ok je vais faire tout ces essais mais pour les logs je suis déja en debug…
les logs quand je fait « Test »
[2022-09-08 20:13:48]DEBUG : Connection successful
[2022-09-08 20:13:48]INFO : Received new file /test from ip=192.168.1.84
[2022-09-08 20:13:48]DEBUG : Get all equipments of camPatrol
[2022-09-08 20:13:48]DEBUG : Search equipment with IP: 192.168.1.84
[2022-09-08 20:13:48]DEBUG : Equipment found! {"id":"702","name":"Détection coté EST","logicalId":"192.168.1.84","generic_type":null,"object_id":"21","eqType_name":"camPatrol","isVisible":"1","isEnable":"1","configuration":{"alertInterval":"60","createtime":"2022-09-07 20:11:43","updatetime":"2022-09-07 20:17:41"},"timeout":null,"category":{"security":"1","heating":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"0","default":"0"},"display":{"backGraph::info":0,"width":"230px","height":"74px"},"order":"8","comment":"","tags":null,"status":{"lastCommunication":"2022-09-07 20:38:23","timeout":0,"warning":0,"danger":0},"cache":[]}
[2022-09-08 20:13:48]DEBUG : The equipment found is: {"id":"702","name":"Détection coté EST","logicalId":"192.168.1.84","generic_type":null,"object_id":"21","eqType_name":"camPatrol","isVisible":"1","isEnable":"1","configuration":{"alertInterval":"60","createtime":"2022-09-07 20:11:43","updatetime":"2022-09-07 20:17:41"},"timeout":null,"category":{"security":"1","heating":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"0","default":"0"},"display":{"backGraph::info":0,"width":"230px","height":"74px"},"order":"8","comment":"","tags":null,"status":{"lastCommunication":"2022-09-07 20:38:23","timeout":0,"warning":0,"danger":0},"cache":[]}
[2022-09-08 20:13:48]DEBUG : Search the command info to update for equipment Id: 702
[2022-09-08 20:13:48]DEBUG : Update Alert command ID: 7171 with: /test
[2022-09-08 20:13:48]DEBUG : Command updated
