Bonjour, depuis une semaine je n’arrive plus a installer les dépendances du plugin googlecast.
je suis en V4.0.40 sur une mini plus
Voici les logs google cast update,
d’avance merci pour votre aide
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 8.9 (jessie)
-- Updating repo...
Ign http://httpredir.debian.org jessie InRelease
Hit http://httpredir.debian.org jessie-updates InRelease
Ign http://http.us.debian.org jessie InRelease
Get:1 http://security.debian.org jessie/updates InRelease [44.9 kB]
Get:2 https://repo.solid-build.xyz ./ InRelease [169 B]
Ign https://repo.solid-build.xyz ./ InRelease
Hit https://deb.nodesource.com jessie InRelease
Get:3 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Hit http://httpredir.debian.org jessie Release.gpg
Get:4 https://repo.solid-build.xyz ./ Release [981 B]
Hit http://http.us.debian.org jessie Release.gpg
Hit http://httpredir.debian.org jessie-updates/main Sources
Hit http://httpredir.debian.org jessie-updates/main armhf Packages
Hit http://httpredir.debian.org jessie-updates/main Translation-en
Get:5 http://security.debian.org jessie/updates/main Sources [333 kB]
Get:6 https://deb.nodesource.com jessie/main Sources [762 B]
Err https://repo.solid-build.xyz ./ Release
Get:7 http://security.debian.org jessie/updates/main armhf Packages [727 kB]
Get:8 https://deb.nodesource.com jessie/main armhf Packages [1005 B]
Get:9 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Get:14 http://security.debian.org jessie/updates/main Translation-en [382 kB]
Hit http://httpredir.debian.org jessie/main Sources
Hit http://httpredir.debian.org jessie/main armhf Packages
Hit http://httpredir.debian.org jessie/main Translation-en
Hit http://http.us.debian.org jessie/non-free armhf Packages
Hit http://http.us.debian.org jessie/non-free Translation-en
Fetched 1108 kB in 1min 18s (14.1 kB/s)
Reading package lists...
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.solid-build.xyz ./ Release: The following signatures were invalid: KEYEXPIRED 1578732531
W: Failed to fetch https://repo.solid-build.xyz/debian/jessie/bsp-imx6/./Release
W: Some index files failed to download. They have been ignored, or old ones used instead.
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version.
python-dev is already the newest version.
python3 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 274 not upgraded.
-- Installed version of Python :
Python 3.4.2
Your version of python is not compatible with this plugin, installation might not work correctly !
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version.
python3-dev is already the newest version.
python-requests is already the newest version.
-- Installation of audio sox library
sox is already the newest version.
-- Installation of TTS libraries
libttspico-utils is already the newest version.
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version.
-- Upgrade setuptools with command pip3 if not up to date
File "/usr/bin/pip3", line 9, in <module>
load_entry_point('pip==1.5.6', 'console_scripts', 'pip3')()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 356, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2476, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2190, in load
['__name__'])
File "/usr/lib/python3/dist-packages/pip/__init__.py", line 74, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/usr/lib/python3/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
from pip.download import path_to_url
File "/usr/lib/python3/dist-packages/pip/download.py", line 25, in <module>
from requests.compat import IncompleteRead
ImportError: cannot import name 'IncompleteRead'
-- Installed version of pip :
return ep.load()
['__name__'])
-- Installation of python library 'requests' with command pip3
return ep.load()
['__name__'])
-- Installation of python library 'protobuf' with command pip3
return ep.load()
['__name__'])
-- Installation of python library 'zeroconf' with command pip3
return ep.load()
['__name__'])
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
return ep.load()
['__name__'])
-- Installation of python library 'tqdm, websocket-client' for plex with command pip3
return ep.load()
['__name__'])
-- Installation of dependencies is done !
