Je remplace mon vieux RPI par une VM sur la freebox Delta.
Tout c’est bien passé et ça tourne plutôt bien mais je n’arrive pas à installer le plugins Zwave.
Lors de l’installation des dépendances, ça avance jusque 20 % puis plus rien.
Merci de votre aide et désolé si c’est pas grand chose
Voici le contenu de la log :
Lancement de l'installation/mise à jour des dépendances openzwave
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Reading package lists...
E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://deb.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
build-essential set to manually installed.
g++ is already the newest version (4:8.3.0-1).
g++ set to manually installed.
gcc is already the newest version (4:8.3.0-1).
gcc set to manually installed.
git is already the newest version (1:2.20.1-2).
python-lxml is already the newest version (4.3.2-1).
make is already the newest version (4.2.1-1.2).
make set to manually installed.
python-dev is already the newest version (2.7.16-1).
python-dev set to manually installed.
python-pip is already the newest version (18.1-5).
python-setuptools is already the newest version (40.8.0-1).
python-requests is already the newest version (2.21.0-1).
unzip is already the newest version (6.0-23+deb10u1).
The following additional packages will be installed:
libjpeg62-turbo-dev python-nose
Suggested packages:
python-twisted python-qt3 python-coverage python-nose-doc python-gobject
python-qt4 python-pyside.qtcore python-wxgtk3.0 | python-wxgtk
libjpeg-dev libjpeg62-turbo-dev libudev-dev python-louie python-nose
python-pyudev python-serial
0 upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
Need to get 630 kB of archives.
After this operation, 2129 kB of additional disk space will be used.
Err:1 http://deb.debian.org/debian buster/main arm64 libjpeg62-turbo-dev arm64 1:1.5.2-2+b1
404 Not Found [IP: 2a04:4e42:6c::644 80]
Err:2 http://deb.debian.org/debian buster/main arm64 libjpeg-dev all 1:1.5.2-2
Err:3 http://deb.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u1
Get:4 http://deb.debian.org/debian buster/main arm64 python-nose all 1.3.7-4 [132 kB]
Get:5 http://deb.debian.org/debian buster/main arm64 python-louie all 1.1-4 [21.8 kB]
Get:6 http://deb.debian.org/debian buster/main arm64 python-pyudev all 0.21.0-1 [40.2 kB]
Get:7 http://deb.debian.org/debian buster/main arm64 python-serial all 3.4-4 [83.0 kB]
Fetched 277 kB in 0s (4019 kB/s)
E: Failed to fetch http://deb.debian.org/debian/pool/main/libj/libjpeg-turbo/libjpeg62-turbo-dev_1.5.2-2+b1_arm64.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/libj/libjpeg-turbo/libjpeg-dev_1.5.2-2_all.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/s/systemd/libudev-dev_241-7~deb10u1_arm64.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
could not install git - abort
