Bonjour.
Contexte : Jeedom stable 4.3.17 debian 11
Je teste la béta du plugin et je constate la présence d’un message dans la log du backup de jeedom
Plugin meteofrance - the following subfolder will be excluded from the backup: data/*.json
0070|[START BACKUP]
0071|***************Start of Jeedom backup at 2023-06-24 03:32:01***************
0072|Send begin backup event...OK
0073|Checking files rights...
0074|OK
0075|Checking database...OK
0076|Backing up database...OK
0077|Cache persistence:
0078|OK
0079|Creating archive...
0080|Plugin meteofrance - the following subfolder will be excluded from the backup: data/*.json
0081|OK
0082|Cleaning old backup...OK
0083|Send backup Samba...Delete backup too old : {"filename":"backup-DMJ_Jeedom_PROD-4.3.17-2023-06-17-03h32.tar.gz","size":"135037735","datetime":"2023-06-17 03:32:21"}OK
0084|Limiting backup size to 1000 Mb...
0085|Delete: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_PROD-4.3.17-2023-06-17-03h32.tar.gz
0086|OK
0087|Backup name: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_PROD-4.3.17-2023-06-24-03h32.tar.gz
0088|Checking files rights...OK
0089|Send end backup event...OK
0090|Backup operation duration: 25s
0091|***************Jeedom backup end***************
0092|[END BACKUP SUCCESS]
0
Voilà.
