File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in <module>
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 668, in _load_unlocked
File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in <module>
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1553, in <module>
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1571, in X509StoreFlags
NOTIFY_POLICY = _lib.X509_V_FLAG_NOTIFY_POLICY
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_NOTIFY_POLICY'
+ echo 9
+ sudo pip3 install --force-reinstall --upgrade future
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
__import__(vendored_name, globals(), locals(), level=0)
ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
During handling of the above exception, another exception occurred:
File "/usr/bin/pip3", line 9, in <module>
from pip._internal import main
File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in <module>
from pip._vendor.urllib3.exceptions import DependencyWarning
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in <module>
vendored("cachecontrol")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in <module>
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in <module>
+ echo 10
+ sudo pip3 install --force-reinstall --upgrade pycrypto
+ echo 11
+ sudo pip3 install --force-reinstall --upgrade cryptography
+ echo 12
+ sudo pip3 install --force-reinstall --upgrade enum34
+ echo 13
+ sudo pip3 install --force-reinstall --upgrade enum-compat
+ echo 14
+ sudo pip3 install --force-reinstall --upgrade wheel
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade yeelight
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade python-miio
+ echo 17
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end xiaomihome
+ echo 18
+ rm /tmp/jeedom_install_in_progress_xiaomihome
