@Bison
j’ai tenté un réinstallation mais y’a des choses qui coince
i@CHEOPSrasp:/var/www/html/jeedom $ sudo wget https://raw.githubusercontent.com/jeedom/core/master/install/install.sh
sudo chmod +x install.sh
sudo ./install.sh
--2024-06-18 21:59:44-- https://raw.githubusercontent.com/jeedom/core/master/install/install.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 2606:50c0:8003::154, 2606:50c0:8001::154, 2606:50c0:8000::154, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|2606:50c0:8003::154|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 16302 (16K) [text/plain]
Saving to: 'install.sh'
install.sh 100%[=======================================================>] 15.92K --.-KB/s in 0.001s
2024-06-18 21:59:44 (17.1 MB/s) - 'install.sh' saved [16302/16302]
Welcome to Jeedom installer
Jeedom version : V4-stable
Web folder : /var/www/html
Installation type : standard
Starting installation ...
Starting step 1 - install
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 299 not upgraded.
Calculating upgrade... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libc6-dev : Breaks: libgcc-8-dev (< 8.4.0-2~) but 8.3.0-6+rpi1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Step 1 - Install done
Starting step 2 - packages
software-properties-common is already the newest version (0.96.20.2-2.1).
File "/usr/bin/add-apt-repository", line 95, in <module>
sp = SoftwareProperties(options=options)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
self.reload_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/bullseye
Hit:2 http://phoscon.de/apt/deconz buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
ca-certificates is already the newest version (20210119).
cron is already the newest version (3.0pl1-137).
curl is already the newest version (7.74.0-1.3+deb11u11).
ntp is already the newest version (1:4.2.8p15+dfsg-1).
sudo is already the newest version (1.9.5p2-3+deb11u1).
unzip is already the newest version (6.0-26+deb11u1).
dos2unix is already the newest version (7.4.1-1).
fail2ban is already the newest version (0.11.2-2).
iotop is already the newest version (0.6-24-g733f3f8-1.1).
locate is already the newest version (4.8.0-1).
logrotate is already the newest version (3.18.0-2+deb11u2).
ntpdate is already the newest version (1:4.2.8p15+dfsg-1).
tar is already the newest version (1.34+dfsg-1+deb11u1).
telnet is already the newest version (0.17-42).
wget is already the newest version (1.21-1+deb11u1).
dconf-service : Depends: default-dbus-session-bus or
dbus-session-bus
libsoup2.4-1 : Depends: glib-networking (>= 2.32.0) but it is not going to be installed
E: Unable to locate package usermod
E: Unable to locate package visudo
git is already the newest version (1:2.30.2-1+deb11u2).
python-pip is already the newest version (18.1-5+rpt1).
python is already the newest version (2.7.16-1).
dbus-session-bus
libexpat1 is already the newest version (2.2.10-2+deb11u5).
ssl-cert is already the newest version (1.1.0+nmu1).
apt-transport-https is already the newest version (2.2.4).
cutycapt is already the newest version (0.0~svn10-0.1).
xauth is already the newest version (1:1.1-1).
dbus-session-bus
at is already the newest version (3.1.23-1.1).
glib-networking : Depends: gsettings-desktop-schemas but it is not going to be installed
libgtk-3-common : Depends: dconf-gsettings-backend but it is not going to be installed or
gsettings-backend
Package libav-tools is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
ffmpeg
E: Package 'libav-tools' has no installation candidate
Package libttspico-utils is not available, but is referred to by another package.
E: Package 'libttspico-utils' has no installation candidate
dbus-session-bus
Package mbrola is not available, but is referred to by another package.
E: Package 'mbrola' has no installation candidate
net-tools is already the newest version (1.60+git20181103.0eebece-1).
dbus-session-bus
dbus-session-bus
usbutils is already the newest version (1:013-3).
gettext is already the newest version (0.21-4).
libcurl3-gnutls is already the newest version (7.74.0-1.3+deb11u11).
libgtk-3-0 : Depends: libgtk-3-common (>= 3.24.5-1+rpt2) but it is not going to be installed
Recommends: libgtk-3-bin but it is not going to be installed
librsync-dev is already the newest version (2.3.1-1).
dbus-session-bus
snmp-mibs-downloader is already the newest version (1.5).
Package 'brltty' is not installed, so not removed
step 2 - packages done
Starting step 3 - databse
mariadb-common is already the newest version (1:10.5.23-0+deb11u1).
dbus-session-bus
Cannot install mariadb-client mariadb-common mariadb-server - Cancelling
pi@CHEOPSrasp:/var/www/html/jeedom $
