Hello
J’ai les messages suivant qui apparaissent dans le http.error et cron_execution
Pour le #plugin-alexaamazonmusic, j’ai les messages suivants :
[Fri Apr 16 07:46:18.957714 2021] [php7:warn] [pid 13871] [client 192.168.156.232:60552] PHP Warning: Declaration of alexaamazonmusicCmd::getWidgetTemplateCode($_version = 'dashboard', $_noCustom = false) should be compatible with cmd::getWidgetTemplateCode($_version = 'dashboard', $_clean = true, $_widgetName = '') in /var/www/html/plugins/alexaamazonmusic/core/class/alexaamazonmusic.class.php on line 0
[Fri Apr 16 16:00:30.462984 2021] [php7:warn] [pid 5771] [client 192.168.156.29:64564] PHP Warning: Declaration of alexaamazonmusicCmd::getWidgetTemplateCode($_version = 'dashboard', $_noCustom = false) should be compatible with cmd::getWidgetTemplateCode($_version = 'dashboard', $_clean = true, $_widgetName = '') in /var/www/html/plugins/alexaamazonmusic/core/class/alexaamazonmusic.class.php on line 434, referer: http://192.168.156.232/index.php?v=d&p=dashboard&object_id=1
Pour le #plugin-alexasmarthome , j’ai les messages suivants :
PHP Warning: Invalid argument supplied for foreach() in /var/www/html/plugins/alexasmarthome/core/class/alexasmarthome.class.php on line 241
PHP Warning: Declaration of alexasmarthomeCmd::getWidgetTemplateCode($_version = 'dashboard', $_noCustom = false) should be compatible with cmd::getWidgetTemplateCode($_version = 'dashboard', $_clean = true, $_widgetName = '') in /var/www/html/plugins/alexasmarthome/core/class/alexasmarthome.class.php on line 0
Ce n’est pas bloquant mais cela rempli les logs
Dispo si besoin de plus de renseignements
merci
