Bonsoir la communauté,
j’ai un problème de communication depuis que j’ai remis mon Atlas d’origine avec le backup qui va bien (du market…)
le démon du plugin Google Cast était NOK, il est maintenant vert (j’ai installé en SHH pip install protobuf==3.20.*) mais il ne scan rien
Voici les logs :
GoogleCast_local:
24-04-16 21:42:17][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:48060]
[2024-04-16 21:42:17][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "action", "device": {"uuid": "ea20150b-af56-c3ce-30bc-1ff40016add2", "source": "googlecast"}, "command": [{"cmd": "notif", "value": "il y a quelqu'un dans le parking.mp3", "vol": "40"}]}
[2024-04-16 21:42:17][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:48060]
[2024-04-16 21:42:17][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-04-16 21:42:17][DEBUG] : SOCKET-READ------Received command from jeedom : action
[2024-04-16 21:42:17][DEBUG] : SOCKET-READ------Attempt an action on a device
[2024-04-16 21:42:17][DEBUG] : SOCKET-READ------Action Thread Launched
[2024-04-16 21:42:17][DEBUG] : ACTION------ Device not connected !
[2024-04-16 21:42:17][DEBUG] : SENDER------Send to jeedom : {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'nowplaying': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'online': True, 'is_active_input': False, 'is_stand_by': False, 'display_name': 'NOT CONNECTED', 'status_text': 'NOT CONNECTED', 'player_state': 'NOT CONNECTED', 'title': '', 'album_artist': '', 'album_name': '', 'current_time': 0, 'artist': '', 'image': None, 'series_title': '', 'season': '', 'episode': '', 'stream_type': '', 'track': ''}}
[2024-04-16 21:42:17][DEBUG] : SENDER------Send to jeedom : {'devices': {'ea20150b-af56-c3ce-30bc-1ff40016add2': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'typemsg': 'error', 'status': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'display_name': 'NOT CONNECTED', 'status_text': 'NOT CONNECTED'}}}}
[2024-04-16 21:42:25][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:45122]
[2024-04-16 21:42:25][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "action", "device": {"uuid": "ea20150b-af56-c3ce-30bc-1ff40016add2", "source": "googlecast"}, "command": [{"cmd": "notif", "value": "fermeture automatique des volets dans une minute.mp3", "vol": "40"}]}
[2024-04-16 21:42:25][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:45122]
[2024-04-16 21:42:25][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-04-16 21:42:25][DEBUG] : SOCKET-READ------Received command from jeedom : action
[2024-04-16 21:42:25][DEBUG] : SOCKET-READ------Attempt an action on a device
[2024-04-16 21:42:25][DEBUG] : SOCKET-READ------Action Thread Launched
[2024-04-16 21:42:25][DEBUG] : ACTION------ Device not connected !
[2024-04-16 21:42:25][DEBUG] : SENDER------Send to jeedom : {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'nowplaying': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'online': True, 'is_active_input': False, 'is_stand_by': False, 'display_name': 'NOT CONNECTED', 'status_text': 'NOT CONNECTED', 'player_state': 'NOT CONNECTED', 'title': '', 'album_artist': '', 'album_name': '', 'current_time': 0, 'artist': '', 'image': None, 'series_title': '', 'season': '', 'episode': '', 'stream_type': '', 'track': ''}}
[2024-04-16 21:42:25][DEBUG] : SENDER------Send to jeedom : {'devices': {'ea20150b-af56-c3ce-30bc-1ff40016add2': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'typemsg': 'error', 'status': {'uuid': 'ea20150b-af56-c3ce-30bc-1ff40016add2', 'display_name': 'NOT CONNECTED', 'status_text': 'NOT CONNECTED'}}}}
[2024-04-16 21:42:37][DEBUG] : SCANNER------ Start scanning... (schedule)
[2024-04-16 21:42:37][DEBUG] : MEMORY---- Total CPU time used : 19.625s (0.38%) | Last 62 sec : 0.313s (0.50%) | Memory : 50 Mo
[2024-04-16 21:42:37][INFO] : SCANNER------ Adding chromecast : Chambre parentale
[2024-04-16 21:42:37][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2024-04-16 21:42:37][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 2133, in scanner
globals.GCAST_DEVICES[uuid] = JeedomChromeCast(
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 107, in __init__
self.gcast.wait(timeout=globals.SCAN_TIMEOUT)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 444, in wait
if not self.socket_client.isAlive():
AttributeError: 'SocketClient' object has no attribute 'isAlive'
[2024-04-16 21:43:39][DEBUG] : SCANNER------ Start scanning... (schedule)
[2024-04-16 21:43:39][DEBUG] : MEMORY---- Total CPU time used : 19.821s (0.38%) | Last 62 sec : 0.196s (0.32%) | Memory : 50 Mo
[2024-04-16 21:43:39][INFO] : SCANNER------ Adding chromecast : Chambre parentale
[2024-04-16 21:43:39][ERROR] : SCANNER------Exception on scanner : 'SocketClient' object has no attribute 'isAlive'
[2024-04-16 21:43:39][DEBUG] : Traceback (most recent call last):
googlecast_update :
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 11 (bullseye)
-- Updating repo...
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
Hit:4 http://security.debian.org bullseye-security InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:6 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Ign:7 http://imola.armbian.com/apt buster InRelease
Err:8 http://fi.mirror.armbian.de/apt buster Release
404 Not Found [IP: 65.21.120.247 80]
Reading package lists...
E: The repository 'http://apt.armbian.com buster Release' no longer has a Release file.
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
python-dev-is-python2 is already the newest version (2.7.18-9).
0 upgraded, 0 newly installed, 0 to remove and 88 not upgraded.
-- Installed version of Python :
Python 3.9.2
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
E: Unable to locate package python-requests
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-2+deb11u2).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-11).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.3.6-0+deb11u1).
-- Upgrade setuptools with command pip3.9 if not up to date
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.9/dist-packages (69.5.1)
-- Installed version of pip :
pip 24.0 from /usr/local/lib/python3.9/dist-packages/pip (python 3.9)
-- Installation of python library 'requests' with command pip3.9
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.9/dist-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (2.0.12)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (3.7)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (2.2.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (2024.2.2)
-- Installation of python library 'protobuf' with command pip3.9
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.9/dist-packages (3.20.3)
-- Installation of python library 'zeroconf' with command pip3.9
Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.9/dist-packages (0.132.2)
Requirement already satisfied: async-timeout>=3.0.0 in /usr/local/lib/python3.9/dist-packages (from zeroconf>=0.25.1) (4.0.3)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.9/dist-packages (from zeroconf>=0.25.1) (0.2.0)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.9
Requirement already satisfied: click in /usr/local/lib/python3.9/dist-packages (8.1.7)
Requirement already satisfied: bs4 in /usr/local/lib/python3.9/dist-packages (0.0.2)
Requirement already satisfied: six in /usr/local/lib/python3.9/dist-packages (1.16.0)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.9/dist-packages (from bs4) (4.12.3)
Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.9/dist-packages (from beautifulsoup4->bs4) (2.5)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.9
Requirement already satisfied: tqdm in /usr/local/lib/python3.9/dist-packages (4.66.2)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.9/dist-packages (1.7.0)
Requirement already satisfied: casttube in /usr/local/lib/python3.9/dist-packages (0.2.1)
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (from casttube) (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (2.0.12)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (3.7)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (2.2.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (2024.2.2)
-- Installation of dependencies is done !
J’ai beau lancé un scan et il ne trouve rien alors que c’est ok sur le réseau
Je suis preneur de tout conseil car je ne vois pas ce qu’il faut faire…
merci par avance
