ok ce n’est pas une coquille
Je retombe sur le meme message de maj :
[START UPDATE]
****Update from 3.3.30 (2019-08-14 12:22:31)****
Parameters : {"preUpdate":"0","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event...OK
Check update...
OK
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2019-08-14 12:22:39***************
Envoi l'évènement de début de sauvegarde...OK
Vérification des droits sur les fichiers...
OK
Vérification de la base de données...
OK
Sauvegarde la base de données...
OK
Persistance du cache :
OK
Création de l'archive...
OK
Nettoyage de l'ancienne sauvegarde...OK
Limitation de la taille des sauvegardes à 5000 Mo...
OK
Nom de la sauvegarde : /var/www/html/core/php/../../backup/backup-jeedomint-3.3.30-2019-08-14-12h22.tar.gz
OK
Envoi l'évènement de fin de sauvegarde...OK
Durée de la sauvegarde : 88s
***************Fin de la sauvegarde de Jeedom***************
[END BACKUP SUCCESS]
Disable all task.
kill: (18861): No such process
kill: (18470): No such process
kill: (18252): No such process
... OK
Disable all scenario.................
........................... OK
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress...--2019-08-14 12:24:13-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com)... 140.82.113.3
Connecting to github.com (github.com)|140.82.113.3|:443... connected.
HTTP request sent, awaiting response...
302 Found
Location: https://codeload.github.com/jeedom/core/zip/V4-stable [following]
--2019-08-14 12:24:13-- https://codeload.github.com/jeedom/core/zip/V4-stable
Resolving codeload.github.com (codeload.github.com)... 140.82.114.10
Connecting to codeload.github.com (codeload.github.com)|140.82.114.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K ........ .....
2019-08-14 12:24:17 (9.44 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [31086350]
OK
Cleaning folders...OK
Create temporary folder...OK
Unzip in progress...
OK
Clean temporary files (tmp)...OK
Moving files...
OK
Remove temporary files...OK
Update system into : 3.4.0...
Suppression theme /var/www/html/install/update/../../core/themes/amber/Suppression theme ......
Update system into : 4.0.1...
OK
Update system into : 4.0.2...
Je vais laisser plus longtemps qu’au précédent essai pour voir.
Par contre rien ne bouge dans les logs (/var/log/ et /var/www/html/log/)
Maj :
Après 20 minutes la maj est passée.
J’ai des erreurs majoritairement sur des plugins (rfxcom). Ces logs ne devrait il pas être dans les logs des plugins en question et non de l’update ?
Par contre 20 min sur un serveur HP j’image pas le temps sur un rpi 1
[START UPDATE]
Check update...
OK
Check rights...
OK
[START BACKUP]
OK
OK
OK
OK
OK
OK
OK
Disable all task.
... OK
302 Found
0K ........ .....
... ........ ........ ........ ........ 4.75M
3072K ........ ........ ........ ........ ........ ........ 16.3M
6144K ........ ........ ........ ........ ........ ........ 7.08M
9216K ........ ........ ...
..... ........ ........ ........ 4.78M
12288K ........ ........ ........ ........ ........ ........ 7.72M
15360K ........ ........ ........ ........ ........ ........ 35.4M
18432K ........ ........ ........ ........ ........ ........ 17.3M
21504K ........ ........ ....
.... ........ ........ ........ 16.9M
24576K ........ ........ ........ ........ ........ ........ 16.3M
27648K ........ ........ ........ ........ ........ .. 9.98M=3.1s
OK
OK
Moving files...
OK
Suppression theme /var/www/html/install/update/../../core/themes/amber/Suppression theme /var/www/html/install/update/../../core/themes/blue/Suppression theme /var/www/html/install/update/../../core/themes/blue_grey/Suppression theme /var/www/html/install/update/../../core/themes/bootable/Suppression theme /var/www/html/install/update/../../core/themes/brown/Suppression theme /var/www/html/install/update/../../core/themes/cerulean/Suppression theme /var/www/html/install/update/../../core/themes/cosmo/Suppression theme /var/www/html/install/update/../../core/themes/cyan/Suppression theme /var/www/html/install/update/../../core/themes/cyborg/Suppression theme /var/www/html/install/update/../../core/themes/darkly/Suppression theme /var/www/html/install/update/../../core/themes/darksobre/Suppression theme /var/www/html/install/update/../../core/themes/deep_orange/Suppression theme /var/www/html/install/update/../../core/themes/deep_purple/Suppression theme /var/www/html/install/update/../../core/themes/flatly/Suppression theme /var/www/html/install/update/../../core/themes/green/Suppression theme /var/www/html/install/update/../../core/themes/grey/Suppression theme /var/www/html/install/update/../../core/themes/indigo/Suppression theme /var/www/html/install/update/../../core/themes/jeedom/Suppression theme /var/www/html/install/update/../../core/themes/journal/Suppression theme /var/www/html/install/update/../../core/themes/light_blue/Suppression theme /var/www/html/install/update/../../core/themes/light_green/Suppression theme /var/www/html/install/update/../../core/themes/lime/Suppression theme /var/www/html/install/update/../../core/themes/lumen/Suppression theme /var/www/html/install/update/../../core/themes/orange/Suppression theme /var/www/html/install/update/../../core/themes/paper/Suppression theme /var/www/html/install/update/../../core/themes/pink/Suppression theme /var/www/html/install/update/../../core/themes/purple/Suppression theme /var/www/html/install/update/../../core/themes/readable/Suppression theme /var/www/html/install/update/../../core/themes/red/Suppression theme /var/www/html/install/update/../../core/themes/sandstorn/Suppression theme /var/www/html/install/update/../../core/themes/simplex/Suppression theme /var/www/html/install/update/../../core/themes/slate/Suppression theme /var/www/html/install/update/../../core/themes/spacelab/Suppression theme /var/www/html/install/update/../../core/themes/superhero/Suppression theme /var/www/html/install/update/../../core/themes/teal/Suppression theme /var/www/html/install/update/../../core/themes/united/Suppression theme /var/www/html/install/update/../../core/themes/yellow/Suppression theme /var/www/html/install/update/../../core/themes/yeti/OK
OK
PHP Warning: socket_connect(): unable to connect [111]: Connection refused in /var/www/html/plugins/rfxcom/core/class/rfxcom.class.php on line 335
PHP Warning: socket_write(): unable to write to socket [32]: Broken pipe in /var/www/html/plugins/rfxcom/core/class/rfxcom.class.php on line 336
PHP Warning: deg2rad() expects parameter 1 to be float, string given in /var/www/html/plugins/simupre/vendor/minube/solar-position/src/SolarPosition/Calculator.php on line 235
Invalid version specified after -v flag: -c
USAGE: snmpget [OPTIONS] AGENT OID [OID]...
Version: 5.7.3
Web: http://www.net-snmp.org/
Email: net-snmp-coders@lists.sourceforge.net
OPTIONS:
-h, --help display this help message
-H display configuration file directives understood
-v 1|2c|3 specifies SNMP version to use
-V, --version display package version number
SNMP Version 1 or 2c specific
-c COMMUNITY set the community string
SNMP Version 3 specific
-a PROTOCOL set authentication protocol (MD5|SHA)
-A PASSPHRASE set authentication protocol pass phrase
-e ENGINE-ID set security engine ID (e.g. 800000020109840301)
-E ENGINE-ID set context engine ID (e.g. 800000020109840301)
-l LEVEL set security level (noAuthNoPriv|authNoPriv|authPriv)
-n CONTEXT set context name (e.g. bridge1)
-u USER-NAME set security name (e.g. bert)
-x PROTOCOL set privacy protocol (DES|AES)
-X PASSPHRASE set privacy protocol pass phrase
-Z BOOTS,TIME set destination engine boots/time
General communication options
-r RETRIES set the number of retries
-t TIMEOUT set the request timeout (in seconds)
Debugging
-d dump input/output packets in hexadecimal
-D[TOKEN[,...]] turn on debugging output for the specified TOKENs
(ALL gives extremely verbose debugging output)
General options
-m MIB[:...] load given list of MIBs (ALL loads everything)
-M DIR[:...] look in given list of directories for MIBs
(default: $HOME/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp)
-P MIBOPTS Toggle various defaults controlling MIB parsing:
u: allow the use of underlines in MIB symbols
c: disallow the use of "--" to terminate comments
d: save the DESCRIPTIONs of the MIB objects
e: disable errors when MIB symbols conflict
w: enable warnings when MIB symbols conflict
W: enable detailed warnings when MIB symbols conflict
R: replace MIB symbols from latest module
-O OUTOPTS Toggle various defaults controlling output display:
0: print leading 0 for single-digit hex characters
a: print all strings in ascii format
b: do not break OID indexes down
e: print enums numerically
E: escape quotes in string indices
f: print full OIDs on output
n: print OIDs numerically
q: quick print for easier parsing
Q: quick print with equal-signs
s: print only last symbolic element of OID
S: print MIB module-id plus last element
t: print timeticks unparsed as numeric integers
T: print human-readable text along with hex strings
u: print OIDs using UCD-style prefix suppression
U: don't print units
v: print values only (not OID = value)
x: print all strings in hex format
X: extended index format
-I INOPTS Toggle various defaults controlling input parsing:
b: do best/regex matching to find a MIB node
h: don't apply DISPLAY-HINTs
r: do not check values for range/type legality
R: do random access to OID labels
u: top-level OIDs must have '.' prefix (UCD-style)
s SUFFIX: Append all textual OIDs with SUFFIX before parsing
S PREFIX: Prepend all textual OIDs with PREFIX before parsing
-L LOGOPTS Toggle various defaults controlling logging:
e: log to standard error
o: log to standard output
n: don't log at all
f file: log to the specified file
s facility: log to syslog (via the specified facility)
(variants)
[EON] pri: log to standard error, output or /dev/null for level 'pri' and above
[EON] p1-p2: log to standard error, output or /dev/null for levels 'p1' to 'p2'
[FS] pri token: log to file/syslog for level 'pri' and above
[FS] p1-p2 token: log to file/syslog for levels 'p1' to 'p2'
-C APPOPTS Set various application specific behaviours:
f: do not fix errors and retry the request
File "/var/www/html/plugins/nut/resources/nut.py", line 41, in <module>
result = ups.GetUPSVars( ups=device )
File "/var/www/html/plugins/nut/resources/PyNUT.py", line 154, in GetUPSVars
raise PyNUTError( result.replace( "
PyNUT.PyNUTError: ERR ACCESS-DENIED
File "/var/www/html/plugins/nut/resources/nut.py", line 37, in <module>
ups = PyNUT.PyNUTClient( host=address, login=user,password=password )
File "/var/www/html/plugins/nut/resources/PyNUT.py", line 86, in __init__
self.__connect()
File "/var/www/html/plugins/nut/resources/PyNUT.py", line 105, in __connect
self.__srv_handler = telnetlib.Telnet( self.__host, self.__port )
File "/usr/lib/python2.7/telnetlib.py", line 211, in __init__
self.open(host, port, timeout)
File "/usr/lib/python2.7/telnetlib.py", line 227, in open
self.sock = socket.create_connection((host, port), timeout)
File "/usr/lib/python2.7/socket.py", line 575, in create_connection
raise err
socket.error: [Errno 111] Connection refused
PHP Fatal error: Uncaught Error: Call to a member function event() on boolean in /var/www/html/plugins/alarm/core/class/alarm.class.php:783
Stack trace:
#0 /var/www/html/core/class/cmd.class.php(1093): alarmCmd->execute(NULL)
#1 /var/www/html/plugins/alarm/core/class/alarm.class.php(878): cmd->execCmd()
#2 /var/www/html/core/class/cmd.class.php(1093): alarmCmd->execute(NULL)
#3 /var/www/html/plugins/alarm/core/class/alarm.class.php(437): cmd->execCmd()
#4 /var/www/html/core/class/DB.class.php(195): alarm->postUpdate()
#5 /var/www/html/core/class/eqLogic.class.php(938): DB::save(Object(alarm), false)
#6 /var/www/html/install/update/4.0.2.php(19): eqLogic->save()
#7 /var/www/html/install/update/4.0.2.php(27): replaceAndSaveFA5(Array)
#8 {main}
thrown in /var/www/html/plugins/alarm/core/class/alarm.class.php on line 783
OK
Update system into : 4.0.3...Copy widget of plugin widget to jeedom custom widget dir...OK
Update system into : 4.0.4...
Stack trace:
#0 /var/www/html/plugins/script/core/class/script.class.php(290): com_http->exec(2, 3)
#1 /var/www/html/plugins/script/core/class/script.class.php(189): scriptCmd->execute()
#2 /var/www/html/plugins/script/core/class/script.class.php(211): scriptCmd->refresh()
#3 /var/www/html/core/class/DB.class.php(199): scriptCmd->postSave()
#4 /var/www/html/core/class/cmd.class.php(948): DB::save(Object(scriptCmd))
#5 /var/www/html/install/update/4.0.4.php(23): cmd->save()
#6 {main}
thrown in /var/www/html/core/com/http.com.php on line 126
OK
Update system into : 4.0.5...
OK
Check jeedom consistency...[START CONSISTENCY]
[START CHECK AND FIX DB]
Fix : ALTER TABLE `cmd` DROP INDEX `unique`;
Fix : ALTER TABLE `cmd` DROP INDEX `isHistorized`;
Fix : ALTER TABLE `cmd` DROP INDEX `type`;
Fix : ALTER TABLE `cmd` DROP INDEX `name`;
Fix : ALTER TABLE `cmd` DROP INDEX `subtype`;
Fix : ALTER TABLE `cmd` DROP INDEX `eqLogic_id`;
Fix : ALTER TABLE `cmd` DROP INDEX `value`;
Fix : ALTER TABLE `cmd` DROP INDEX `order`;
Fix : ALTER TABLE `cmd` DROP INDEX `logicalID`;
Fix : ALTER TABLE `cmd` DROP INDEX `logicalId_eqLogicID`;
Fix : ALTER TABLE `cmd` MODIFY COLUMN `logicalId` varchar(255) NULL
Fix : ALTER TABLE `cmd` DROP `html`
Fix :
CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)
Fix :
CREATE INDEX `isHistorized` ON `cmd` (`isHistorized` ASC)
Fix :
CREATE INDEX `type` ON `cmd` (`type` ASC)
Fix :
CREATE INDEX `name` ON `cmd` (`name` ASC)
Fix :
CREATE INDEX `subtype` ON `cmd` (`subType` ASC)
Fix :
CREATE INDEX `eqLogic_id` ON `cmd` (`eqLogic_id` ASC)
Fix :
CREATE INDEX `value` ON `cmd` (`value` ASC)
Fix :
CREATE INDEX `order` ON `cmd` (`order` ASC)
Fix :
CREATE INDEX `logicalID` ON `cmd` (`logicalId` ASC)
Fix :
CREATE INDEX `logicalId_eqLogicID` ON `cmd` (`eqLogic_id` ASC,`logicalId` ASC)
Fix : ALTER TABLE `interactDef` ADD `display` text NULL
Fix : ALTER TABLE `message` ADD `occurrences` int(11) NULL
Fix : ALTER TABLE `plan3dHeader` ADD `order` int(11) NULL
Fix : CREATE INDEX `order` ON `plan3dHeader` (`order` ASC)
Fix : ALTER TABLE `planHeader` ADD `order` int(11) NULL
Fix : CREATE INDEX `order` ON `planHeader` (`order` ASC)
Fix : ALTER TABLE `scenario` DROP `type`
Fix : CREATE TABLE IF NOT EXISTS `widgets` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`name` varchar(255) NOT NULL,
`type` varchar(27) NULL,
`subtype` varchar(27) NULL,
`template` varchar(255) NULL,
`display` text NULL,
`replace` text NULL,
`test` text NULL,
primary key(`id`))
ENGINE InnoDB;
CREATE UNIQUE INDEX `unique` ON `widgets` (`type` ASC,`subtype` ASC,`name` ASC)[END CHECK AND FIX DB]
Check jeedom database...OK
Suppression de : cmd::returnState() car il n'y a pas de lancement prévu
Check filesystem right...
OK
[END CONSISTENCY]
OK
Check update...
OK
***************Jeedom is up to date in 4.0.5***************
***************Update plugins***************
[2019-08-14 12:41:56][ALERT] : Début de la mise à jour de : Monitoring
[2019-08-14 12:41:56][ALERT] : Action de pré-update...
[2019-08-14 12:41:57][ALERT] : OK
[2019-08-14 12:41:57][ALERT] : Téléchargement du plugin...
[2019-08-14 12:41:57][ALERT] : Téléchargement de Monitoring...
[2019-08-14 12:41:57][ALERT] : URL https://www.jeedom.com/market/core/php/downloadFile.php?id=282&version=beta&jeedomversion=4.0.5&hwkey=xxxxxxxx&username=xxx&password=xxxxxxxxxx&password_type=sha1
--2019-08-14 12:41:57-- https://www.jeedom.com/market/core/php/downloadFile.php?id=282&version=beta&jeedomversion=4.0.5&hwkey=xxxxxxxx&username=xxx&password=xxxxxx&password_type=sha1
Resolving www.jeedom.com (www.jeedom.com)... 193.70.3.228
Connecting to www.jeedom.com (www.jeedom.com)|193.70.3.228|:443... connected.
Length: unspecified [application/octet-stream]
Saving to: '/tmp/jeedom/market/Monitoring.zip'
0K .......... .......... .......... .......... .......... 2.98M
50K 1041G=0.02s
2019-08-14 12:41:57 (3.01 MB/s) - '/tmp/jeedom/market/Monitoring.zip' saved [51759]
[2019-08-14 12:41:57][ALERT] : Décompression du zip...
[2019-08-14 12:41:57][ALERT] : Post-installation de Monitoring...
[2019-08-14 12:41:58][ALERT] : OK
***************Update plugin successfully***************
Check update
OK
Enable scenario : OK
Enable task : OK
Launch cron dependancy plugins...OK
Send end of update event...Update duration : 1174s
[END UPDATE SUCCESS]
