J’ai acheté la tête de radiateur Zigbee Woox R7067 : WOOX - Tête thermostatique connectée Zigbee 3.0
J’utilise le zigbee « natif » et le plugin ZigBee (zigpy).
Le pairing semble fonctionner, le type de matériel est détecté, mais seules 3 commandes sont créées : Etat, on, off.
Les commandes on et off génèrent l’erreur : Cluster not found : on_off
J’ai essayé de créer manuellement des commandes, notamment en m’inspirant de ce thread, mais rien n’y fait.
Ci-dessous les « informations brutes » du noeud. Je m’attenderais à voir plus de commandes. Le matériel est bien listé comme compatible.
Est-ce que quelqu’un saurait quels sont les bons clusters/commandes à utiliser ? D’avance merci !
"ieee": "5c:02:72:ff:fe:f1:40:c4",
"nwk": 43784,
"status": 2,
"lqi": "118",
"rssi": "-65",
"last_seen": "1641081120.000621",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_wnvhlcgl",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 64
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_wnvhlcgl"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 10,
"name": "Time",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
10,
4,
5,
61184
25
"class": "zigpy.device"
