voila mes log :
[2019-06-03 15:04:11][DEBUG] : login result={"data":{"user":{"id":3301,"email_address":"alexandre.orilia@gmail.com","first_name":"Alexandre","last_name":"Orilia","country_id":75,"language_id":47,"photo_id":6838,"marketing_opt_in":true,"terms_accepted":false,"weight_units":0,"version":"Mw==","created_at":"2017-12-31T20:45:14+00:00","updated_at":"2017-12-31T20:46:24+00:00","notifications":{"device_status":true,"animal_movement":true,"intruder_movements":true,"new_device_pet":true,"household_management":true,"photos":true,"low_battery":true,"curfew":true,"feeding_activity":true}},"token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczovL2FwcC5hcGkuc3VyZWh1Yi5pby9hcGkvYXV0aC9sb2dpbiIsImlhdCI6MTU1OTU2NzA1MSwiZXhwIjoxNTkxMDE2NjUxLCJuYmYiOjE1NTk1NjcwNTEsImp0aSI6Im4zVEpvaVh1QTFxR1ZmVXUiLCJzdWIiOjMzMDEsInBydiI6ImIzZWQzZGIzMzRjMmJjMzNiMTg0MjY5NDc1NTc1NmEzZmZiZjVhN2QiLCJkZXZpY2VfaWQiOiIzNzcyNjU3MTI5In0.MTE2XGCsZzhpgo8q_7JJdviKrqK0JiRlfwvB3Utu3Xs"}}
[2019-06-03 15:04:12][DEBUG] : Gethouseholds result : {"data":[{"id":2648,"name":"Maison Villefranche","share_code":"ukzAxuAr32Rl","timezone_id":349,"version":"MQ==","created_at":"2017-12-31T20:46:46+00:00","updated_at":"2017-12-31T20:46:46+00:00"}]}
[2019-06-03 15:04:12][DEBUG] : Found 1 households
[2019-06-03 15:04:12][DEBUG] : Household_config= Array ( [0] => Array ( [id] => 2648 [name] => Maison Villefranche ) )
[2019-06-03 15:04:12][DEBUG] : Household id= 2648
[2019-06-03 15:04:12][DEBUG] : Household name= Maison Villefranche
[2019-06-03 15:04:12][DEBUG] : getDevices result : {"data":[{"id":53859,"product_id":1,"household_id":2648,"name":"Maison Villefranche ","serial_number":"H001-0053859","mac_address":"0000D88039766FE6","version":"OTM=","created_at":"2017-06-30T16:27:31+00:00","updated_at":"2019-06-03T01:27:49+00:00"},{"id":195173,"parent_device_id":53859,"product_id":4,"household_id":2648,"name":"Nourriture Mitsuki","serial_number":"U001-0003117","mac_address":"2D0C00C0F9D5B370","index":0,"version":"ODU=","created_at":"2018-12-06T14:47:39+00:00","updated_at":"2019-06-03T01:27:49+00:00","pairing_at":"2019-04-24T19:36:53+00:00"}]}
[2019-06-03 15:04:12][DEBUG] : Device 0={"id":53859,"product_id":1,"household_id":2648,"name":"Maison Villefranche ","serial_number":"H001-0053859","mac_address":"0000D88039766FE6","version":"OTM=","created_at":"2017-06-30T16:27:31+00:00","updated_at":"2019-06-03T01:27:49+00:00"}
[2019-06-03 15:04:12][DEBUG] : debut de postSave
[2019-06-03 15:04:12][DEBUG] : Found config file for product id 1
[2019-06-03 15:04:12][DEBUG] : Products : { "name": "Hub", "configuration": { "id": "", "product_id": "1", "parent_device_id": "", "product_name": "Hub" }, "commands": [ { "name": "En ligne", "type": "info", "subtype": "binary", "isVisible": 0, "isHistorized": 1, "logicalId": "online", "display": { "generic_type": "GENERIC_INFO" }, "template":{ "dashboard" : "badge", "mobile" : "badge" } }, { "name": "Etat led", "type": "info", "subtype": "numeric", "isVisible": 0, "isHistorized": 1, "logicalId": "led_mode", "display": { "generic_type": "GENERIC_INFO" }, "template":{ "dashboard" : "badge", "mobile" : "badge" } }, { "name": "Mode led", "type": "action", "subtype": "select", "configuration" :{ "listValue" : "0|Eteint;1|Brillant;4|Atténué" }, "generic_type": "DONT", "isVisible": 1, "isHistorized": 0, "value" : "Etat led", "logicalId": "led_mode::#select#" } ] }
[2019-06-03 15:04:12][DEBUG] : Commande : {"name":"En ligne","type":"info","subtype":"binary","isVisible":0,"isHistorized":1,"logicalId":"online","display":{"generic_type":"GENERIC_INFO"},"template":{"dashboard":"badge","mobile":"badge"}}
[2019-06-03 15:04:12][DEBUG] : Commande : {"name":"Etat led","type":"info","subtype":"numeric","isVisible":0,"isHistorized":1,"logicalId":"led_mode","display":{"generic_type":"GENERIC_INFO"},"template":{"dashboard":"badge","mobile":"badge"}}
[2019-06-03 15:04:12][DEBUG] : Commande : {"name":"Mode led","type":"action","subtype":"select","configuration":{"listValue":"0|Eteint;1|Brillant;4|Att\u00e9nu\u00e9"},"generic_type":"DONT","isVisible":1,"isHistorized":0,"value":"Etat led","logicalId":"led_mode::#select#"}
[2019-06-03 15:04:12][DEBUG] : applyData Array ( [id] => 53859 [product_id] => 1 [household_id] => 2648 [name] => Maison Villefranche [serial_number] => H001-0053859 [mac_address] => 0000D88039766FE6 [version] => OTM= [created_at] => 2017-06-30T16:27:31+00:00 [updated_at] => 2019-06-03T01:27:49+00:00 )
[2019-06-03 15:04:12][DEBUG] : [{"_cmds":{"dev.online..":{},"dev.led_mode..":{},"dev.led_mode::#select#..":{}}}]
[2019-06-03 15:04:12][DEBUG] : Device 1={"id":195173,"parent_device_id":53859,"product_id":4,"household_id":2648,"name":"Nourriture Mitsuki","serial_number":"U001-0003117","mac_address":"2D0C00C0F9D5B370","index":0,"version":"ODU=","created_at":"2018-12-06T14:47:39+00:00","updated_at":"2019-06-03T01:27:49+00:00","pairing_at":"2019-04-24T19:36:53+00:00"}
[2019-06-03 15:04:12][DEBUG] : Found config file for product id 4
[2019-06-03 15:04:12][DEBUG] : Products : { "name": "Distributeur", "configuration": { "id": "", "product_id": "4", "parent_device_id": "", "product_name": "Distributeur de nourriture Connect" }, "commands": [ { "name": "En ligne", "type": "info", "subtype": "binary", "isVisible": 1, "isHistorized": 1, "logicalId": "online", "generic_type": "GENERIC_INFO", "template":{ "dashboard" : "line", "mobile" : "line" } } ] }
[2019-06-03 15:04:12][DEBUG] : Commande : {"name":"En ligne","type":"info","subtype":"binary","isVisible":1,"isHistorized":1,"logicalId":"online","generic_type":"GENERIC_INFO","template":{"dashboard":"line","mobile":"line"}}
[2019-06-03 15:04:12][DEBUG] : applyData Array ( [id] => 195173 [parent_device_id] => 53859 [product_id] => 4 [household_id] => 2648 [name] => Nourriture Mitsuki [serial_number] => U001-0003117 [mac_address] => 2D0C00C0F9D5B370 [index] => 0 [version] => ODU= [created_at] => 2018-12-06T14:47:39+00:00 [updated_at] => 2019-06-03T01:27:49+00:00 [pairing_at] => 2019-04-24T19:36:53+00:00 )
[2019-06-03 15:04:12][DEBUG] : [{"_cmds":{"dev.online..":{},"dev.led_mode..":{},"dev.led_mode::#select#..":{}}},{"_cmds":{"dev.online..":{}}}]
[2019-06-03 15:04:13][DEBUG] : getPets result : {"data":[{"id":47463,"name":"Mitsuki","gender":0,"weight":"9","comments":"","household_id":2648,"breed_id":190,"food_type_id":2,"photo_id":55397,"species_id":2,"tag_id":39162,"version":"Ng==","created_at":"2019-04-26T17:19:05+00:00","updated_at":"2019-04-26T17:24:10+00:00"}]}
[2019-06-03 15:04:13][DEBUG] : Pet 0={"id":47463,"name":"Mitsuki","gender":0,"weight":"9","comments":"","household_id":2648,"breed_id":190,"food_type_id":2,"photo_id":55397,"species_id":2,"tag_id":39162,"version":"Ng==","created_at":"2019-04-26T17:19:05+00:00","updated_at":"2019-04-26T17:24:10+00:00"}
[2019-06-03 15:04:13][DEBUG] : Petfull 0={"id":47463,"name":"Mitsuki","gender":0,"weight":"9","comments":"","household_id":2648,"breed_id":190,"food_type_id":2,"photo_id":55397,"species_id":2,"tag_id":39162,"version":"Ng==","created_at":"2019-04-26T17:19:05+00:00","updated_at":"2019-04-26T17:24:10+00:00","breed":{"id":190,"name":"Spitz japonais","species_id":2,"version":"MA=="},"photo":{"id":55397,"location":"https:\/\/surehub.s3.amazonaws.com\/user-photos\/thm\/3301\/LnbvgCu08sTKPJ2iFv6UVN0t1ZwXeHZiQRqXKTeUBc.jpg","uploading_user_id":3301,"version":"MA==","created_at":"2019-04-26T17:23:20+00:00","updated_at":"2019-04-26T17:23:20+00:00"},"species":{"id":2,"name":"Chien","version":"MA=="},"tag":{"id":39162,"tag":"0112bafa9c","version":"MQ==","created_at":"2019-04-26T17:19:05+00:00","updated_at":"2019-04-26T17:19:05+00:00","supported_product_ids":[3,4,6]}}
[2019-06-03 15:04:13][DEBUG] : debut de postSave
[2019-06-03 15:04:13][DEBUG] : [{"_cmds":{"dev.online..":{},"dev.led_mode..":{},"dev.led_mode::#select#..":{}}},{"_cmds":{"dev.online..":{}}},{"_cmds":{"pet.position..":{},"pet.setposition::#select#..":{}}}]```
