Pour info
fresh install OOTB sur pi5 bookworm 64b (je sais en version beta, etc…) pas de restore de backup
1er plugin installé : jeezigbee donc avec mqqt manager
le demon ne se lance pas
semble venir de mosquito
seul log:
Fri, 22 Mar 2024 13:05:02 GMT body-parser deprecated undefined extended: provide extended option at jeedom/jeedom.js:168:31
[2024-03-22 13:05:02] ERROR : Callback error.Please check your network configuration page : {"message":"Request failed with status code 403","name":"AxiosError","stack":"AxiosError: Request failed with status code 403\n at settle (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:1966:12)\n at IncomingMessage.handleStreamEnd (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:3065:11)\n at IncomingMessage.emit (node:events:529:35)\n at endReadableNT (node:internal/streams/readable:1400:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:3876:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.6.8","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=xLk83YaSVekMjvieVXIShR46qN1IwGpInkF19sEg4AswtipoXPiJBeOIQvuKEYkD"},"code":"ERR_BAD_REQUEST","status":403}
Informations Jeedom
Core : 4.4.2 (beta)
DNS Jeedom : oui
Plugin : MQTT Manager
Version : 2024-02-23 13:59:49 (stable)
Statut Démon : Stoppé - (2024-03-22 14:05:02)
