Sur VM Debian 11, Core beta 4.4.2
Le tout à jour
Quand je vais dans onglet OS/DB et que je fais une vérification générale j’ai cela dans les logs ?
0000|[START CONSISTENCY]
0001|[START CHECK AND FIX DB]
0002|[END CHECK AND FIX DB]
0003|Check jeedom package...OK
0004|Check jeedom database...OK
0005|Check crons...
0006|Check filesystem right...OK
0007|Flush cache widget...
0008|Check jeedom object...PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 33
0009|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0010|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0011|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0012|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0013|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0014|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0015|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0016|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0017|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0018|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0019|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0020|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0021|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0022|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0023|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0024|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0025|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0026|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0027|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0028|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0029|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0030|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0031|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0032|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0033|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0034|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0035|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0036|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0037|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0038|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0039|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0040|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0041|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0042|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0043|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0044|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0045|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0046|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0047|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0048|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0049|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0050|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0051|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0052|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0053|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0054|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0055|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0056|PHP Warning: fopen(/tmp/jeedom/event_cache_lock): failed to open stream: Permission denied in /var/www/html/core/class/event.class.php on line 37
0057|OK
0058|Check jeedom cmd...OK
