Bonjour Le plugin ne semble pas reconnaitre ma Pergola IO
Est-ce un problème connu ou est-ce spécifique a ma configuration ?
[2024-01-12 07:59:25] : Full Mode : new Device command created
[2024-01-12 07:59:25] : 125 Device command(s) created
[2024-01-12 07:59:25] : Device found #6
[2024-01-12 07:59:25] : ± Method -+ GetFileContent::fileGetContents - Succeeded to read file (/var/www/html/plugins/TaHomaLocal/plugin_info/info.json)
[2024-01-12 07:59:25] : ±+ TaHomaLocal::checkEquipmentIsRegistered method
[2024-01-12 07:59:25] : Found equipment name: « PERGOLA BOX IO »
[2024-01-12 07:59:25] : ± Method -+ GetFileContent::fileGetContents - File not found (/var/www/html/plugins/TaHomaLocal/core/class/UDF/…/…/…/data/components/Pergola/ioSimpleBioclimaticPergolaIOComponent.toml)
[2024-01-12 07:59:25] : New unknown component detected …
[2024-01-12 07:59:25] : ± Method -+ GetFileContent::fileGetContents - Succeeded to read file (/var/www/html/plugins/TaHomaLocal/data/json/configInfo.json)
