J’ai des centaines de lignes par jour dans le log cron_execution
0460|PHP Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /var/www/html/plugins/wifilightV2/3rdparty/meross2.php on line 880
0461|PHP Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /var/www/html/plugins/wifilightV2/3rdparty/meross2.php on line 884
0462|PHP Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /var/www/html/plugins/wifilightV2/3rdparty/meross2.php on line 888
0463|PHP Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /var/www/html/plugins/wifilightV2/3rdparty/meross.php on line 251
Je sais que cela n’impacte pas le plugin puisque c’est un avertissement pour PHP 8 mais serait-il possible de corriger quand même car ça me gêne dans le debug d’autre chose ?
Un sujet qui en parle : php 7.4 - The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence - Stack Overflow
wifilightV2 : 2022-12-28 19:16:22
Jeedom : 4.3.15
Debian : 11.6
