Il faut copier le depot dans un dossier de jeedom c’est ca? Lequel?
Oui dans le dossier plugin
JE viens de le copier
Le plugin apparait bien dans la liste des plugins mais lorsque je veux acceder a la config, il met plugin introuvable.
Ya til quelque chose a modifier dans le code?
Essai cette branche plutôt , j’ai desendu la version
Après pour les modifs de code sûrement j’en ai aucune idée
Ca avance.
J’ai réussi à installer le plugin.
Par contre, les dependance sont Nok, pourtant dans les logs, j’ai dépendances OK.
Python ne serait pas a jour?
Hit:1 Index of /debian stretch InRelease
Hit:2 Index of /raspbian stretch InRelease
Hit:3 Index of /node_14.x/ stretch InRelease
Reading package lists…
Building dependency tree…
Reading state information…
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 243 not upgraded.
python3-pip is already the newest version (9.0.1-2+rpt2).
DEPRECATION: Python 3.5 reached the end of its life on September 13th, 2020. Please upgrade your Python as Python 3.5 is no longer maintained. pip 21.0 will drop support for Python 3.5 in January 2021. pip 21.0 will remove support for this functionality.
Looking in indexes: Simple index, piwheels - Simple index
Requirement already satisfied: pip in /usr/local/lib/python3.5/dist-packages (20.3.4)
Collecting pip
Using cached https://www.piwheels.org/simple/pip/pip-20.3.4-py2.py3-none-any.whl (1.5 MB)
Using cached https://www.piwheels.org/simple/pip/pip-20.3.3-py2.py3-none-any.whl (1.5 MB)
WARNING: Skipping serial as it is not installed.
Package ‹ python3-serial › is not installed, so not removed
python3-setuptools is already the newest version (33.1.1-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.12.4-1).
Collecting pyjwt
Using cached https://www.piwheels.org/simple/pyjwt/PyJWT-1.7.1-py2.py3-none-any.whl (18 kB)
Collecting html.parser
Using cached https://www.piwheels.org/simple/html-parser/html_parser-0.2-py3-none-any.whl (2.0 kB)
Collecting html5lib
Using cached https://www.piwheels.org/simple/html5lib/html5lib-1.1-py2.py3-none-any.whl (117 kB)
Collecting bs4
Using cached https://www.piwheels.org/simple/bs4/bs4-0.0.1-py3-none-any.whl (2.2 kB)
Collecting asyncio
Using cached https://www.piwheels.org/simple/asyncio/asyncio-3.4.3-py3-none-any.whl (101 kB)
ERROR: Could not find a version that satisfies the requirement httpx
ERROR: No matching distribution found for httpx
Collecting pyserial
Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Requirement already satisfied: six in /usr/local/lib/python3.5/dist-packages (1.16.0)
Collecting six
Using cached https://www.piwheels.org/simple/six/six-1.16.0-py2.py3-none-any.whl (11 kB)
Using cached https://www.piwheels.org/simple/six/six-1.15.0-py2.py3-none-any.whl (10 kB)
[2022-12-24 16:56:02][INFO] : Début d’activation du plugin
[2022-12-24 16:56:03][INFO] : Info sur le démon : Array ( [launchable_message] => [launchable] => nok [state] => nok [log] => nok [auto] => 0 )
[2022-12-24 16:56:08][ERROR] : Veuillez vérifier la configuration
Un paquet ne fonctionne pas avec ta version de python
Ok mais lequel?
Pense à mettre les log dans les balises approprié
Httpx
Du coup ça concerne quel paquet ?
Je peux essayer de l’installer par ssh?
Pourriez-vous me donner la commande ?
Tu n’as pas lu mon précédent message
Si les depandances ne se sont pas installées c’est qu’il ne pouvait pas le faire. Il faut upgrader python avec les risques que ça encour.
C’est pour ça que je n’ai pas tester en v3 mon plugin car ça implique souvent d’anciennes version de debian et python
Et je n’ai pas les compétences et le temps pour faire ces essais.
Pourquoi ne bascule tu pas en v4
Bonjour à tous, la doc officiel de l’API pour la V7 est disponnible https://enphase.com/download/accessing-iq-gateway-local-apis-or-local-ui-token-based-authentication
Mieux vaut tard que jamais ma foi
Et apparement tous ce petit monde communique en mqtt^^
Tout je ne sais pas une partie, oui apparemment
Si seulement il pouvait aussi se connecter sur un mqtt local pour pousser les informations…
on est d’accord^^
mais je dirait que c’est sur le CPL entre les onduleur et la base…
Juste poussé entre la gateway et un broker qu’on pourrait définir, ils ont deja l’air de le faire entre la gateway et leur serveur, ca sera juste une duplication pour eux et pour nous ca serait tellement pratique
Hello.
Pour info, la V7 vient d’être poussée automatiuement sur ma gataway ce matin, le déploiment à l’ensemble des utilisateurs semble être en cours…
