[2022-03-09 18:02:50][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2022-03-09 18:02:50][DEBUG] : null
[2022-03-09 18:02:50][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=0 type : GET
[2022-03-09 18:02:50][DEBUG] : [{"ieee":"00:21:2e:ff:ff:07:b4:da","nwk":0,"status":2,"lqi":"221","rssi":"30","last_seen":"1646845352.811715","node_descriptor":"10:40:0f:35:11:47:2b:00:40:00:2b:00:00","endpoints":[{"id":1,"status":1,"device_type":5,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":1280,"name":"IAS Zone","attributes":[]}],"input_clusters":[{"id":25,"name":"Ota","attributes":[]},{"id":10,"name":"Time","attributes":[]}]},{"id":242,"status":1,"device_type":100,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"model":"RaspBee II","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":1,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":15,"manufacturer_code":4405,"maximum_buffer_size":71,"maximum_incoming_transfer_size":43,"server_mask":64,"maximum_outgoing_transfer_size":43,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":5,"input_clusters":[25,10],"output_clusters":[1280]},"242":{"profile_id":41440,"device_type":100,"input_clusters":[],"output_clusters":[33]}}},"class":"zigpy_deconz.zigbee.application"}]
[2022-03-09 18:02:50][DEBUG] : [{"ieee":"00:21:2e:ff:ff:07:b4:da","nwk":"0x0000","lqi":221,"rssi":30,"device_type":"Coordinator","manufacturer":"dresden elektronik","model":"RaspBee II","offline":false,"neighbours":[]}]
[2022-03-09 18:02:50][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2022-03-09 18:02:50][DEBUG] : {"ieee":"00:21:2e:ff:ff:07:b4:da","zigpy_version":"0.43.0","zha_version":"0.0.67","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_deconz.db","device":{"path":"\/dev\/ttyACM0"},"network":{"channel":15,"tc_address":null,"key_sequence_number":0,"key":null,"channels":34635776,"extended_pan_id":null,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","pan_id":null,"update_id":0},"topology_scan_period":240,"topology_scan_skip_coordinator":false,"ota":{"ledvance_provider":false,"salus_provider":false,"ikea_provider":false,"otau_directory":null},"topology_scan_enabled":true,"watchdog_ttl":600},"deconz":{"zigpy_deconz_version":"0.14.0","version":"0x26720700","extendedPanId":"da:b4:07:ff:ff:2e:21:00","panId":"0x9fc3","radioChannel":15,"nwkUpdateId":"0x2"}}
[2022-03-09 18:02:53][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2022-03-09 18:02:53][DEBUG] : null
[2022-03-09 18:02:53][DEBUG] : [{"ieee":"00:21:2e:ff:ff:07:b4:da","nwk":"0x0000","lqi":221,"rssi":30,"device_type":"Coordinator","manufacturer":"dresden elektronik","model":"RaspBee II","offline":false,"neighbours":[]}]
[2022-03-09 18:03:15][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2022-03-09 18:03:15][DEBUG] : {"duration":180}
[2022-03-09 18:03:15][DEBUG] : ""
[2022-03-09 18:03:28][DEBUG] : {"device_joined":"00:15:8d:00:07:c5:74:3f"}
[2022-03-09 18:03:28][DEBUG] : {"device_initialized":"00:15:8d:00:07:c5:74:3f"}
[2022-03-09 18:03:29][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":[{"65281":{"value":"b'\x01!\xa9\x0b\x03(\x1a\x04!\xa8\x01\x05!\x06\x00\x06$\x01\x00\x00\x00\x00
!\x00\x00d\x10\x00'","cluster_name":"BasicCluster"}},{"32":{"value":"29.9","cluster_name":"Power Configuration"},"33":{"value":"118","cluster_name":"Power Configuration"}},[{"value":"2600","cluster_name":"Device Temperature"}]]}}}
[2022-03-09 18:03:40][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":[{"4":{"value":"LUMI","cluster_name":"BasicCluster"},"5":{"value":"lumi.sensor_magnet.aq2","cluster_name":"BasicCluster"},"event":{"attribute_updated":{"value":{"attribute_id":5,"attribute_name":"model","value":"lumi.sensor_magnet.aq2"},"cluster_name":"BasicCluster"}}}]}}}
[2022-03-09 18:03:44][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":[[{"value":"1","cluster_name":"BasicCluster"},{"value":"3","cluster_name":"BasicCluster"},{"value":"2","cluster_name":"BasicCluster"},{"value":"2","cluster_name":"BasicCluster"}]]}}}
[2022-03-09 18:03:47][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":[{"7":{"value":"PowerSource.Battery","cluster_name":"BasicCluster"}}]}}}
[2022-03-09 18:03:53][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":[{"6":{"value":"20161128","cluster_name":"BasicCluster"},"16384":{"value":"3000-0001","cluster_name":"BasicCluster"}}]}}}
[2022-03-09 18:03:58][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-03-09 18:03:58][DEBUG] : {"with_attributes":2}
[2022-03-09 18:03:59][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2022-03-09 18:03:59][DEBUG] : {"ieee":"00:15:8d:00:07:c5:74:3f","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-03-09 18:03:59][INFO] : [Aucun][LUMI.lumi.sensor_magnet.aq2 00:15:8d:00:07:c5:74:3f] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:07:c5:74:3f","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Cluster not found : 6","code":0}
[2022-03-09 18:03:59][DEBUG] : {"ieee":"00:15:8d:00:07:c5:74:3f","endpoint":1,"cluster":2,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-03-09 18:03:59][DEBUG] : [Aucun][LUMI.lumi.sensor_magnet.aq2 00:15:8d:00:07:c5:74:3f] refresh
[2022-03-09 18:03:59][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-03-09 18:03:59][DEBUG] : null
[2022-03-09 18:03:59][DEBUG] : http://127.0.0.1:8089/device/info?ieee=00%3A15%3A8d%3A00%3A07%3Ac5%3A74%3A3f type : GET
[2022-03-09 18:03:59][DEBUG] : {"ieee":"00:15:8d:00:07:c5:74:3f"}
[2022-03-09 18:03:59][DEBUG] : {"devices":{"00:15:8d:00:07:c5:74:3f":{"1":{"2":[{"value":"2600","cluster_name":"Device Temperature"}]}}}}
[2022-03-09 18:03:59][DEBUG] : Search attribut for 00:15:8d:00:07:c5:74:3f logicalId : 1::2::0 => 2600 convert to 2600
[2022-03-09 18:04:44][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2022-03-09 18:04:44][DEBUG] : {"duration":180}
[2022-03-09 18:04:45][DEBUG] : ""
[2022-03-09 18:05:00][DEBUG] : {"device_joined":"84:71:27:ff:fe:72:fc:a2"}
[2022-03-09 18:05:01][DEBUG] : {"device_initialized":"84:71:27:ff:fe:72:fc:a2"}
[2022-03-09 18:05:04][DEBUG] : {"devices":{"84:71:27:ff:fe:72:fc:a2":{"1":{"1026":[{"value":"2090","cluster_name":"Temperature Measurement"}],"1029":[{"value":"3660","cluster_name":"Relative Humidity Measurement"}]}}}}
[2022-03-09 18:05:07][DEBUG] : {"devices":{"84:71:27:ff:fe:72:fc:a2":{"1":[[{"value":"3","cluster_name":"Basic"},{"value":"72","cluster_name":"Basic"},{"value":"0","cluster_name":"Basic"},{"value":"1","cluster_name":"Basic"}]]}}}
[2022-03-09 18:05:08][DEBUG] : {"devices":{"84:71:27:ff:fe:72:fc:a2":{"1":[{"7":{"value":"PowerSource.Battery","cluster_name":"Basic"}}]}}}
[2022-03-09 18:05:10][DEBUG] : {"devices":{"84:71:27:ff:fe:72:fc:a2":{"1":[{"6":{"value":"","cluster_name":"Basic"}}]}}}
[2022-03-09 18:05:31][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-03-09 18:05:31][DEBUG] : {"with_attributes":2}
[2022-03-09 18:05:31][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2022-03-09 18:05:31][DEBUG] : {"ieee":"84:71:27:ff:fe:72:fc:a2","endpoint":1,"cluster":1029,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-03-09 18:05:39][INFO] : [Aucun][TZ2000_a476raq2.TS0201 84:71:27:ff:fe:72:fc:a2] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"84:71:27:ff:fe:72:fc:a2","endpoint":1,"cluster":1029,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"[0x753f:1:0x0405]: Message send failure","code":0}
[2022-03-09 18:05:39][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2022-03-09 18:05:39][DEBUG] : {"ieee":"84:71:27:ff:fe:72:fc:a2","endpoint":1,"cluster":1026,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-03-09 18:05:47][INFO] : [Aucun][TZ2000_a476raq2.TS0201 84:71:27:ff:fe:72:fc:a2] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"84:71:27:ff:fe:72:fc:a2","endpoint":1,"cluster":1026,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"[0x753f:1:0x0402]: Message send failure","code":0}
[2022-03-09 18:05:47][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-03-09 18:05:47][DEBUG] : null
[2022-03-09 18:05:47][DEBUG] : http://127.0.0.1:8089/device/info?ieee=84%3A71%3A27%3Aff%3Afe%3A72%3Afc%3Aa2 type : GET
[2022-03-09 18:05:47][DEBUG] : {"ieee":"84:71:27:ff:fe:72:fc:a2"}
voilà les logs du plugins, merci
