Plantage systématique du deamon depuis mise à jour 2024-10-17
Petit souci depuis la mise à jour du 17/10 …
Le daemon tente de démarrer mais sans succès.
Les logs :
daemon :
[2024-10-18 10:56:45][DEBUG] : hardware:RPI 4 B
[2024-10-18 10:56:45][DEBUG] : status:1
[2024-10-18 10:56:45][DEBUG] : session:1
[2024-10-18 10:56:45][DEBUG] : user set:1
[2024-10-18 10:56:45][DEBUG] : user obj:1
[2024-10-18 10:56:45][DEBUG] : user id obj:1
[2024-10-18 10:56:45][DEBUG] : user id con:1
[2024-10-18 10:56:45][DEBUG] : right:
[2024-10-18 10:56:45][DEBUG] : OK connect
[2024-10-18 10:59:48][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-10-18 10:59:51][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:00:04][DEBUG] : hardware:RPI 4 B
[2024-10-18 11:00:04][DEBUG] : status:1
[2024-10-18 11:00:04][DEBUG] : session:1
[2024-10-18 11:00:04][DEBUG] : user set:1
[2024-10-18 11:00:04][DEBUG] : user obj:1
[2024-10-18 11:00:04][DEBUG] : user id obj:1
[2024-10-18 11:00:04][DEBUG] : user id con:1
[2024-10-18 11:00:04][DEBUG] : right:
[2024-10-18 11:00:04][DEBUG] : OK connect
[2024-10-18 11:00:17][DEBUG] : hardware:RPI 4 B
[2024-10-18 11:00:17][DEBUG] : status:1
[2024-10-18 11:00:17][DEBUG] : session:1
[2024-10-18 11:00:17][DEBUG] : user set:1
[2024-10-18 11:00:17][DEBUG] : user obj:1
[2024-10-18 11:00:17][DEBUG] : user id obj:1
[2024-10-18 11:00:17][DEBUG] : user id con:1
[2024-10-18 11:00:17][DEBUG] : right:
[2024-10-18 11:00:17][DEBUG] : OK connect
[2024-10-18 11:05:19][DEBUG] : hardware:RPI 4 B
[2024-10-18 11:05:19][DEBUG] : status:1
[2024-10-18 11:05:19][DEBUG] : session:1
[2024-10-18 11:05:19][DEBUG] : user set:1
[2024-10-18 11:05:19][DEBUG] : user obj:1
[2024-10-18 11:05:19][DEBUG] : user id obj:1
[2024-10-18 11:05:19][DEBUG] : user id con:1
[2024-10-18 11:05:19][DEBUG] : right:
[2024-10-18 11:05:19][DEBUG] : OK connect
[2024-10-18 11:11:10][DEBUG] : hardware:RPI 4 B
[2024-10-18 11:11:10][DEBUG] : status:1
[2024-10-18 11:11:10][DEBUG] : session:1
[2024-10-18 11:11:10][DEBUG] : user set:1
[2024-10-18 11:11:10][DEBUG] : user obj:1
[2024-10-18 11:11:10][DEBUG] : user id obj:1
[2024-10-18 11:11:10][DEBUG] : user id con:1
[2024-10-18 11:11:10][DEBUG] : right:
[2024-10-18 11:11:10][DEBUG] : OK connect
[2024-10-18 11:11:23][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-10-18 11:11:35][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:14:27][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-10-18 11:16:03][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:20:14][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:25:51][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:32:05][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
[2024-10-18 11:35:26][ERROR] : Erreur sur wifilightV2::daemonTuya() : syntax error, unexpected '='
Update :
*             Installation des dépendances             *
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:4 https://dl.ui.com/unifi/debian stable InRelease
Fetched 15.0 kB in 1s (11.3 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
arp-scan is already the newest version (1.9.5-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
*             Installation terminée                    *
Santé jeedom :
J’ai cherché dans la doc et dans le forum :blush:, mais rien vu qui ressemblait à ça :thinking:.
Merci pour votre aide.
Didier
Informations Jeedom
Core : 4.4.18 (master)
DNS Jeedom : oui
Plugin : wifilightV2
Version : 2024-10-17 10:41:10 (stable)
Statut Démon : Stoppé - (2024-10-18 10:59:48)
Sans lien probable mais je vous signale que vous êtes en debian 10 qui n’est plus supporté depuis quelques mois. Donc vous risquez d’avoir des misws à jour lors de vos prochaines mises à jours, quelque soit le plugin.
Il faudrait faire une nouvelle installation en debian 11 ou ne plus toucher aux mises à jour plugin et jeedom.
Je viens de faire un scan du code et je n’ai pas d’erreur de syntaxe.
peux-tu désactiver tous les périphériques du plugin et voir si le daemon tient?
Ca me guidera un peu
En attendant, reprenez une sauvegarde.
Bonjour Antoine,
Oui, j’en suis conscient.
J’ai un raspberry PI4 avec carte SD, os Raspbian. D’après ce que j’ai lu, la mise à jour os n’est pas triviale :frowning_face:.
Je vais remplacer la Sd par un SDD avec Raspberry PI os préinstallé. Je ferai la reprise de mon jeedom sur cette nouvelle version. :slightly_smiling_face:
A suivre…
Didier
Bonjour Bernard,
J’ai désactivé mes équipements (deux compteurs élec Tuya ZMAI/EMAI, une gateway tuya zigbee).
Le daemon reste en vie après redémarrage. :slightly_smiling_face:.
Je vais réactiver les équipements un à un.
A suivre…
Didier
C’est assez simple d’installer un os. Il y a un logiciel créer par le fondation raspberry qui fait le job. Pas besoin d’acheter un ssd pré-installé (avec le risqie d’avoir debian 12) sauf à avoir aucune notion en informatique.
J’ai le même problème depuis la màj du 16/10 (compteur ZMAI90 et prise pilotable). Je suis repassé sur la version précédente en attendant.
Je vois qu’une nouvelle version est dispo depuis le 22/10 avec un correctif spécifique Tuya. Est-ce que quelqu’un peut confirmer qu’elle règle le problème décrit ci-dessus ?
Normalement c’est réglé mais pas eu de retour
J’ai fait la même chose, je suis revenu sur la sauvegarde d’avant mise à jour. Pas encore tenté la version du 22/10. Pas de nécessité de mon coté.
Je suis en train migrer mon raspberry de raspbian vers raspberry PI OS (debian 10 vers 11).
Je verrai à ce moment là. A suivre.
Didier
La mise à jour du 22/10 a réglé le pb. :slightly_smiling_face:
Didier
J’ai installé la màj du 22/10 ce matin et je confirme que je n’ai plus l’erreur.
@DoubleD peux-tu mettre résolu ?
