Et le début du log qui ne passait pas :
[2024-12-01 03:20:55.308][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-97", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 03:20:55.309][DEBUG] : Data found
[2024-12-01 03:20:55.310][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-97', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 03:20:55.310][DEBUG] : frame found
[2024-12-01 03:20:55.311][DEBUG] : Received a X2d frame
[2024-12-01 03:20:55.311][DEBUG] : type11
[2024-12-01 03:20:55.311][DEBUG] : Device with id fb996900 is not included
[2024-12-01 05:09:49.939][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-95", "floorNoise": "-104", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 05:09:49.940][DEBUG] : Data found
[2024-12-01 05:09:49.940][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-95', 'floorNoise': '-104', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 05:09:49.941][DEBUG] : frame found
[2024-12-01 05:09:49.941][DEBUG] : Received a X2d frame
[2024-12-01 05:09:49.942][DEBUG] : type11
[2024-12-01 05:09:49.942][DEBUG] : Device with id fb996900 is not included
[2024-12-01 05:09:56.063][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-97", "floorNoise": "-104", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 05:09:56.064][DEBUG] : Data found
[2024-12-01 05:09:56.065][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-97', 'floorNoise': '-104', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 05:09:56.067][DEBUG] : frame found
[2024-12-01 05:09:56.067][DEBUG] : Received a X2d frame
[2024-12-01 05:09:56.068][DEBUG] : type11
[2024-12-01 05:09:56.069][DEBUG] : Device with id fb996900 is not included
[2024-12-01 06:58:44.910][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 06:58:44.911][DEBUG] : Data found
[2024-12-01 06:58:44.912][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 06:58:44.912][DEBUG] : frame found
[2024-12-01 06:58:44.913][DEBUG] : Received a X2d frame
[2024-12-01 06:58:44.913][DEBUG] : type11
[2024-12-01 06:58:44.913][DEBUG] : Device with id fb996900 is not included
[2024-12-01 06:58:51.141][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 06:58:51.141][DEBUG] : Data found
[2024-12-01 06:58:51.142][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 06:58:51.142][DEBUG] : frame found
[2024-12-01 06:58:51.143][DEBUG] : Received a X2d frame
[2024-12-01 06:58:51.143][DEBUG] : type11
[2024-12-01 06:58:51.144][DEBUG] : Device with id fb996900 is not included
[2024-12-01 08:01:03.162][DEBUG] : Client connected to [127.0.0.1:54830]
[2024-12-01 08:01:03.163][DEBUG] : Message read from socket: b'{"apikey":"ZjU5yFuxgCVmVUeCmtTGiCeonEUcrN1Q1MaQAYYMEVPgpV1TRiKlHBUOftfP2HDa","cmd":"send","id":"17","action":"ON","type":"RTS","qualifier":"0"}'
[2024-12-01 08:01:03.164][DEBUG] : Client disconnected from [127.0.0.1:54830]
[2024-12-01 08:01:03.191][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-01 08:01:03.192][DEBUG] : Commande SEND
[2024-12-01 08:01:03.193][DEBUG] : ON ID 17 RTS
[2024-12-01 08:01:03.193][DEBUG] : Sending message ZIA++ON ID 17 RTS
[2024-12-01 08:01:03.305][DEBUG] : Client connected to [127.0.0.1:54834]
[2024-12-01 08:01:03.305][DEBUG] : Message read from socket: b'{"apikey":"ZjU5yFuxgCVmVUeCmtTGiCeonEUcrN1Q1MaQAYYMEVPgpV1TRiKlHBUOftfP2HDa","cmd":"send","id":"19","action":"ON","type":"RTS","qualifier":"0"}'
[2024-12-01 08:01:03.306][DEBUG] : Client disconnected from [127.0.0.1:54834]
[2024-12-01 08:01:03.395][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-01 08:01:03.396][DEBUG] : Commande SEND
[2024-12-01 08:01:03.397][DEBUG] : ON ID 19 RTS
[2024-12-01 08:01:03.397][DEBUG] : Sending message ZIA++ON ID 19 RTS
[2024-12-01 08:47:38.188][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 08:47:38.189][DEBUG] : Data found
[2024-12-01 08:47:38.189][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 08:47:38.190][DEBUG] : frame found
[2024-12-01 08:47:38.190][DEBUG] : Received a X2d frame
[2024-12-01 08:47:38.191][DEBUG] : type11
[2024-12-01 08:47:38.191][DEBUG] : Device with id fb996900 is not included
[2024-12-01 08:47:45.595][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-95", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 08:47:45.596][DEBUG] : Data found
[2024-12-01 08:47:45.596][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-95', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 08:47:45.597][DEBUG] : frame found
[2024-12-01 08:47:45.597][DEBUG] : Received a X2d frame
[2024-12-01 08:47:45.598][DEBUG] : type11
[2024-12-01 08:47:45.598][DEBUG] : Device with id fb996900 is not included
[2024-12-01 09:22:51.622][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-85", "floorNoise": "-101", "rfQuality": "4", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "2657104", "qualifier": "7", "qualifierMeaning": { "flags": ["Up/On"]}}}}
[2024-12-01 09:22:51.622][DEBUG] : Data found
[2024-12-01 09:22:51.623][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-85', 'floorNoise': '-101', 'rfQuality': '4', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '2657104', 'qualifier': '7', 'qualifierMeaning': {'flags': ['Up/On']}}}}
[2024-12-01 09:22:51.624][DEBUG] : frame found
[2024-12-01 09:22:51.624][DEBUG] : Received a RTS frame
[2024-12-01 09:22:51.625][DEBUG] : type3
[2024-12-01 09:22:51.625][DEBUG] : Device with id 2657104 is not included
[2024-12-01 10:36:29.835][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 10:36:29.835][DEBUG] : Data found
[2024-12-01 10:36:29.836][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 10:36:29.837][DEBUG] : frame found
[2024-12-01 10:36:29.837][DEBUG] : Received a X2d frame
[2024-12-01 10:36:29.838][DEBUG] : type11
[2024-12-01 10:36:29.838][DEBUG] : Device with id fb996900 is not included
[2024-12-01 10:36:37.309][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 10:36:37.309][DEBUG] : Data found
[2024-12-01 10:36:37.310][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 10:36:37.310][DEBUG] : frame found
[2024-12-01 10:36:37.311][DEBUG] : Received a X2d frame
[2024-12-01 10:36:37.312][DEBUG] : type11
[2024-12-01 10:36:37.312][DEBUG] : Device with id fb996900 is not included
[2024-12-01 10:56:34.861][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-102", "rfQuality": "5", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "9702476", "qualifier": "9", "qualifierMeaning": { "flags": [""]}}}}
[2024-12-01 10:56:34.861][DEBUG] : Data found
[2024-12-01 10:56:34.862][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-79', 'floorNoise': '-102', 'rfQuality': '5', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '9702476', 'qualifier': '9', 'qualifierMeaning': {'flags': ['']}}}}
[2024-12-01 10:56:34.862][DEBUG] : frame found
[2024-12-01 10:56:34.863][DEBUG] : Received a RTS frame
[2024-12-01 10:56:34.863][DEBUG] : type3
[2024-12-01 10:56:34.864][DEBUG] : Device with id 9702476 is not included
[2024-12-01 11:23:52.389][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-83", "floorNoise": "-101", "rfQuality": "4", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "2128696704", "subTypeMeaning": "OFF"}}}
[2024-12-01 11:23:52.389][DEBUG] : Data found
[2024-12-01 11:23:52.390][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-83', 'floorNoise': '-101', 'rfQuality': '4', 'protocol': '4', 'protocolMeaning': 'CHACON', 'infoType': '1', 'frequency': '433920'}, 'infos': {'subType': '0', 'id': '2128696704', 'subTypeMeaning': 'OFF'}}}
[2024-12-01 11:23:52.390][DEBUG] : frame found
[2024-12-01 11:23:52.391][DEBUG] : Received a Chacon frame
[2024-12-01 11:23:52.391][DEBUG] : type1
[2024-12-01 11:23:52.392][DEBUG] : Device with id 7ee15580 is not included
[2024-12-01 11:23:53.975][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-78", "floorNoise": "-102", "rfQuality": "6", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "0", "id": "2128696704", "subTypeMeaning": "OFF"}}}
[2024-12-01 11:23:53.976][DEBUG] : Data found
[2024-12-01 11:23:53.977][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-78', 'floorNoise': '-102', 'rfQuality': '6', 'protocol': '4', 'protocolMeaning': 'CHACON', 'infoType': '1', 'frequency': '433920'}, 'infos': {'subType': '0', 'id': '2128696704', 'subTypeMeaning': 'OFF'}}}
[2024-12-01 11:23:53.977][DEBUG] : frame found
[2024-12-01 11:23:53.977][DEBUG] : Received a Chacon frame
[2024-12-01 11:23:53.978][DEBUG] : type1
[2024-12-01 11:23:53.978][DEBUG] : Device with id 7ee15580 is not included
[2024-12-01 11:23:56.473][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-75", "floorNoise": "-101", "rfQuality": "6", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "2128696704", "subTypeMeaning": "ON"}}}
[2024-12-01 11:23:56.473][DEBUG] : Data found
[2024-12-01 11:23:56.474][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-75', 'floorNoise': '-101', 'rfQuality': '6', 'protocol': '4', 'protocolMeaning': 'CHACON', 'infoType': '1', 'frequency': '433920'}, 'infos': {'subType': '1', 'id': '2128696704', 'subTypeMeaning': 'ON'}}}
[2024-12-01 11:23:56.474][DEBUG] : frame found
[2024-12-01 11:23:56.475][DEBUG] : Received a Chacon frame
[2024-12-01 11:23:56.475][DEBUG] : type1
[2024-12-01 11:23:56.476][DEBUG] : Device with id 7ee15580 is not included
[2024-12-01 11:23:58.693][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-75", "floorNoise": "-101", "rfQuality": "6", "protocol": "4", "protocolMeaning": "CHACON", "infoType": "1", "frequency": "433920"},"infos": {"subType": "1", "id": "2128696704", "subTypeMeaning": "ON"}}}
[2024-12-01 11:23:58.693][DEBUG] : Data found
[2024-12-01 11:23:58.694][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-75', 'floorNoise': '-101', 'rfQuality': '6', 'protocol': '4', 'protocolMeaning': 'CHACON', 'infoType': '1', 'frequency': '433920'}, 'infos': {'subType': '1', 'id': '2128696704', 'subTypeMeaning': 'ON'}}}
[2024-12-01 11:23:58.695][DEBUG] : frame found
[2024-12-01 11:23:58.695][DEBUG] : Received a Chacon frame
[2024-12-01 11:23:58.695][DEBUG] : type1
[2024-12-01 11:23:58.696][DEBUG] : Device with id 7ee15580 is not included
[2024-12-01 11:29:26.009][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-91", "floorNoise": "-101", "rfQuality": "2", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "5954381", "qualifier": "1", "qualifierMeaning": { "flags": ["Down/Off"]}}}}
[2024-12-01 11:29:26.009][DEBUG] : Data found
[2024-12-01 11:29:26.010][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-91', 'floorNoise': '-101', 'rfQuality': '2', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '5954381', 'qualifier': '1', 'qualifierMeaning': {'flags': ['Down/Off']}}}}
[2024-12-01 11:29:26.010][DEBUG] : frame found
[2024-12-01 11:29:26.011][DEBUG] : Received a RTS frame
[2024-12-01 11:29:26.011][DEBUG] : type3
[2024-12-01 11:29:26.012][DEBUG] : Device with id 5954381 is not included
[2024-12-01 11:39:27.596][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-88", "floorNoise": "-102", "rfQuality": "3", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "5954381", "qualifier": "7", "qualifierMeaning": { "flags": ["Up/On"]}}}}
[2024-12-01 11:39:27.596][DEBUG] : Data found
[2024-12-01 11:39:27.597][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-88', 'floorNoise': '-102', 'rfQuality': '3', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '5954381', 'qualifier': '7', 'qualifierMeaning': {'flags': ['Up/On']}}}}
[2024-12-01 11:39:27.597][DEBUG] : frame found
[2024-12-01 11:39:27.598][DEBUG] : Received a RTS frame
[2024-12-01 11:39:27.598][DEBUG] : type3
[2024-12-01 11:39:27.598][DEBUG] : Device with id 5954381 is not included
[2024-12-01 12:25:20.418][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 12:25:20.419][DEBUG] : Data found
[2024-12-01 12:25:20.420][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 12:25:20.420][DEBUG] : frame found
[2024-12-01 12:25:20.420][DEBUG] : Received a X2d frame
[2024-12-01 12:25:20.421][DEBUG] : type11
[2024-12-01 12:25:20.421][DEBUG] : Device with id fb996900 is not included
[2024-12-01 12:25:29.205][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-95", "floorNoise": "-104", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 12:25:29.206][DEBUG] : Data found
[2024-12-01 12:25:29.207][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-95', 'floorNoise': '-104', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 12:25:29.207][DEBUG] : frame found
[2024-12-01 12:25:29.207][DEBUG] : Received a X2d frame
[2024-12-01 12:25:29.208][DEBUG] : type11
[2024-12-01 12:25:29.208][DEBUG] : Device with id fb996900 is not included
[2024-12-01 14:14:09.963][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 14:14:09.964][DEBUG] : Data found
[2024-12-01 14:14:09.965][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 14:14:09.966][DEBUG] : frame found
[2024-12-01 14:14:09.967][DEBUG] : Received a X2d frame
[2024-12-01 14:14:09.968][DEBUG] : type11
[2024-12-01 14:14:09.969][DEBUG] : Device with id fb996900 is not included
[2024-12-01 14:14:13.673][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-104", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 14:14:13.674][DEBUG] : Data found
[2024-12-01 14:14:13.674][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-96', 'floorNoise': '-104', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 14:14:13.675][DEBUG] : frame found
[2024-12-01 14:14:13.675][DEBUG] : Received a X2d frame
[2024-12-01 14:14:13.676][DEBUG] : type11
[2024-12-01 14:14:13.676][DEBUG] : Device with id fb996900 is not included
[2024-12-01 15:38:16.706][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-84", "floorNoise": "-101", "rfQuality": "4", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "9702476", "qualifier": "3", "qualifierMeaning": { "flags": [""]}}}}
[2024-12-01 15:38:16.706][DEBUG] : Data found
[2024-12-01 15:38:16.707][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-84', 'floorNoise': '-101', 'rfQuality': '4', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '9702476', 'qualifier': '3', 'qualifierMeaning': {'flags': ['']}}}}
[2024-12-01 15:38:16.707][DEBUG] : frame found
[2024-12-01 15:38:16.708][DEBUG] : Received a RTS frame
[2024-12-01 15:38:16.708][DEBUG] : type3
[2024-12-01 15:38:16.709][DEBUG] : Device with id 9702476 is not included
[2024-12-01 15:38:17.115][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-87", "floorNoise": "-101", "rfQuality": "3", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "9702476", "qualifier": "10", "qualifierMeaning": { "flags": [""]}}}}
[2024-12-01 15:38:17.116][DEBUG] : Data found
[2024-12-01 15:38:17.116][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '0', 'rfLevel': '-87', 'floorNoise': '-101', 'rfQuality': '3', 'protocol': '9', 'protocolMeaning': 'RTS', 'infoType': '3', 'frequency': '433920'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Shutter', 'id': '9702476', 'qualifier': '10', 'qualifierMeaning': {'flags': ['']}}}}
[2024-12-01 15:38:17.117][DEBUG] : frame found
[2024-12-01 15:38:17.117][DEBUG] : Received a RTS frame
[2024-12-01 15:38:17.117][DEBUG] : type3
[2024-12-01 15:38:17.118][DEBUG] : Device with id 9702476 is not included
[2024-12-01 16:02:55.943][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-95", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 16:02:55.943][DEBUG] : Data found
[2024-12-01 16:02:55.944][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-95', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 16:02:55.945][DEBUG] : frame found
[2024-12-01 16:02:55.945][DEBUG] : Received a X2d frame
[2024-12-01 16:02:55.945][DEBUG] : type11
[2024-12-01 16:02:55.946][DEBUG] : Device with id fb996900 is not included
[2024-12-01 16:03:00.920][DEBUG] : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-95", "floorNoise": "-105", "rfQuality": "2", "protocol": "8", "protocolMeaning": "X2D", "infoType": "11", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4221135104", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}, "d0": "33789", "d1": "0", "d2": "0", "d3": "0"}}}
[2024-12-01 16:03:00.920][DEBUG] : Data found
[2024-12-01 16:03:00.921][DEBUG] : {'frame': {'header': {'frameType': '0', 'cluster': '0', 'dataFlag': '1', 'rfLevel': '-95', 'floorNoise': '-105', 'rfQuality': '2', 'protocol': '8', 'protocolMeaning': 'X2D', 'infoType': '11', 'frequency': '868350'}, 'infos': {'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'id': '4221135104', 'qualifier': '8', 'qualifierMeaning': {'flags': ['Supervisor/Alive']}, 'd0': '33789', 'd1': '0', 'd2': '0', 'd3': '0'}}}
[2024-12-01 16:03:00.921][DEBUG] : frame found
[2024-12-01 16:03:00.922][DEBUG] : Received a X2d frame
[2024-12-01 16:03:00.923][DEBUG] : type11
[2024-12-01 16:03:00.923][DEBUG] : Device with id fb996900 is not included
[2024-12-01 16:03:04.890][DEBUG] : Client connected to [127.0.0.1:53738]
[2024-12-01 16:03:04.891][DEBUG] : Message read from socket: b'{"apikey":"ZjU5yFuxgCVmVUeCmtTGiCeonEUcrN1Q1MaQAYYMEVPgpV1TRiKlHBUOftfP2HDa","cmd":"send","id":"17","action":"OFF","type":"RTS","qualifier":"0"}'
[2024-12-01 16:03:04.892][DEBUG] : Client disconnected from [127.0.0.1:53738]
[2024-12-01 16:03:04.931][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-01 16:03:04.932][DEBUG] : Commande SEND
[2024-12-01 16:03:04.933][DEBUG] : OFF ID 17 RTS
[2024-12-01 16:03:04.934][DEBUG] : Sending message ZIA++OFF ID 17 RTS
[2024-12-01 16:03:04.947][DEBUG] : Client connected to [127.0.0.1:53740]
[2024-12-01 16:03:04.948][DEBUG] : Message read from socket: b'{"apikey":"ZjU5yFuxgCVmVUeCmtTGiCeonEUcrN1Q1MaQAYYMEVPgpV1TRiKlHBUOftfP2HDa","cmd":"send","id":"19","action":"OFF","type":"RTS","qualifier":"0"}'
[2024-12-01 16:03:04.948][DEBUG] : Client disconnected from [127.0.0.1:53740]
[2024-12-01 16:03:05.135][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-01 16:03:05.136][DEBUG] : Commande SEND
[2024-12-01 16:03:05.137][DEBUG] : OFF ID 19 RTS
[2024-12-01 16:03:05.138][DEBUG] : Sending message ZIA++OFF ID 19 RTS
