"Mac-mini-de-Laurent-poumailloux","source":"mdns"},{"name":"MinideLmailloux","source":"dhcp"},{"name":"TVMOBiLi.localhost","source":"upnp"},{"name":"MACMINI-2179A0","source":"netbios"}],"vendor_name":"Apple","host_type":"workstation","primary_name":"MinideLmailloux","l3connectivities":[{"addr":"fe80::40d:4d48:2d89:6f8f","active":false,"reachable":false,"last_activity":1574291716,"af":"ipv6","last_time_reachable":1574291716},{"addr":"fe80::1c55:16c7:8e02:9d75","active":false,"reachable":false,"last_activity":1574378114,"af":"ipv6","last_time_reachable":1574378068},{"addr":"fe80::18a6:da9e:7a1a:12bb","active":false,"reachable":false,"last_activity":1574723710,"af":"ipv6","last_time_reachable":1574723660},{"addr":"fe80::27:a16:2350:ee11","active":false,"reachable":false,"last_activity":1574810114,"af":"ipv6","last_time_reachable":1574810110},{"addr":"fe80::18d4:96f0:d6ec:1437","active":false,"reachable":false,"last_activity":1574896512,"af":"ipv6","last_time_reachable":1574896512},{"addr":"fe80::1032:bb52:cc2c:128b","active":false,"reachable":false,"last_activity":1574982915,"af":"ipv6","last_time_reachable":1574982915},{"addr":"fe80::873:6add:525f:940","active":true,"reachable":true,"last_activity":1575186490,"af":"ipv6","last_time_reachable":1575186374},{"addr":"192.168.0.132","active":true,"reachable":true,"last_activity":1575186490,"af":"ipv4","last_time_reachable":1575185394}],"reachable":true,"last_activity":1575186490,"primary_name_manual":false,"interface":"pub"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/ether-b8:27:eb:1f:35:68([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"mac":"F4:CA:E5:48:23:B8","fan_rpm":1954,"box_flavor":"full","temp_cpub":63,"temp_cpum":55,"disk_status":"active","temp_hdd":36,"board_name":"fbxgw1r","temp_sw":46,"uptime":"16 jours 11 heures 54 minutes 29 secondes","uptime_val":1425269,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"639601E113317169","firmware_version":"4.0.6"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"l2ident":{"id":"B8:27:EB:1F:35:68","type":"mac_address"},"active":true,"id":"ether-b8:27:eb:1f:35:68","last_time_reachable":1575186500,"persistent":true,"names":[{"name":"raspberrypi","source":"dhcp"},{"name":"raspberrypi","source":"mdns"},{"name":"JBL-OnBeat-Air01993E","source":"upnp"}],"vendor_name":"Raspberry Pi Foundation","host_type":"other","primary_name":"lms_ethernet","l3connectivities":[{"addr":"192.168.0.31","active":true,"reachable":true,"last_activity":1575186500,"af":"ipv4","last_time_reachable":1575186500},{"addr":"fe80::31fe:13dc:e4ac:b7aa","active":false,"reachable":false,"last_activity":1573395505,"af":"ipv6","last_time_reachable":1573395500},{"addr":"192.168.0.35","active":false,"reachable":false,"last_activity":1559469486,"af":"ipv4","last_time_reachable":1559469473},{"addr":"192.168.0.36","active":false,"reachable":false,"last_activity":1560064887,"af":"ipv4","last_time_reachable":1560064800},{"addr":"fe80::ab06:5df3:2f25:703b","active":true,"reachable":true,"last_activity":1575186396,"af":"ipv6","last_time_reachable":1575186391}],"reachable":true,"last_activity":1575186500,"primary_name_manual":true,"interface":"pub"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/downloads/stats/([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/ether-2c:f4:32:68:c5:24([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/call/log/([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/connection/([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"l2ident":{"id":"2C:F4:32:68:C5:24","type":"mac_address"},"active":true,"id":"ether-2c:f4:32:68:c5:24","last_time_reachable":1575186494,"persistent":true,"names":[{"name":"shelly1-68C524","source":"dhcp"},{"name":"shelly1-68C524","source":"mdns"}],"vendor_name":"Espressif Inc.","host_type":"other","primary_name":"shelly boucle eau","l3connectivities":[{"addr":"192.168.0.99","active":true,"reachable":true,"last_activity":1575186494,"af":"ipv4","last_time_reachable":1575186494},{"addr":"192.168.0.107","active":false,"reachable":false,"last_activity":1568449995,"af":"ipv4","last_time_reachable":1568449982}],"reachable":true,"last_activity":1575186494,"primary_name_manual":true,"interface":"pub"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/lan/browser/pub/ether-b8:27:eb:8f:80:a2([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":[{"number":"0953219218","type":"accepted","id":209,"duration":39,"datetime":1575022894,"contact_id":0,"line_id":0,"name":"0953219218","new":true},{"number":"0970186049","type":"missed","id":208,"duration":28,"datetime":1574674180,"contact_id":0,"line_id":0,"name":"0970186049","new":true},{"number":"0367480231","type":"accepted","id":207,"duration":10,"datetime":1574435635,"contact_id":0,"line_id":0,"name":"0367480231","new":true},{"number":"0367480231","type":"missed","id":206,"duration":27,"datetime":1574435608,"contact_id":0,"line_id":0,"name":"0367480231","new":true},{"number":"0978080946","type":"missed","id":205,"duration":22,"datetime":1574413732,"contact_id":0,"line_id":0,"name":"0978080946","new":true},{"number":"0970185921","type":"accepted","id":204,"duration":39,"datetime":1574354878,"contact_id":0,"line_id":0,"name":"0970185921","new":true},{"number":"0176460274","type":"missed","id":203,"duration":24,"datetime":1574187258,"contact_id":0,"line_id":0,"name":"0176460274","new":true},{"number":"0970185921","type":"accepted","id":202,"duration":40,"datetime":1574163061,"contact_id":0,"line_id":0,"name":"0970185921","new":true},{"number":"+447050671651","type":"missed","id":201,"duration":22,"datetime":1574095856,"contact_id":0,"line_id":0,"name":"+447050671651","new":true},{"number":"0985702055","type":"missed","id":200,"duration":28,"datetime":1574092385,"contact_id":0,"line_id":0,"name":"0985702055","new":true},{"number":"0172634566","type":"accepted","id":199,"duration":39,"datetime":1574065641,"contact_id":0,"line_id":0,"name":"0172634566","new":true},{"number":"0985705746","type":"missed","id":198,"duration":27,"datetime":1573747569,"contact_id":0,"line_id":0,"name":"0985705746","new":true},{"number":"0977291066","type":"missed","id":197,"duration":18,"datetime":1573730878,"contact_id":0,"line_id":0,"name":"0977291066","new":true},{"number":"0367480231","type":"accepted","id":196,"duration":13,"datetime":1573568076,"contact_id":0,"line_id":0,"name":"0367480231","new":true},{"number":"0367480231","type":"missed","id":195,"duration":27,"datetime":1573568048,"contact_id":0,"line_id":0,"name":"0367480231","new":true},{"number":"+447268681244","type":"missed","id":194,"duration":21,"datetime":1573557302,"contact_id":0,"line_id":0,"name":"+447268681244","new":true},{"number":"0985703919","type":"accepted","id":193,"duration":40,"datetime":1573132189,"contact_id":0,"line_id":0,"name":"0985703919","new":true},{"number":"0320295885","type":"accepted","id":192,"duration":15,"datetime":1572963699,"contact_id":0,"line_id":0,"name":"0320295885","new":true},{"number":"0320295885","type":"missed","id":191,"duration":27,"datetime":1572963671,"contact_id":0,"line_id":0,"name":"0320295885","new":true},{"number":"0985704720","type":"accepted","id":186,"duration":40,"datetime":1572530517,"contact_id":0,"line_id":0,"name":"0985704720","new":false},{"number":"0147827733","type":"accepted","id":184,"duration":1126,"datetime":1572376104,"contact_id":0,"line_id":0,"name":"BOUSSIQUAULTARL","new":false},{"number":"0970186709","type":"accepted","id":181,"duration":31,"datetime":1572282193,"contact_id":0,"line_id":0,"name":"0970186709","new":false},{"number":"","type":"accepted","id":179,"duration":1150,"datetime":1572206705,"contact_id":0,"line_id":0,"name":"","new":false},{"number":"","type":"accepted","id":176,"duration":42,"datetime":1572182700,"contact_id":0,"line_id":0,"name":"","new":false},{"number":"0985705783","type":"missed","id":175,"duration":27,"datetime":1571741393,"contact_id":0,"line_id":0,"name":"0985705783","new":false},{"number":"+262692830101","type":"accepted","id":174,"duration":44,"datetime":1571647827,"contact_id":0,"line_id":0,"name":"+262692830101","new":false},{"number":"0971073978","type":"missed","id":173,"duration":26,"datetime":1571420985,"contact_id":0,"line_id":0,"name":"0971073978","new":false},{"number":"0756786118","type":"missed","id":172,"duration":18,"datetime":1571068537,"contact_id":0,"line_id":0,"name":"0756786118","new":false}]}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":2,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":18,"nb_tasks_stopping":0,"nzb_config_status":{"status":"error","error":"connection_refused"},"conn_ready":false,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":2,"nb_tasks_seeding":0,"nb_tasks_error":0,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":20,"nb_rss":8,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":true}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"type":"ethernet","rate_down":2340,"bytes_up":4070100442,"ipv4_port_range":[0,16383],"rate_up":2300,"bandwidth_up":1060000,"ipv6":"2a01:e0a:4b3:2440::1","bandwidth_down":19340000,"media":"xdsl","state":"up","bytes_down":49201953677,"ipv4":"88.122.204.145"}}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/connection/xdsl/([])
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"msg":"Erreur interne","success":false,"error_code":"internal_error"}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"mac":"F4:CA:E5:48:23:B8","fan_rpm":1954,"box_flavor":"full","temp_cpub":63,"temp_cpum":55,"disk_status":"active","temp_hdd":36,"board_name":"fbxgw1r","temp_sw":46,"uptime":"16 jours 11 heures 54 minutes 30 secondes","uptime_val":1425270,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"639601E113317169","firmware_version":"4.0.6"}}
[2019-12-01 08:48:29][DEBUG] : closing session :{"uid":"da6ac3bf461623f791f9400296873cb8","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"C\/BYEeD9L2r69361RE49a\/29ynmMpjmG","challenge":"nDBDOgtDrHDA5hT6rIaFa20QyhbOVwQK"},"error_code":"invalid_session"}
[2019-12-01 08:48:29][DEBUG] : [FreeboxRequest] {"success":true,"result":{"status":{"status":"showtime","protocol":"vdsl2_17a","uptime":448733,"modulation":"vdsl"},"down":{"es":135,"rtx_c":848698,"attn":31,"snr":5,"nitro":false,"attn_10":315,"hec":0,"rxmt_uncorr":0,"ses":10,"maxrate":19648,"phyr":false,"leftrs":163,"rxmt_corr":0,"ginp":true,"err_free_bits":653482161,"snr_10":52,"crc":120,"min_eftr":19341,"rtx_uc":47792,"rtx_tx":137760,"rate":19344,"fec":2261918,"rxmt":0},"up":{"es":0,"rtx_c":0,"attn":0,"snr":7,"nitro":false,"attn_10":0,"hec":0,"rxmt_uncorr":0,"ses":0,"maxrate":1062,"phyr":false,"leftrs":0,"rxmt_corr":0,"ginp":true,"err_free_bits":7179696,"snr_10":75,"crc":0,"min_eftr":1061,"rtx_uc":0,"rtx_tx":18,"rate":1062,"fec":0,"rxmt":0}}}
