mapa
Avril 12, 2023, 6:36
1
ci joint les infos demandées
WorxLandroidS
[2023-04-12 13:21:14][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=worxLandroidS function=remove callInstallFunction=1
[2023-04-12 13:21:14][INFO] : Suppression extension
[2023-04-12 13:21:17][INFO] : Début d'activation du plugin
[2023-04-12 13:21:18][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2023-04-12 13:21:18][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=worxLandroidS function=install callInstallFunction=1
[2023-04-12 13:21:36][ERROR] : Impossible de lancer le démon
[2023-04-12 13:21:53][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=worxLandroidS function=remove callInstallFunction=1
[2023-04-12 13:21:53][INFO] : Suppression extension
[2023-04-12 13:21:55][INFO] : Début d'activation du plugin
[2023-04-12 13:21:56][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2023-04-12 13:21:56][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=worxLandroidS function=install callInstallFunction=1
[2023-04-12 13:22:33][INFO] : Lancement démon
[2023-04-12 13:22:33][DEBUG] : test from daemon
[2023-04-12 13:22:43][ERROR] : Impossible de lancer le démon```
WorxLandroidS_deamon
[2023-04-12 11:22:33][INFO] : Starting daemon
[2023-04-12 11:22:33][INFO] : Log level: debug
[2023-04-12 11:22:33][DEBUG] : Socket port : 55073
[2023-04-12 11:22:33][DEBUG] : PID file : /tmp/jeedom/worxLandroidS/daemon.pid
[2023-04-12 11:22:33][DEBUG] : Initializing connector…
[2023-04-12 11:22:33][DEBUG] : Initializing the API connector …
[2023-04-12 11:22:33][DEBUG] : Getting logger …
[2023-04-12 11:22:33][DEBUG] : Initializing EventHandler …
[2023-04-12 11:22:33][DEBUG] : Authenticating yyyyyy.yyyy@xxxx.xxx
[2023-04-12 11:22:33][ERROR] : Exception during authentication:
[2023-04-12 11:22:33][INFO] : Shuting down
[2023-04-12 11:22:33][DEBUG] : Removing PID file /tmp/jeedom/worxLandroidS/daemon.pid
[2023-04-12 11:22:33][DEBUG] : Exit 0
Par contre un log me donne l’heure correcte (13:22) et l’autre me donne l’heure - 2 (11:22)
Cordialement
Mips
Avril 12, 2023, 7:03
2
Je suis étonné de ne pas voir un log ..._packages avec les dépendances, pouvez-vous relancer les dépendances ?
Pour info le fichier ..._dep est l’ancien log des dépendances, il peut être supprimé
mapa
Avril 12, 2023, 7:17
3
J’ai relancé les dépendances mais toujours rien
j’ai aussi désinstallé le plugin et réinstallé et relancé les dépendances mais toujours rien
que dois-je faire docteur ?
Mips
Avril 15, 2023, 7:19
4
Essayez d’installer la beta et de relancer les dépendances
c’est quoi comme machine sur lequel est installé jeedom? un vm?
mapa
Avril 15, 2023, 7:56
5
Avec la Beta, mème motif même punition
Jeedom tourne dans un container Proxmox
Cordialement
Mips
Avril 15, 2023, 8:25
6
S’il n’y a pas de log des dépendances c’est qu’il y a un soucis qlq part.
Je ne peux pas deviner ce qu’il se passe sans log
Je peux voir la page des paquets system dans la config jeedom, onglet os/db
mapa
Avril 15, 2023, 8:33
7
Ci joint les infos
|Package|Type|Status|Obligatoire|Voulu par|Version|Remarque|Commande|Action|
|apt-transport-https|apt|OK|oui|core|1.8.2.3||||
|at|apt|OK|oui|core|3.1.23-1||||
|chromium|apt|OK|non|core|90.0.4430.212-1~deb10u1|Utilisé pour les rapports|||
|ffmpeg|apt|OK|oui|core|7:4.1.10-0+deb10u1||||
|gettext|apt|OK|oui|core|0.19.8.1-9||||
|libav-tools|apt|OK (ffmpeg)|oui|core|||||
|libcurl3-gnutls|apt|OK|non|core|7.64.0-4+deb10u5|Utilisé pour chromium|||
|librsync-dev|apt|OK|oui|core|0.9.7-10+b1||||
|mariadb-client|apt|OK|oui|core|1:10.3.38-0+deb10u1||||
|mariadb-common|apt|OK|non|core|1:10.3.38-0+deb10u1||||
|mariadb-server|apt|OK|non|core|1:10.3.38-0+deb10u1||||
|net-tools|apt|OK|oui|core|1.60+git20180626.aebd88e-1||||
|nmap|apt|OK|oui|core|7.70+dfsg1-6+deb10u2||||
|nodejs|apt|OK|oui|gsh|16.19.1-deb-1nodesource1||||
|ntpdate|apt|OK|oui|core|1:4.2.8p12+dfsg-4||||
|openvpn|apt|OK|oui|openvpn|2.4.7-1+deb10u1||||
|php-common|apt|OK|oui|core|2:69||||
|php-curl|apt|OK|oui|core|2:7.3+69||||
|php-dev|apt|OK|oui|core|2:7.3+69||||
|php-gd|apt|OK|oui|core|2:7.3+69||||
|php-imap|apt|OK|oui|core|2:7.3+69||||
|php-ldap|apt|OK|non|core|2:7.3+69||||
|php-mbstring|apt|OK|oui|core enedis|2:7.3+69||||
|php-soap|apt|OK|oui|core|2:7.3+69||||
|php-ssh2|apt|OK|oui|core|1.1.2+0.13-4||||
|php-xml|apt|OK|oui|core|2:7.3+69||||
|php-xmlrpc|apt|OK|oui|core|2:7.3+69||||
|php-zip|apt|OK|oui|core|2:7.3+69||||
|python|apt|OK|oui|core|2.7.16-1||||
|python-dev|apt|OK|oui|core|2.7.16-1||||
|python-pip|apt|OK|oui|core|18.1-5||||
|python3|apt|OK|oui|core|3.7.3-1||||
|python3-pip|apt|OK|oui|core|18.1-5||||
|python3-requests|apt|OK|oui|worxLandroidS|2.21.0-1||||
|smbclient|apt|OK|oui|core|2:4.9.5+dfsg-5+deb10u3||||
|software-properties-common|apt|OK|oui|core|0.96.20.2-2||||
|ssl-cert|apt|OK|oui|core|1.0.39||||
|tar|apt|OK|oui|core|1.30+dfsg-6||||
|usbutils|apt|OK|non|core|1:010-3||||
|wget|apt|OK|oui|core|1.20.1-1.1||||
|wireguard|apt|OK|oui|wireguard|1.0.20210223-1~bpo10+1||||
|plugins/gsh/resources/gshd|npm|OK|oui|gsh|0.0.1||||
|fasteners|pip2|OK|oui|core|0.16.3||||
|future|pip2|OK|oui|core|0.18.3||||
|aiohttp|pip3|OK|oui|worxLandroidS|3.8.4||||
|awsiot|pip3|OK|oui|worxLandroidS|0.1.3||||
|awsiotsdk|pip3|OK|oui|worxLandroidS|1.13.0||||
|backports.zoneinfo|pip3|OK|oui|worxLandroidS|0.2.1||||
|requests|pip3|OK|oui|worxLandroidS|2.28.2||||
|urllib3|pip3|OK|oui|worxLandroidS|1.26.15|
mapa
Avril 15, 2023, 8:45
8
Désolé j’ai a présent _package, je n’avais pas fait attention
echo '*******************Begin of package installation******************'
+ touch /tmp/jeedom_install_in_progress_worxLandroidS
+ echo 1
+ echo 2
++ cut -f 2-
++ awk '$1 <= 4'
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
+ RESULTTODELETE=
++ sed 's, ,\ ,g'
++ echo ''
+ RESULTTODELETE2=
+ xargs rm -rf
+ echo ''
+ echo 3
+ sudo pip3 cache purge
Files removed: 121
+ echo 4
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.0.1)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo pip3 install --force-reinstall --upgrade awsiotsdk
Collecting awsiotsdk
Downloading awsiotsdk-1.13.0-py3-none-any.whl (67 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 67.6/67.6 kB 3.6 MB/s eta 0:00:00
Collecting awscrt==0.16.14
Downloading awscrt-0.16.14-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (8.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 8.1/8.1 MB 50.2 MB/s eta 0:00:00
Installing collected packages: awscrt, awsiotsdk
Attempting uninstall: awscrt
Found existing installation: awscrt 0.16.13
Uninstalling awscrt-0.16.13:
Successfully uninstalled awscrt-0.16.13
Attempting uninstall: awsiotsdk
Found existing installation: awsiotsdk 1.12.6
Uninstalling awsiotsdk-1.12.6:
Successfully uninstalled awsiotsdk-1.12.6
Successfully installed awscrt-0.16.14 awsiotsdk-1.13.0
+ echo 6
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end worxLandroidS
+ rm /tmp/jeedom_install_in_progress_worxLandroidS
Mips
Avril 15, 2023, 8:54
9
Ok et le log du démon est le même ?
Toujours pas de description de l’erreur ?
Y aurait-il un caractère (un peu trop) spécial dans le mot de passe? Êtes-vous certain qu’il est correct ?
mapa
Avril 15, 2023, 10:00
10
C’est cela, mon mot de passe était
<sG=6$_zY8)Ag}e
a présent c’est
4qshAfOvkLg77Qc
et cela fonctionne, merci
Quel est le caractère spécial qu’il ne faut pas utiliser ?
Cordialement
Mips
Avril 15, 2023, 11:06
11
Je ne suis pas certain, faudrait tester, mais à priori ca doit être le < qui casse la requête.
Je vais nettoyer le code pour que ca ne cause plus de soucis.
Je suppose que vous avez encore changer le mot de passe depuis? car là il est public
Dans mon cas c’est le signe $ qu’il n’aimait pas…
