[2020-10-04 20:27:15][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:27:15][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:27:15][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2400}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":62},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 27 minutes 51 secondes","uptime_val":4606071,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:27:15][DEBUG] : └─────────
[2020-10-04 20:29:07][DEBUG] : ================= ORDRE DE LA CREATION DES EQUIPEMENTS STANDARDS ==================
[2020-10-04 20:29:07][DEBUG] : ================= Air Média
[2020-10-04 20:29:07][DEBUG] : ================= Freebox Débits / 4G / Fibre / xdsl
[2020-10-04 20:29:07][DEBUG] : ================= Disque Dur
[2020-10-04 20:29:07][DEBUG] : ================= Téléphone
[2020-10-04 20:29:07][DEBUG] : ================= Système
[2020-10-04 20:29:07][DEBUG] : ================= Appareils connectés
[2020-10-04 20:29:07][DEBUG] : ================= Appareils connectés Wifi Invité
[2020-10-04 20:29:07][DEBUG] : ================= Wifi
[2020-10-04 20:29:07][DEBUG] : ================= ENSEMBLE DES PLAYERS SOUS TENSION
[2020-10-04 20:29:07][DEBUG] : ====================================================================================
[2020-10-04 20:29:07][DEBUG] : ┌───────── Ajout des commandes : Air Média
[2020-10-04 20:29:07][DEBUG] : │ Application des Widgets ou Icônes pour le core V3
[2020-10-04 20:29:07][DEBUG] : │ Name: Air Média -- LogicalID : airmedia -- catégorie : multimedia -- Equipement Type : -- Logical ID Equip : -- Cron : */5 * * * * -- Objet :
[2020-10-04 20:29:08][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:29:08][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:29:08][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:29:08][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2403}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":62},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 29 minutes 44 secondes","uptime_val":4606184,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:29:08][DEBUG] : └─────────
[2020-10-04 20:29:56][DEBUG] : ================= ORDRE DE LA CREATION DES EQUIPEMENTS STANDARDS ==================
[2020-10-04 20:29:56][DEBUG] : ================= Air Média
[2020-10-04 20:29:56][DEBUG] : ================= Freebox Débits / 4G / Fibre / xdsl
[2020-10-04 20:29:56][DEBUG] : ================= Disque Dur
[2020-10-04 20:29:56][DEBUG] : ================= Téléphone
[2020-10-04 20:29:56][DEBUG] : ================= Système
[2020-10-04 20:29:56][DEBUG] : ================= Appareils connectés
[2020-10-04 20:29:56][DEBUG] : ================= Appareils connectés Wifi Invité
[2020-10-04 20:29:56][DEBUG] : ================= Wifi
[2020-10-04 20:29:56][DEBUG] : ================= ENSEMBLE DES PLAYERS SOUS TENSION
[2020-10-04 20:29:56][DEBUG] : ====================================================================================
[2020-10-04 20:29:56][DEBUG] : ┌───────── Ajout des commandes : Air Média
[2020-10-04 20:29:56][DEBUG] : │ Application des Widgets ou Icônes pour le core V3
[2020-10-04 20:29:56][DEBUG] : │ Name: Air Média -- LogicalID : airmedia -- catégorie : multimedia -- Equipement Type : -- Logical ID Equip : -- Cron : */5 * * * * -- Objet :
[2020-10-04 20:29:57][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:29:57][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:29:57][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:29:57][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2403}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":62},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 30 minutes 33 secondes","uptime_val":4606233,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:29:57][DEBUG] : └─────────
[2020-10-04 20:30:06][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2020-10-04 20:30:06][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:30:06][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:30:06][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:30:06][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:30:06][DEBUG] : └─────────
[2020-10-04 20:30:06][DEBUG] : ================= CRON pour l'actualisation de : Home Adapters ==================
[2020-10-04 20:30:06][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2020-10-04 20:30:06][DEBUG] : │──────────> Récupération des valeurs du Système
[2020-10-04 20:30:06][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:30:06][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2405}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":62},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 30 minutes 42 secondes","uptime_val":4606242,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:30:07][DEBUG] : ================= CRON pour l'actualisation de : Téléchargements ==================
[2020-10-04 20:30:07][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:30:07][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/downloads/stats/(null)
[2020-10-04 20:30:07][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":0,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":0,"nb_tasks_stopping":0,"nzb_config_status":{"status":"ok","error":"none"},"conn_ready":true,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":0,"nb_tasks_seeding":0,"nb_tasks_error":0,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":0,"nb_rss":0,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":false}}
[2020-10-04 20:30:07][DEBUG] : └─────────
[2020-10-04 20:30:07][DEBUG] : ================= CRON pour l'actualisation de : Wifi ==================
[2020-10-04 20:30:07][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2020-10-04 20:30:07][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2020-10-04 20:30:07][DEBUG] : >───────── Traitement de la Mise à jour de wifi/config avec la valeur : 1
[2020-10-04 20:30:07][DEBUG] : ================= CRON pour l'actualisation de : Freebox Débits ==================
[2020-10-04 20:31:25][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:31:25][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:31:25][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:31:25][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2403}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":63},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 32 minutes 1 seconde","uptime_val":4606321,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:31:25][DEBUG] : └─────────
[2020-10-04 20:31:40][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:31:40][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:31:40][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:31:40][DEBUG] : └─────────
[2020-10-04 20:31:41][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:31:41][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:31:41][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:31:41][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2405}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":63},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 32 minutes 17 secondes","uptime_val":4606337,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:31:41][DEBUG] : └─────────
[2020-10-04 20:31:59][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:31:59][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:31:59][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:31:59][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2406}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":62},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 32 minutes 35 secondes","uptime_val":4606355,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:31:59][DEBUG] : └─────────
[2020-10-04 20:32:04][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:32:04][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:32:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:32:04][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:32:04][DEBUG] : └─────────
[2020-10-04 20:32:13][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:32:13][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:32:13][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:32:13][DEBUG] : └─────────
[2020-10-04 20:32:14][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-10-04 20:32:14][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:32:14][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:32:14][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2405}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":63},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 32 minutes 50 secondes","uptime_val":4606370,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:32:14][DEBUG] : └─────────
[2020-10-04 20:33:04][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:33:04][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:33:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:33:04][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:33:04][DEBUG] : └─────────
[2020-10-04 20:34:04][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:34:04][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:34:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:34:04][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:34:04][DEBUG] : └─────────
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Home Adapters ==================
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2020-10-04 20:35:05][DEBUG] : │──────────> Récupération des valeurs du Système
[2020-10-04 20:35:05][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"68:A3:78:C3:63:3D","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r2)","customer_hdd_slots":0,"name":"fbxgw-r2\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2406}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":42},{"id":"temp_sw","name":"Température Switch","value":52},{"id":"temp_cpum","name":"Température CPU M","value":63},{"id":"temp_cpub","name":"Température CPU B","value":62}],"board_name":"fbxgw2r","disk_status":"active","uptime":"53 jours 7 heures 35 minutes 41 secondes","uptime_val":4606541,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"762600A163701510","firmware_version":"4.2.3"}}
[2020-10-04 20:35:05][DEBUG] : └─────────
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Téléchargements ==================
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/downloads/stats/(null)
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":0,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":0,"nb_tasks_stopping":0,"nzb_config_status":{"status":"ok","error":"none"},"conn_ready":true,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":0,"nb_tasks_seeding":0,"nb_tasks_error":0,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":0,"nb_rss":0,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":false}}
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Wifi ==================
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2020-10-04 20:35:05][DEBUG] : >───────── Traitement de la Mise à jour de wifi/config avec la valeur : 1
[2020-10-04 20:35:05][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:35:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:35:06][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:35:06][DEBUG] : └─────────
[2020-10-04 20:35:06][DEBUG] : ================= CRON pour l'actualisation de : Freebox Débits ==================
[2020-10-04 20:36:04][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:36:04][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:36:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:36:04][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:36:04][DEBUG] : └─────────
[2020-10-04 20:37:04][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:37:04][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:37:04][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:37:04][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:37:04][DEBUG] : └─────────
[2020-10-04 20:38:03][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:38:03][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:38:03][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:38:03][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:38:03][DEBUG] : └─────────
[2020-10-04 20:39:05][DEBUG] : ================= CRON pour l'actualisation de : Appareils connectés Wifi Invité ==================
[2020-10-04 20:39:05][DEBUG] : ┌───────── Début de Mise à jour
[2020-10-04 20:39:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/lan/browser/wifiguest(null)
[2020-10-04 20:39:05][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2020-10-04 20:39:05][DEBUG] : └─────────
