je n’arrive pas à découvrir mon Roomba S9+,
J’ai 2 robots, un S9+ et un Braava M6.
Le M6 est bien découvert, mais pas le S9+
Quelqu’un a-t-il déjà rencontré ce problème et pourrait me dire comment le résoudre?
Log du daemon:
/var/www/html/plugins/kroomba/resources/kroomba/roomba/roomba.py:598: RuntimeWarning: coroutine 'Roomba._disconnect' was never awaited
self.loop.create_task(self._disconnect())
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
Exception in thread Thread-3:
File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner
self.run()
File "/usr/lib/python3.9/threading.py", line 892, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3591, in _thread_main
self.loop_forever(retry_first_connection=True)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1756, in loop_forever
rc = self._loop(timeout)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1164, in _loop
rc = self.loop_read()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1556, in loop_read
rc = self._packet_read()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 2439, in _packet_read
rc = self._packet_handle()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3039, in _packet_handle
return self._handle_connack()
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 3138, in _handle_connack
on_connect(
File "/var/www/html/plugins/kroomba/resources/kroomba/roomba/roomba.py", line 768, in broker_on_connect
client.subscribe(self.brokerCommand)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1491, in subscribe
raise ValueError('Invalid subscription filter.')
ValueError: Invalid subscription filter.
Exception in thread Thread-5:
self.run()
on_connect(
File "/var/www/html/plugins/kroomba/resources/kroomba/roomba/roomba.py", line 625, in on_connect
self.connected(True)
File "/var/www/html/plugins/kroomba/resources/kroomba/roomba/roomba.py", line 620, in connected
self.publish('status', 'Online' if self.roomba_connected else 'Offline at {}'.format(time.ctime()))
File "/var/www/html/plugins/kroomba/resources/kroomba/roomba/roomba.py", line 944, in publish
self.mqttc.publish(topic, message)
File "/usr/local/lib/python3.9/dist-packages/paho/mqtt/client.py", line 1233, in publish
raise ValueError('Publish topic cannot contain wildcards.')
ValueError: Publish topic cannot contain wildcards.
