J’ai réussi à inclure mes modules d’ouverture de porte. Lors de l’achat, j’ai choisi un modèle qui fonctionne avec des piles AAA (et non avec pile bouton CR2032) et je ne sais pas si c’est ça qui perturbe la remontée de l’info batterie mais on remarque que dans les informations brutes ci-dessous les attributs dans la section Power Configuration sont vide. Avez-vous une idée d’où peut venir le problème.
Informations brutes
"ieee": "a4:c1:38:07:2b:6e:aa:36",
"nwk": 40207,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "1652386740.508",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TZ3000_n2egfsli",
"model": "TS0203",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 2,
"name": "zone_status",
"value": 1
"id": 16,
"name": "cie_addr",
"value": "00:21:2e:ff:ff:06:99:61"
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 69
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_n2egfsli"
"id": 5,
"name": "model",
"value": "TS0203"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"signature": {
"model": "TS0203",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
1,
3,
1280,
0
3,
4,
5,
6,
8,
4096,
25,
10
"class": "zigpy.device"
