bonjour, j’ai quelle que problème avec ce plugin et mon onduleur, voila les log et quelles images
[2019-11-07 20:00:29][DEBUG] : Get information string APC : 001,036,0888 DATE : 2019-11-07 19:00:15 +0000 HOSTNAME : raspberrypi VERSION : 3.14.14 (31 May 2016) debian UPSNAME : jeedom UPS_IDEN CABLE : USB Cable DRIVER : USB UPS Driver UPSMODE : Stand Alone STARTTIME: 2019-11-07 18:44:55 +0000 MODEL : Back-UPS XS 700U STATUS : ONLINE LINEV : 222.0 Volts LOADPCT : 13.0 Percent BCHARGE : 100.0 Percent TIMELEFT : 32.9 Minutes MBATTCHG : 5 Percent MINTIMEL : 3 Minutes MAXTIME : 0 Seconds SENSE : Medium LOTRANS : 140.0 Volts HITRANS : 300.0 Volts ALARMDEL : 30 Seconds BATTV : 13.6 Volts LASTXFER : Unacceptable line voltage changes NUMXFERS : 0 TONBATT : 0 Seconds CUMONBATT: 0 Seconds XOFFBATT : N/A SELFTEST : NO STATFLAG : 0x05000008 SERIALNO : 3B1523X08811 BATTDATE : 2015-06-03 NOMINV : 230 Volts NOMBATTV : 12.0 Volts NOMPOWER : 390 Watts FIRMWARE : 924.Z3 .I USB FW:Z3 END APC : 2019-11-07 19:00:29 +0000 from apcaccess
[2019-11-07 20:00:29][DEBUG] : Get information key APC with value 001,036,0888
[2019-11-07 20:00:29][DEBUG] : Get information key DATE with value 2019-11-07 19:00:15 +0000
[2019-11-07 20:00:29][DEBUG] : Get information key HOSTNAME with value raspberrypi
[2019-11-07 20:00:29][DEBUG] : Get information key VERSION with value 3.14.14 (31 May 2016) debian
[2019-11-07 20:00:29][DEBUG] : Get information key UPSNAME with value jeedom UPS_IDEN
[2019-11-07 20:00:29][DEBUG] : Get information key CABLE with value USB Cable
[2019-11-07 20:00:29][DEBUG] : Get information key DRIVER with value USB UPS Driver
[2019-11-07 20:00:29][DEBUG] : Get information key UPSMODE with value Stand Alone
[2019-11-07 20:00:29][DEBUG] : Get information key STARTTIME with value 2019-11-07 18:44:55 +0000
[2019-11-07 20:00:29][DEBUG] : Get information key MODEL with value Back-UPS XS 700U
[2019-11-07 20:00:29][DEBUG] : Get information key STATUS with value ONLINE
[2019-11-07 20:00:29][DEBUG] : Get information key LINEV with value 222.0 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key LOADPCT with value 13.0 Percent
[2019-11-07 20:00:29][DEBUG] : Get information key BCHARGE with value 100.0 Percent
[2019-11-07 20:00:29][DEBUG] : Get information key TIMELEFT with value 32.9 Minutes
[2019-11-07 20:00:29][DEBUG] : Get information key MBATTCHG with value 5 Percent
[2019-11-07 20:00:29][DEBUG] : Get information key MINTIMEL with value 3 Minutes
[2019-11-07 20:00:29][DEBUG] : Get information key MAXTIME with value 0 Seconds
[2019-11-07 20:00:29][DEBUG] : Get information key SENSE with value Medium
[2019-11-07 20:00:29][DEBUG] : Get information key LOTRANS with value 140.0 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key HITRANS with value 300.0 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key ALARMDEL with value 30 Seconds
[2019-11-07 20:00:29][DEBUG] : Get information key BATTV with value 13.6 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key LASTXFER with value Unacceptable line voltage changes
[2019-11-07 20:00:29][DEBUG] : Get information key NUMXFERS with value 0
[2019-11-07 20:00:29][DEBUG] : Get information key TONBATT with value 0 Seconds
[2019-11-07 20:00:29][DEBUG] : Get information key CUMONBATT with value 0 Seconds
[2019-11-07 20:00:29][DEBUG] : Get information key XOFFBATT with value N/A
[2019-11-07 20:00:29][DEBUG] : Get information key SELFTEST with value NO
[2019-11-07 20:00:29][DEBUG] : Get information key STATFLAG with value 0x05000008
[2019-11-07 20:00:29][DEBUG] : Get information key SERIALNO with value 3B1523X08811
[2019-11-07 20:00:29][DEBUG] : Get information key BATTDATE with value 2015-06-03
[2019-11-07 20:00:29][DEBUG] : Get information key NOMINV with value 230 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key NOMBATTV with value 12.0 Volts
[2019-11-07 20:00:29][DEBUG] : Get information key NOMPOWER with value 390 Watts
[2019-11-07 20:00:29][DEBUG] : Get information key FIRMWARE with value 924.Z3 .I USB FW:Z3
[2019-11-07 20:00:29][DEBUG] : Get information key END APC with value 2019-11-07 19:00:29 +0000
[2019-11-07 20:00:29][DEBUG] : Update command event
[2019-11-07 20:00:29][DEBUG] : => ignore
[2019-11-07 20:00:29][DEBUG] : Update command model
[2019-11-07 20:00:29][DEBUG] : => apply model case
[2019-11-07 20:00:29][DEBUG] : => update command model with Back-UPS XS 700U
[2019-11-07 20:00:29][DEBUG] : Update command status
[2019-11-07 20:00:29][DEBUG] : => apply default case
[2019-11-07 20:00:29][DEBUG] : => update command status with ONLINE
[2019-11-07 20:00:29][DEBUG] : Update command bcharge
[2019-11-07 20:00:29][DEBUG] : => update battery status
