J’ai découvert ce plugin qui va me servir a récupérer les objets de certains mails pour entre autre les notifs de backup:
Mon system à jour:
root@jeedom:~# apt update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
root@jeedom:~# apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@jeedom:~#
l’install du plugin:
Début de l'installation
Installation spécifique plugin
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated mailparser@0.4.9: Mailparser versions older than v2.3.0 are deprecated
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 92 packages, and audited 93 packages in 2s
13 packages are looking for funding
run `npm fund` for details
5 moderate severity vulnerabilities
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
Fin de l'installation
root@jeedom:~# npm fund
rootroot@jeedom:~#
root@jeedom:~# npm audit fix --force
npm WARN using --force Recommended protections disabled.
npm ERR! code ENOLOCK
npm ERR! audit This command requires an existing lockfile.
npm ERR! audit Try creating one first with: npm i --package-lock-only
npm ERR! audit Original error: loadVirtual requires existing shrinkwrap file
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-03-08T09_26_49_752Z-debug-0.log
root@jeedom:~#
un peu dans une impasse :
root@jeedom:~# cat /root/.npm/_logs/2024-03-08T09_26_49_752Z-debug-0.log
cat: /root/.npm/_logs/2024-03-08T09_26_49_752Z-debug-0.log: No such file or directory
root@jeedom:~#
Merci d’avance pour vos pistes ![]()
