j’ai tenté d’inclure un visonic K90-80,
la procedure semble fonctionner car il me l’inclus mais le resultat qualifier reçu est toujours a la valeur 3
0468|[2022-07-31 10:55:44]DEBUG : Send to jeedom : {'devices': {'7b4d6320': {'protocol': 'VISONIC', 'subid': '6320', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '2', 'frameType': '0', 'floorNoise': '-100', 'cluster': '0', 'frequency': '868350', 'rfLevel': '-87', 'dataFlag': '1', 'infoType': '2', 'protocolMeaning': 'VISONIC'}, 'infos': {'id': '2068669216', 'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3', 'qualifierMeaning': {'flags': ['Tamper', 'Alarm']}}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-87', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3'}, 'id': '7b4d'}}}
0469|[2022-07-31 10:55:44]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0470|[2022-07-31 12:55:44]INFO : API RfPlayer solicité
0471|[2022-07-31 10:55:44]DEBUG : http://127.0.0.1:80 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=GHMalAkFqpaOPHwmlyVFqQH85sn5GdwDMpqDtbCWuOA94K6p9V7SV8jQ9mL5DOIF HTTP/1.1" 200 0
0472|[2022-07-31 10:55:50]DEBUG : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-89", "floorNoise": "-105", "rfQuality": "4", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "2068669216", "qualifier": "3", "qualifierMeaning": { "flags": ["Tamper","Alarm"]}}}}
0473|[2022-07-31 10:55:50]DEBUG : Received a Visonic frame
0474|[2022-07-31 10:55:50]DEBUG : type2
0475|[2022-07-31 10:55:50]DEBUG : Send to jeedom : {'devices': {'7b4d6320': {'protocol': 'VISONIC', 'subid': '6320', 'raw': {'frame': {'header': {'rfQuality': '4', 'protocol': '2', 'frameType': '0', 'floorNoise': '-105', 'cluster': '0', 'frequency': '868350', 'rfLevel': '-89', 'dataFlag': '1', 'infoType': '2', 'protocolMeaning': 'VISONIC'}, 'infos': {'id': '2068669216', 'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3', 'qualifierMeaning': {'flags': ['Tamper', 'Alarm']}}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-89', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3'}, 'id': '7b4d'}}}
0476|[2022-07-31 10:55:50]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0477|[2022-07-31 12:55:50]INFO : API RfPlayer solicité
0478|[2022-07-31 10:55:50]DEBUG : http://127.0.0.1:80 "POST /plugins/rfplayer2/core/php/jeeRfplayer2.php?apikey=GHMalAkFqpaOPHwmlyVFqQH85sn5GdwDMpqDtbCWuOA94K6p9V7SV8jQ9mL5DOIF HTTP/1.1" 200 0
0479|[2022-07-31 10:55:54]DEBUG : ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-92", "floorNoise": "-105", "rfQuality": "3", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868350"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "2068669216", "qualifier": "3", "qualifierMeaning": { "flags": ["Tamper","Alarm"]}}}}
0480|[2022-07-31 10:55:54]DEBUG : Received a Visonic frame
0481|[2022-07-31 10:55:54]DEBUG : type2
0482|[2022-07-31 10:55:54]DEBUG : Send to jeedom : {'devices': {'7b4d6320': {'protocol': 'VISONIC', 'subid': '6320', 'raw': {'frame': {'header': {'rfQuality': '3', 'protocol': '2', 'frameType': '0', 'floorNoise': '-105', 'cluster': '0', 'frequency': '868350', 'rfLevel': '-92', 'dataFlag': '1', 'infoType': '2', 'protocolMeaning': 'VISONIC'}, 'infos': {'id': '2068669216', 'subType': '0', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3', 'qualifierMeaning': {'flags': ['Tamper', 'Alarm']}}}}, 'learn': False, 'data': {'subType': '0', 'dBm': '-92', 'subTypeMeaning': 'Detector/Sensor', 'qualifier': '3'}, 'id': '7b4d'}}}
Donc le resultat ne change jamais et donc pas exploitable.
Merci a ceux qui pourront m’aider.
