Et merci pour ce plugin.
Apres installation est configuration du plugin j’ai ce message d’erreur :
[2021-11-12 15:25:02][DEBUG] : REFRESH_DASHBOARD WITH DATA ..... {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:25:02][INFO] : REPONSE REQUETE : SUCCESS : {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:26:29][INFO] : DATA_ALL_SYSTEMS_ZONES: []
[2021-11-12 15:27:32][INFO] : REQUETEINTEGRATION : {"driver":"1"}
[2021-11-12 15:27:32][INFO] : REPONSE REQ INTEGRATION : { "driver": "1" }
[2021-11-12 15:28:28][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=airzone function=remove callInstallFunction=1
[2021-11-12 15:28:29][INFO] : Début d'activation du plugin
[2021-11-12 15:28:30][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2021-11-12 15:28:30][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=airzone function=install callInstallFunction=1
[2021-11-12 15:29:05][INFO] : DATA_ALL_SYSTEMS_ZONES: []
[2021-11-12 15:30:02][DEBUG] : REFRESH_DASHBOARD WITH DATA ..... {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:30:02][INFO] : REPONSE REQUETE : SUCCESS : {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:30:22][INFO] : DATA_ALL_SYSTEMS_ZONES: []
[2021-11-12 15:35:02][DEBUG] : REFRESH_DASHBOARD WITH DATA ..... {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:35:02][INFO] : REPONSE REQUETE : SUCCESS : {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:38:03][INFO] : REQUETEINTEGRATION : {"driver":"0"}
[2021-11-12 15:38:03][INFO] : REPONSE REQ INTEGRATION : { "driver": "0" }
[2021-11-12 15:40:02][DEBUG] : REFRESH_DASHBOARD WITH DATA ..... {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:40:02][INFO] : REPONSE REQUETE : SUCCESS : {"errors":[{"error":"systemid out of range"}]}
[2021-11-12 15:45:02][DEBUG] : REFRESH_DASHBOARD WITH DATA ..... {"errors":[{"error":"systemid out of range"}]}
Je suis certain que j’ai la bonne ip et le port de configurer puisque j’arrive à y accéder avec d’autres outils.
Je ne vois pas ou configurer le systemid qui semble poser problème.
D’avance merci
