Plugin Broadlink inopérant
je suis sous Jeedom V3 à jour, et j’ai depuis aujourd’hui un problème avec le plugin Brodlink depuis la mise à jour d’aujourd’hui, mais je ne sais pas si c’est lié à la mise à jour: plus aucun device ne sont commandé alors qu’hier tout fonctionnait (j’ai des SC1, des prise et multiprises braodlink ainsi qu’un broadlink universal remote ) le log indique par exemple lorsqu’une cde IR est envoyée:
[2020-11-21 20:03:35.202][DEBUG] : Message read from socket: b'{"apikey":"VNZAGxJqaROKaK8hV6F4VHlHkri56vZLELKAY9weeegdDjh6","cmd":"send","cmdType":"command","mac":"ff1718770f78","device":{"hex2send":"b2003a024f1b4f1a501a4f1a1c1b4f1b1b1b4f1a1c1b1c1a4f1b1b1b4f1a1d1a1c1a1c1a1c1a1c1b1c1a1c1a501a5019501a1c700001741a4f1a501a4f1b4f1a1c1a501a1d19501a1c1a1c1b4f1a1c1a501a1c1a1d1a1c1a1c1a1c1a1d1a1c1a4f1b4f1a501a1c700001741a4f1a501a4f1b4f1a1c1b4f1a1c1a501a1c1a1c1a501a1c1a501a1c1a1d191d1a1c1a1c1b1b1b1c1a4f1b4f1a501a1c700001741a4f1a4f1b4f1a501a1c1a501a1c1a4f1b1c1a1c1a501a1c1a4f1b1c1a1c1a1c1b1c1a1c1a1c1a1c1b4f1a501a4f1a1d700001731b4f1a4f1b4f1a501a1c1a501a1c1a501a1c1a1c1b4f1a1c1a501a1c1a1d191d1a1c1a1c1a1c1b1c1a501a4f1a501a1ce20001731a501b4e1b4f1a501a1c1a501a1c1a501a1c1a1c1a501a1c1a501a1c1a1c1a1d1a1c1a1c1b1b1b1c1a4f1b4f1a501a1c700001741a4f1b4f1a4f1b4f1a1d1a4f1b1c19501a1c1a1d1a4f1b1c1a4f1a1d1a1c1a1c1a1c1a1d1a1c1a1c1a501a5019501a1d6f0001741a501a5019501a501a1c1a501a1c1a501a1b1b1c1a501a1c1a501a1c1a1c1a1c1b1c1a1c1a1c1a1d1a4f1a501a4f1b1b710001741a4f1a501a501a4f1a1c1a501a1c1a501a1c1a1c1a501a1d1a4f1a1d191d1a1c1a1c1a1d1a1c1a1c1a4f1b4f1a501a1c700001741a4f1b4f1a501a4f1b1c1a4f1b1c1a4f1a1c1b1c1a4f1a1d1a4f1b1c1a1c1a1c1a1d1a1c1a1c1a1c1a501a4f1b4f1a1c700001741a501a501a4f1a501a1c1a501a1c1a501a1c1a1c1b4f1a1c1a501a1c1b1c191d1a1c1a1c1a1c1b1c1a4f1a501a501a1c0005dc0000000000000000000000000000","ip":"192.168.1.196","port":"80","type":"rm2","name":"Broadlink Universel remote","mac":"ff1718770f78"}}'
[2020-11-21 20:03:35.202][DEBUG] : Client disconnected from [127.0.0.1:42434]
[2020-11-21 20:03:35.205][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-11-21 20:03:35.206][DEBUG] : Send command
[2020-11-21 20:03:35.206][ERROR] : initialization_vector must be bytes
a chaque fois qu’une cde est envoyée j’ai le message
j’ai rechargé la backup d’avant le pb et donc revenu à l’ancienne version broadlink mais cela n’ a pas résolu le problème.
nota après la mise à jour du plugin j’ai relancé les dépendances ??
je ne sais plus trop quoi faire
Bonsoir, après recherche sur le forum cette mise à jour semble buggé.
Il faut attendre le correctif ou recharger une sauvegarde d’avant la mise à jour de ce plugin.
Le correctif pour le souci de ce matin est en ligne … et dispo via le market
Là c’est autre chose, à priori pas résolu par la restauration
Ok
Merci pour l’info @naboleo
Comme quoi ne jamais se précipiter sur les mises à jour me sauve les fesses régulièrement.
Il faut aussi que certains tentent au moment où les nouveautés arrivent, sinon on risque de tous s’attendre.
C’est ce que j’ai fait, la sauvegarde de la nuit, mais nib
[2020-11-21 20:41:12.660][DEBUG] : Handling SP2 for 155-Sc1-N\xe9on Boucarou
[2020-11-21 20:41:12.661][ERROR] : initialization_vector must be bytes
[2020-11-21 20:41:12.742][DEBUG] : Handling SP2 for 45-SP3-3_ON-OFF_alim_an\xe9mo
[2020-11-21 20:41:12.742][ERROR] : initialization_vector must be bytes
[2020-11-21 20:41:12.845][DEBUG] : Handling MP1 for Multiprise
[2020-11-21 20:41:12.846][ERROR] : initialization_vector must be bytes
[2020-11-21 20:42:12.676][DEBUG] : Handling SP2 for 155-Sc1-N\xe9on Boucarou
[2020-11-21 20:42:12.677][ERROR] : initialization_vector must be bytes
[2020-11-21 20:42:12.698][DEBUG] : Handling SP2 for SC1-46-Ruban Led escalier
[2020-11-21 20:42:12.698][ERROR] : initialization_vector must be bytes
[2020-11-21 20:42:12.718][DEBUG] : Handling SP2 for Sp3 inter \xe9cl entr\xe9e,44
[2020-11-21 20:42:12.719][ERROR] : initialization_vector must be bytes
[2020-11-21 20:42:12.760][DEBUG] : Handling SP2 for 45-SP3-3_ON-OFF_alim_an\xe9mo
[2020-11-21 20:42:12.761][ERROR] : initialization_vector must be bytes
[2020-11-21 20:42:12.864][DEBUG] : Handling MP1 for Multiprise
[2020-11-21 20:42:12.865][ERROR] : initialization_vector must be bytes
En plus depuis j’ai passé le plugin en mode inclusion et impossible d’arrêter l’inclusion!
Essayez de relancer les dépendances. Soyez patient, puis une fois les dépendances OK, relancer le plugin. Personnellement, j’ai dû lancer les dépendances 2 fois
Même après plusieurs relance des dépendances, aucune commande ne fonctionne, même erreur que les autres utilisateurs :
[2020-11-22 10:15:13.276][DEBUG] : Handling RM2 for Velux Patio
[2020-11-22 10:15:13.278][ERROR] : initialization_vector must be bytes
Bonsoir, j’ai tenté le coup des dépendances une nouvelle fois relancé les dépendance une première fois hiers) . d’après le log tout était déjà ok, mis à par les avertissement de l’obsolescence future de Python 2.7 et une suggestion de mise à jour de PIP par la cmd "/usr/bin/python -m pip install --upgrade pip ", ce que j’ai fait, puis remis une couche et relancer les dépendances (3ème fois) relancé le Daemon et là bingo, le jackpot, tout remarche !!
Merci @Makai de la suggestion,
Edit: j’étais repassé en arrière avec un backup, donc je reste comme ça sans mise à jour du plugin. Sur un autre Jeedom V4 sur un RPI3 j’ai fait le test d’une MAJ du plugin et là pareil :
[2020-11-22 18:05:20.595][DEBUG] : Handling MP1 for Multiprise_Broadlink
[2020-11-22 18:05:20.596][ERROR] : initialization_vector must be bytes
donc le Pb semble rester entier. Wait and see
Même pb que tout le monde.
Je suis en v4 et malgré plusieurs réinstallations des dépendances, rien à faire.
J’hésite à faire une restauration.
