PB script installation V3
Bonnjour,
Suite à un crash de mon jeedom V3 on m’a conseillé de partir sur une fresh install.
Suite à une recherche j’ai lancé ce script car l’ancien ne fonctionne plus:
wget -O- https://raw.githubusercontent.com/jeedom/core/refactoring/install/install.sh | sudo bash
Et j’ai cette erreur:
Package mbrola is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'mbrola' has no installation candidate
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'brltty' is not installed, so not removed
The following package was automatically installed and is no longer required:
  rpi-eeprom-images
Use 'apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
\033[1;32métape 2 paquet principal réussie\033[0;39m
\033[1;33mCommence l'étape 3 base de données\033[0;39m
Package mysql-client is not available, but is referred to by another package.
However the following packages replace it:
  mariadb-client-10.0
Package mysql-server is not available, but is referred to by another package.
  mariadb-server-10.0
E: Package 'mysql-client' has no installation candidate
E: Package 'mysql-server' has no installation candidate
\033[1;31mNe peut installer mysql-client mysql-common mysql-server - Annulation\033[0;39m
Comment dois je faire car je suis bloqué.
Merci d’avance,
C
La première étape est probablement de mettre à jour le pi avant d’installer Jeedom. La version « buster » est dispo depuis un moment, tu devrais pouvoir éviter ces packages inexistants sur les autres plus anciennes
justement je suis sur la buster…
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
C.
Je ne crois pas que la branche refactoring puisse être installée directement car il cherche mysql-server
est ce qu’il est possible d’avoir le script pour installer la V3?
Ou alors comment dois je faire ?
Merci d’avance,
C.
Tu peux aussi faire une installe standard v4 et restaurer un backup v3 afin de revenir en v3 mais quitte a partir sur une fresh installe profite en pour rester en v4 c’est l’avenir :wink:
je pars en congé ce soir, et je voudrais juste avoir mon jeedom de fonctionnel.
Donc je lance le script pour installer la v4 et je restaure le backup de la v3. Et je serai en v3 focntionnel?
Ai je bien compris?
C.
oui c’est bien cela ou alors si tu veux il y a ici une image stretch v3 fait par un membre de la communauté :slight_smile:
c’est en cours de téléchargement…
C.
Si tu as pris l’image v3 pense a la mettre à jour avant de remettre ton backup car elle est de base en v3.1.19 :wink: surtout si ton backup est plus récent :slight_smile:
Non j’ai pris la v4
la restauration est faite. Pour les plug in je dois les réinstaller à la main ou cela va se faire en auto?
C.
Normalement tout va se remettre tout seul (plugin, widget, scénario, etc) peut être aura tu des dépendances a relancer manuellement si elle ne se réinstalle pas automatiquement.
tout est fonctionnel=
Encore un grand merci pour vos aides.
C.
Cool super tu vas pouvoir partir tranquille :slight_smile:
Pense à cocher la case “solution” sur le message qui répond à la demande. ça fermera automatiquement la sujet et fera remonter la réponse sur le 1er post pour que ceux qui auraient la même demande visualisent immédiatement la solution.
Bonjour @crunchy,
Pour l’instant, pour installer Jeedom V3 voir ici : [RTEX] Debian 10 - Buster - netinst - amd64 - Jeedom V4
En résumé :
# wget https://raw.githubusercontent.com/jeedom/core/master/install/install.sh
Dans le fichier install.sh, remplacer VERSION=V4-stable par VERSION=master.
akenad :slight_smile:
Merci, je le serais pour la prochaine fois. Quoi que en rentrant je passerai en v4 malgré que se soit une « release candidate »
C.
