Je rencontre un pb avec le plugin sur une debian 10. Ci-dessous les logs MyTado_packages de l’installation.
Dans l’écran de configuration du plugin, les onglets Dépendances et Démon sont vides et lors de l’ajout d’une maison, il y a une erreur « Type incorrect, (classe commande inexistante)MyTadoCmd »
Cela provient surement de mon environnement resté en Debian 10 (je sais qu’il est recommandé de passer sur Debian 11 pour la v4.4, mais je n’ai pas encore migré l’OS).
Merci d’avance,
Loïc
MyTado_packages
+ touch /tmp/jeedom_install_in_progress_MyTado
+ echo 1
+ echo 2
++ awk '$1 <= 4'
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 cache purge
Files removed: 204
+ echo 4
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (24.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo python3 -m pip install --force-reinstall --upgrade typing
Collecting typing
Downloading typing-3.7.4.3.tar.gz (78 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.6/78.6 kB 4.0 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Installing backend dependencies: started
Installing backend dependencies: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Building wheels for collected packages: typing
Building wheel for typing (pyproject.toml): started
Building wheel for typing (pyproject.toml): finished with status 'done'
Created wheel for typing: filename=typing-3.7.4.3-py3-none-any.whl size=26304 sha256=74ec9841909a78ba0bd77f3f808713eb008bb91c91fafb3dbd4ee674e58c274f
Stored in directory: /root/.cache/pip/wheels/35/f3/15/01aa6571f0a72ee6ae7b827c1491c37a1f72d686fd22b43b0e
Successfully built typing
Installing collected packages: typing
Successfully installed typing-3.7.4.3
+ echo 6
+ sudo python3 -m pip install --force-reinstall --upgrade psutil
Collecting psutil
Downloading psutil-6.1.1-cp36-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (22 kB)
Downloading psutil-6.1.1-cp36-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (289 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 289.0/289.0 kB 8.1 MB/s eta 0:00:00
Installing collected packages: psutil
Successfully installed psutil-6.1.1
+ echo 7
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end MyTado
+ echo 8
+ rm /tmp/jeedom_install_in_progress_MyTado
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : non
Plugin : MyTado
Version : 2025-01-19 19:08:00 (stable)
Statut Démon : Stoppé - (Inconnue)
