Pas de connexion avec l'imprimante
Bonjour sous la pluie. J’essaie de faire fonctionner ton plugin. Je suis en 4.4.7 et mon imprimante est une MFC-5700DN. Je suis sur en debian11
voila ce que j’obtiens lorsque je lance la commande sudo pip3 show pyasn1
  File "/usr/bin/pip3", line 33, in <module>
    sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
  File "/usr/bin/pip3", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 790, in exec_module
  File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
    from pip._internal.cli.autocompletion import autocomplete
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
    from pip._internal.cli.main_parser import create_main_parser
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
    from pip._internal.cli import cmdoptions
  File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
    from pip._vendor.packaging.utils import canonicalize_name
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
    vendored("requests.packages.urllib3.contrib.pyopenssl")
  File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
    __import__(modulename, globals(), locals(), level=0)
  File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
  File "<frozen zipimport>", line 259, in load_module
  File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
  File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
    class X509StoreFlags(object):
  File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1575, in X509StoreFlags
    NOTIFY_POLICY = _lib.X509_V_FLAG_NOTIFY_POLICY
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_NOTIFY_POLICY'
Le système ne semble pas à jour.
Problème sans lien avec le plugin si c’est juste en tapant cette commande
Je suis d’accord avec toi. Tu as une idée pour le mettre à jour ?
Je suis sur un raspberry 4 et toutes les mises à jour du système sont faites
J’ai fait un essai pour voir sur mon autre jeedom (une atlas), et j’ai la même réponse
J’ai tenté:
sudo apt-get install python-pyasn1-doc
Résultat identique
Apt update / upgrade en ordre?
En fait même l’erreur qu’on voit n’aura pas d’impact sur le plugin car tu utilises des commandes système et que le plugin utilise utilise un environnement virtuel.
Sinon non je n’ai pas d’idée pq il y a cette erreur, sûrement un paquet python pas à jour
En cherchant sur l’erreur il n’y a aucun post qui aide? C’est une erreur qu’on voit assez régulièrement sur community
Désolé pour cette réponse tardive
Oui tout est en ordre et j’ai eu beau chercher… Pas très grave, je peux également avoir ces infos sur l’imprimante :wink:
Hello @fonzie73,
Je viens de publier une nouvelle beta, avec une grosse mise à jour de la bibliothèque python qui reconnait les différents modèles d’imprimantes.
Dit-moi si c’est OK, merci.
Bad
