Je ne sais pas si c’est normal et/ou impactant mais j’ai des warnings dans le log http.error :
0037|[Mon Mar 24 00:01:12.883649 2025] [php:warn] [pid 146116:tid 146116] [client 192.168.1.41:53907] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0054|[Mon Mar 24 00:18:26.229494 2025] [php:warn] [pid 146855:tid 146855] [client 192.168.1.41:53929] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0097|[Mon Mar 24 08:19:44.734112 2025] [php:warn] [pid 252112:tid 252112] [client 192.168.1.31:54365] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/ajax/jeemate.ajax.php on line 31, referer: https://192.168.1.46:8299/index.php?v=d&m=jeemate&p=jeemate
0129|[Mon Mar 24 08:35:29.296157 2025] [php:warn] [pid 269242:tid 269242] [client 192.168.1.41:54170] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/filePUT.api.php on line 4
0141|[Mon Mar 24 08:42:35.664346 2025] [php:warn] [pid 277249:tid 277249] [client 192.168.1.41:54198] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0145|[Mon Mar 24 08:43:40.669028 2025] [php:warn] [pid 258172:tid 258172] [client 192.168.1.41:54199] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0147|[Mon Mar 24 08:45:33.091873 2025] [php:warn] [pid 280129:tid 280129] [client 192.168.1.41:54202] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0149|[Mon Mar 24 08:45:33.712963 2025] [php:warn] [pid 274968:tid 274968] [client 192.168.1.41:54204] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0169|[Mon Mar 24 09:01:17.922025 2025] [php:warn] [pid 274968:tid 274968] [client 192.168.1.31:54691] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/ajax/jeemate.ajax.php on line 31, referer: https://192.168.1.46:8299/index.php?v=d&m=jeemate&p=jeemate
0255|[Tue Mar 25 08:17:44.450825 2025] [php:warn] [pid 502114:tid 502114] [client 192.168.1.41:55175] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0256|[Tue Mar 25 08:17:44.483666 2025] [php:warn] [pid 601041:tid 601041] [client 192.168.1.41:55176] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0286|[Wed Mar 26 07:53:35.203179 2025] [php:warn] [pid 813169:tid 813169] [client 192.168.1.41:56999] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0287|[Wed Mar 26 07:53:35.409575 2025] [php:warn] [pid 813167:tid 813167] [client 192.168.1.41:57000] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0305|[Wed Mar 26 09:47:29.171687 2025] [php:warn] [pid 813872:tid 813872] [client 192.168.1.41:57175] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0306|[Wed Mar 26 09:47:29.204054 2025] [php:warn] [pid 908032:tid 908032] [client 192.168.1.41:57176] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0312|[Wed Mar 26 09:49:13.358782 2025] [php:warn] [pid 933677:tid 933677] [client 192.168.1.31:60073] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/ajax/jeemate.ajax.php on line 31, referer: https://192.168.1.46:8299/index.php?v=d&m=jeemate&p=jeemate
0373|[Wed Mar 26 10:12:54.629633 2025] [php:warn] [pid 933677:tid 933677] [client 192.168.1.41:57310] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/filePUT.api.php on line 4
0512|[Thu Mar 27 06:45:23.150859 2025] [php:warn] [pid 1150574:tid 1150574] [client 92.184.118.38:58030] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0516|[Thu Mar 27 06:45:23.357946 2025] [php:warn] [pid 1150203:tid 1150203] [client 92.184.118.98:58037] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0531|[Fri Mar 28 03:02:15.981630 2025] [php:warn] [pid 1440586:tid 1440586] [client 123.51.149.218:14424] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0532|[Fri Mar 28 03:02:16.850564 2025] [php:warn] [pid 1440426:tid 1440426] [client 123.51.149.218:10498] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0542|[Sat Mar 29 00:23:00.941084 2025] [php:warn] [pid 1733420:tid 1733420] [client 42.113.152.166:65153] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0543|[Sat Mar 29 00:23:01.819989 2025] [php:warn] [pid 1729064:tid 1729064] [client 42.113.152.166:40505] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0589|[Thu Apr 10 22:36:24.024172 2025] [php:warn] [pid 8487:tid 8487] [client 192.168.1.41:51627] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0590|[Thu Apr 10 22:36:24.071401 2025] [php:warn] [pid 68185:tid 68185] [client 192.168.1.41:51628] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0603|[Fri Apr 11 10:10:41.917158 2025] [php:warn] [pid 215898:tid 215898] [client 192.168.1.31:56465] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/ajax/jeemate.ajax.php on line 31, referer: https://192.168.1.46:8299/index.php?v=d&m=jeemate&p=jeemate
0604|[Fri Apr 11 10:11:48.885616 2025] [php:warn] [pid 198457:tid 198457] [client 192.168.1.41:51802] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0605|[Fri Apr 11 10:11:48.928589 2025] [php:warn] [pid 225328:tid 225328] [client 192.168.1.41:51803] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0622|[Fri Apr 11 10:25:18.361793 2025] [php:warn] [pid 228938:tid 228938] [client 192.168.1.41:51832] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/filePUT.api.php on line 4
0805|[Sat Apr 12 00:13:34.116738 2025] [php:warn] [pid 441572:tid 441572] [client 192.168.1.41:53049] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0806|[Sat Apr 12 00:13:34.228016 2025] [php:warn] [pid 441415:tid 441415] [client 192.168.1.41:53050] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0824|[Sat Apr 12 10:39:44.059272 2025] [php:warn] [pid 700:tid 700] [client 92.184.145.191:7683] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0825|[Sat Apr 12 10:39:44.059272 2025] [php:warn] [pid 1683:tid 1683] [client 92.184.145.186:22207] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0826|[Sat Apr 12 10:39:44.060455 2025] [php:warn] [pid 4713:tid 4713] [client 92.184.145.191:38888] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0827|[Sat Apr 12 10:39:44.060934 2025] [php:warn] [pid 11904:tid 11904] [client 92.184.145.191:57755] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
0828|[Sat Apr 12 10:39:44.218666 2025] [php:warn] [pid 696:tid 696] [client 92.184.145.191:49942] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0829|[Sat Apr 12 10:39:44.219454 2025] [php:warn] [pid 1608:tid 1608] [client 92.184.145.191:57736] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate_SSE.api.php on line 20
0857|[Sat Apr 12 15:38:03.381891 2025] [php:warn] [pid 107805:tid 107805] [client 192.168.1.31:51472] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/ajax/jeemate.ajax.php on line 31, referer: https://192.168.1.46:8299/index.php?v=d&m=jeemate&p=jeemate
1000|[Sun Apr 13 00:00:38.322590 2025] [php:warn] [pid 253957:tid 253957] [client 192.168.1.41:54405] PHP Warning: The use statement with non-compound name 'log' has no effect in /var/www/html/plugins/jeemate/core/api/jeemate.api.php on line 26
Cordialement
Jeedom 4.4.19
Debian 12
