Suite installation du plugin Jeedore (beta ou stable), impossible de synchroniser les équipements.
Dépendance installé (j ai relancé l installation)
Adress Mac renseigné (sans les : )
Mot passe simple
Model Local + IP renseigné mais pb identique en mode distant
IP Jeedom en Localhost:80
02/09/2023 21:50:39 - Hello DeltaDore! <3
02/09/2023 21:50:39 - Unix 4.19.0.23
02/09/2023 21:50:39 - pid: 15523
02/09/2023 21:50:39 - pidFilename: /tmp/jeedom/jeedore/jeedoredaemon.pid
02/09/2023 21:50:39 - Starting with 15523
02/09/2023 21:50:40 - Jeedore Daemon is starting in local network mode...
02/09/2023 21:50:40 - Websocket connection initialization....
02/09/2023 21:50:40 - Connecting to '192.168.0.6'
02/09/2023 21:50:42 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
02/09/2023 21:50:42 - Jeedore Daemon connection has been closed...
02/09/2023 21:50:42 - Connection to DeltaDore server has been closed...
02/09/2023 21:50:42 - Server started. Listening to TCP clients at 127.0.0.1:13666
02/09/2023 21:50:42 - Starting timer Info
02/09/2023 21:50:51 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetEqLogic'...
02/09/2023 21:50:51 - Websocket connection initialization....
02/09/2023 21:50:51 - Connecting to '192.168.0.6'
02/09/2023 21:50:54 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
02/09/2023 21:50:54 - Jeedore Daemon connection has been closed...
02/09/2023 21:50:54 - Connection to DeltaDore server has been closed...
02/09/2023 21:50:54 - Command 1675975851731 executed!
02/09/2023 21:50:56 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetCommands'...
02/09/2023 21:50:56 - Websocket connection initialization....
02/09/2023 21:50:56 - Connecting to '192.168.0.6'
02/09/2023 21:50:58 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
Release de jeedom: 4.3.15
Release SDK Tydom 1.0: 03.04.15
Avez vous une idée ?
