je rajoute ici des snaps de la config Wave sur ma Jeedom Smart EnOcean.
merci 1000x pour votre aide !
puis le fichier log après relâchement du Demon après avoir mis a jour les dépendances :
puis ci dessous le log correspondant a l update des dépendances .
Lancement de l’installation/mise à jour des dépendances openzwave
Hit:1 http://security.debian.org stretch/updates InRelease
Hit:3 http://www.deb-multimedia.org stretch InRelease
Hit:4 https://oph.mdrjr.net/meveric all InRelease
Hit:5 https://oph.mdrjr.net/meveric stretch InRelease
Ign:2 https://repo.jeedom.com/odroid stable InRelease
Get:6 https://repo.jeedom.com/odroid stable Release [932 B]
Get:7 https://repo.jeedom.com/odroid stable Release.gpg [659 B]
Ign:8 http://ftp.debian.org/debian stretch InRelease
Get:9 http://ftp.debian.org/debian stretch-updates InRelease [93.6 kB]
Get:10 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Get:11 http://ftp.debian.org/debian stretch-proposed-updates InRelease [96.3 kB]
Hit:12 http://ftp.debian.org/debian stretch Release
Fetched 283 kB in 2min 1s (2326 B/s)
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
git is already the newest version (1:2.11.0-3+deb9u7).
python-louie is already the newest version (1.1-2.1).
make is already the newest version (4.1-9.1).
python-serial is already the newest version (3.2.1-1).
python-dev is already the newest version (2.7.13-2).
python-setuptools is already the newest version (33.1.1-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.12.4-1).
libudev-dev is already the newest version (232-25+deb9u12).
unzip is already the newest version (6.0-21+deb9u2).
libjpeg-dev is already the newest version (1:1.5.1-2+deb9u1).
python-lxml is already the newest version (3.7.1-1+deb9u1).
python-pip is already the newest version (9.0.1-2+deb9u2).
The following packages were automatically installed and are no longer required:
libmemcached11 libmemcachedutil2 libmysqlclient18 libonig2 libpng12-0
libqdbm14 libvpx1 linux-image-3.14.29+ linux-image-arm64-odroid-c2
u-boot-tools
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 203 not upgraded.
Installation des dependances Python
Requirement already satisfied: urwid in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: louie in /usr/lib/python2.7/dist-packages
Requirement already satisfied: nose>=0.8.3 in /usr/lib/python2.7/dist-packages (from louie)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages
Requirement already satisfied: tornado in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: singledispatch in /usr/local/lib/python2.7/dist-packages (from tornado)
Requirement already satisfied: certifi in /usr/local/lib/python2.7/dist-packages (from tornado)
Requirement already satisfied: backports_abc>=0.4 in /usr/local/lib/python2.7/dist-packages (from tornado)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from singledispatch->tornado)
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
Not uninstalling cython at /usr/lib/python2.7/dist-packages, outside environment /usr
apt-get install --force-yes -y cython
cython is already the newest version (0.25.2-1).
u-boot-tools
Installing dependencies for python : 2 7 13
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-docutils is already the newest version (0.13.1+dfsg-2).
u-boot-tools
apt-get install --force-yes -y build-essential libudev-dev g++
u-boot-tools
u-boot-tools
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: nose>=0.11.1 in /usr/lib/python2.7/dist-packages (from nose-html)
pip install nose-progressive
Requirement already satisfied: nose-progressive in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: nose>=1.2.1 in /usr/lib/python2.7/dist-packages (from nose-progressive)
Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python2.7/dist-packages (from nose-progressive)
pip install coverage
Requirement already satisfied: coverage in /usr/local/lib/python2.7/dist-packages
pip install nose
Requirement already satisfied: nose in /usr/lib/python2.7/dist-packages
pip install pylint
Requirement already satisfied: pylint in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: mccabe in /usr/local/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: astroid<1.5.0,>=1.4.5 in /usr/local/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: configparser; python_version == "2.7" in /usr/local/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: backports.functools-lru-cache; python_version == "2.7" in /usr/local/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: isort>=4.2.5 in /usr/local/lib/python2.7/dist-packages (from pylint)
Requirement already satisfied: lazy-object-proxy in /usr/local/lib/python2.7/dist-packages (from astroid<1.5.0,>=1.4.5->pylint)
Requirement already satisfied: wrapt in /usr/local/lib/python2.7/dist-packages (from astroid<1.5.0,>=1.4.5->pylint)
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install "Cython==0.22"
Dependencies for users installed (python 2 7 13)
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Security.o
Building MultiCmd.o
Building SensorBinary.o
Building Language.o
Building SwitchMultilevel.o
Building Color.o
Building ZWavePlusInfo.o
Building Indicator.o
Building CentralScene.o
Building MultiInstance.o
Building MeterPulse.o
Building DoorLock.o
Building ManufacturerSpecific.o
Building ThermostatFanMode.o
Building MultiChannelAssociation.o
Building SwitchAll.o
Building Configuration.o
Building SwitchToggleBinary.o
Building Hail.o
Building ThermostatMode.o
Building SensorMultilevel.o
Building NoOperation.o
Building TimeParameters.o
Building UserCode.o
Building SensorAlarm.o
Building BarrierOperator.o
Building Lock.o
Building ApplicationStatus.o
Building SwitchToggleMultilevel.o
Building DoorLockLogging.o
Building ClimateControlSchedule.o
Building Protection.o
Building ThermostatOperatingState.o
Building NodeNaming.o
Building WakeUp.o
Building BasicWindowCovering.o
Building ManufacturerProprietary.o
Building Association.o
Building Clock.o
Building SceneActivation.o
Building Powerlevel.o
Building ThermostatFanState.o
Building Meter.o
Building AssociationCommandConfiguration.o
Building DeviceResetLocally.o
Building Battery.o
Building CRC16Encap.o
Building Version.o
Building SoundSwitch.o
Building Basic.o
Building Proprietary.o
Building Alarm.o
Building CommandClasses.o
Building ThermostatSetpoint.o
Building EnergyProduction.o
Building CommandClass.o
Building ControllerReplication.o
Building SwitchBinary.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Wait.o
Building Thread.o
Building Controller.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
building 'libopenzwave' extension
creating build
creating build/temp.linux-aarch64-2.7
creating build/temp.linux-aarch64-2.7/src-lib
creating build/temp.linux-aarch64-2.7/src-lib/libopenzwave
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-rSjPv1/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3:0: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>:0:0: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26:0,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:459:
openzwave/cpp/src/aes/aes.h:75:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:29891:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
src-lib/libopenzwave/libopenzwave.cpp:545:36: note: in definition of macro '__Pyx_PyBool_FromLong'
#define __Pyx_PyBool_FromLong(b) ((b) ? __Pyx_NewRef(Py_True) : __Pyx_NewRef(Py_False))
In file included from src-lib/libopenzwave/libopenzwave.cpp:464:0:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-aarch64-2.7
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-rSjPv1/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-rSjPv1/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-aarch64-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
copying build/lib.linux-aarch64-2.7/libopenzwave.so -> build/bdist.linux-aarch64/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-aarch64/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-aarch64/egg
running install_data
creating build/bdist.linux-aarch64/egg/config
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
writing build/bdist.linux-aarch64/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-aarch64.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-aarch64.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Extracting libopenzwave-0.3.1-py2.7-linux-aarch64.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.10.0
Best match: six 1.10.0
Adding six 1.10.0 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-aarch64-2.7/openzwave
creating build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/scene.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/__init__.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/value.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/option.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/node.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/singleton.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/group.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/controller.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/network.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/command.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/object.py -> build/bdist.linux-aarch64/egg/openzwave
byte-compiling build/bdist.linux-aarch64/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/object.py to object.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Searching for nose==1.3.7
Best match: nose 1.3.7
Adding nose 1.3.7 to easy-install.pth file
Installing nosetests script to /usr/local/bin
Installing nosetests-2.7 script to /usr/local/bin
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
Everything is successfully installed!
