J’ai essayé avec un scénario et via le panel.
Par exemple, je veux passer de hors gel à absent, je clique sur le panel :
ça mouline et j’ai :
[2023-08-24 10:06:32][DEBUG] : 🔹 execute Action : setmode sur: Gateway Netatmo
[2023-08-24 10:06:32][DEBUG] : changeHomeTherm action: away- endtime: - sur: Gateway Netatmo
Si j’annule le mode hors gel via l’app Netatmo :
[2023-08-24 10:10:34][DEBUG] : cron10 started
[2023-08-24 10:10:34][DEBUG] : 🔵 cronJob started from cron10 ***************** 2/10
[2023-08-24 10:10:35][DEBUG] : ******getDataRoom _Homeglobal: {"618434773f6d57509f4042b6":{"Home|618434773f6d57509f4042b6":{"naCat":"energy","home_name":"Home","boiler_anticipating":false,"boiler_status":false,"home_status":true,"temperature_control_mode":"heating","spm_duaration":120,"home_modetech":"hg","home_type":"house","therm_heating_energy":"elec","home_size":114,"thermPriority":"eco","anticipation_enabled":false,"home_modesp":false,"temperature_outdoor":22,"reachable":true,"home_rf":64,"home_rfstatus":"high","wifi_strength":25,"modules":{"70:ee:50:86:d7:6e":{"id":"70:ee:50:86:d7:6e","type":"NAPlug","name":"Relais","subtype":"TPG","setup_date":1638356890,"reachable":true,"modules_bridged":["04:00:00:86:e4:4c"],"schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"}],"firmware_revision":236,"hardware_version":229,"outdoor_temperature":24,"outdoor_temperature_time":1692860400,"last_energy_bilan_month":7,"last_energy_bilan_year":2023,"homekit_compatible":true,"max_modules_nb":21,"behavior":0,"therm_heating_algorithm":"simple_algo","pid_algo_period":18,"simple_heating_algo_deadband":4,"boiler_cable":false,"rf_strength":107,"wifi_strength":25,"rfpower":"high","wifipower":"full"},"70:ee:50:86:9a:38":{"id":"70:ee:50:86:9a:38","type":"NAPlug","name":"Relais","subtype":"TPG","setup_date":1638375378,"reachable":true,"modules_bridged":["04:00:00:86:bc:0a"],"schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"}],"firmware_revision":236,"hardware_version":229,"outdoor_temperature":24,"outdoor_temperature_time":1692860400,"last_energy_bilan_month":7,"last_energy_bilan_year":2023,"homekit_compatible":true,"max_modules_nb":21,"therm_heating_algorithm":"simple_algo","simple_heating_algo_deadband":4,"boiler_cable":false,"rf_strength":109,"wifi_strength":25,"rfpower":"high","wifipower":"full"}},"Plugs_Id":["70:ee:50:86:d7:6e","70:ee:50:86:9a:38"],"energie_modules":{"04:00:00:86:e4:4c":{"id":"04:00:00:86:e4:4c","type":"NATherm1","name":"Thermostat","setup_date":1638356891,"room_id":"2128202097","bridge":"70:ee:50:86:d7:6e","firmware_revision":76,"anticipating":false,"battery_level":3979,"boiler_status":false,"boiler_valve_comfort_boost":false,"reachable":true,"rf_strength":43,"battery_state":"high","config":[]},"04:00:00:86:bc:0a":{"id":"04:00:00:86:bc:0a","type":"NATherm1","name":"Thermostat","setup_date":1638375378,"room_id":"3289441794","bridge":"70:ee:50:86:9a:38","firmware_revision":76,"anticipating":false,"battery_level":3953,"boiler_status":false,"boiler_valve_comfort_boost":false,"reachable":true,"rf_strength":61,"battery_state":"high","config":[]}},"eqmodules":"[{\"id\":\"70:ee:50:86:d7:6e\",\"type\":\"NAPlug\",\"name\":\"Relais\",\"subtype\":\"TPG\",\"reachable\":true,\"modules_bridged\":[\"04:00:00:86:e4:4c\"],\"schedule_limits\":[{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"therm\"}],\"firmware_revision\":236,\"hardware_version\":229,\"outdoor_temperature_time\":1692860400,\"last_energy_bilan_month\":7,\"last_energy_bilan_year\":2023,\"homekit_compatible\":true,\"behavior\":0,\"therm_heating_algorithm\":\"simple_algo\",\"pid_algo_period\":18,\"simple_heating_algo_deadband\":4,\"boiler_cable\":false,\"rf_strength\":107,\"wifi_strength\":25,\"rfpower\":\"high\",\"wifipower\":\"full\"},{\"id\":\"70:ee:50:86:9a:38\",\"type\":\"NAPlug\",\"name\":\"Relais\",\"subtype\":\"TPG\",\"reachable\":true,\"modules_bridged\":[\"04:00:00:86:bc:0a\"],\"schedule_limits\":[{\"nb_zones\":16,\"nb_timeslots\":150,\"type\":\"therm\"}],\"firmware_revision\":236,\"hardware_version\":229,\"outdoor_temperature_time\":1692860400,\"last_energy_bilan_month\":7,\"last_energy_bilan_year\":2023,\"homekit_compatible\":true,\"therm_heating_algorithm\":\"simple_algo\",\"simple_heating_algo_deadband\":4,\"boiler_cable\":false,\"rf_strength\":109,\"wifi_strength\":25,\"rfpower\":\"high\",\"wifipower\":\"full\"}]","modules_types":["NAPlug"],"listplanning":"618434773f6d57509f4042b7|Vacance(Chauff);61a402a968713727636d7a84|Present(Chauff);61aa85d9ca12ef4c305fd5b8|Absent(Chauff);63712f345e74b6344b0f8a90|Nuit(Chauff);63e5397299e8fd1b5c088f6f|Teletravail(Chauff);63e75618c7fd63cf1d01d0e0|Eco(Chauff)","nowplanning":"Absent(Chauff)","nowplanid":"61aa85d9ca12ef4c305fd5b8","away_temp":18,"hg_temp":7,"plan_type":"therm","setpointmode_endtime":"Nouvel Ordre","rooms_modes":["hg","hg"],"roomsCount":2},"ASyncTime":"24-08-2023 10:10","2128202097|618434773f6d57509f4042b6":{"id":"2128202097","name":"Salon","type":"custom","module_ids":["04:00:00:86:e4:4c"],"modules":[{"id":"04:00:00:86:e4:4c","type":"NATherm1","name":"Thermostat","setup_date":1638356891,"room_id":"2128202097","bridge":"70:ee:50:86:d7:6e","firmware_revision":76,"anticipating":false,"battery_level":3979,"boiler_status":false,"boiler_valve_comfort_boost":false,"reachable":true,"rf_strength":43,"battery_state":"high","config":[],"battery_percent":92,"rfpower":"full"}],"therm_relay":"70:ee:50:86:d7:6e","true_temperature_available":true,"anticipation_type":"optimized","measure_offset_NAPlug_temperature":0,"measure_offset_NAPlug_estimated_temperature":1,"open_window":false,"reachable":true,"therm_setpoint_mode":"hg","therm_setpoint_start_time":1692805619,"A_syncTime":"24-08-2023 10:10","Rqst_stauts":"ok","naCat":"energy","room_modetech":"hg","room_modesp":false,"temperature_control_mode":"therm","relay_type":"NAPlug","relay_infos":"70:ee:50:86:d7:6e|NAPlug|Relais","modulesCount":1,"eqmodules":"[{\"id\":\"04:00:00:86:e4:4c\",\"type\":\"NATherm1\",\"name\":\"Thermostat\",\"setup_date\":1638356891,\"room_id\":\"2128202097\",\"bridge\":\"70:ee:50:86:d7:6e\",\"firmware_revision\":76,\"anticipating\":false,\"battery_level\":3979,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"reachable\":true,\"rf_strength\":43,\"battery_state\":\"high\",\"config\":[],\"battery_percent\":92,\"rfpower\":\"full\"}]","batterie":92,"room_rf":"full","listprofil":"Comfort;19|Nuit;17|Confort +;19|\u00c9co;18","nextprofil":"\u00c9co-18","nowprofil":"\u00c9co","nowprofil_name":"\u00c9co;18","nowprofil_temp":"18","nowprofil_mode":null,"nextprofil_temp":"18","profil_endtime":"28-08-2023 00:00","nextprofil_delay":5149,"nextprofil_tendance":0,"spRoom_starttime":"23-08-2023 17:46","spRoom_endtime":"Nouvel Ordre","temperature":26.4,"consigne":7,"room_anticipating":false,"powerRequest":0,"actif":false,"statustr":"Eteint"},"3289441794|618434773f6d57509f4042b6":{"id":"3289441794","name":"Entr\u00e9e","type":"lobby","module_ids":["04:00:00:86:bc:0a"],"modules":[{"id":"04:00:00:86:bc:0a","type":"NATherm1","name":"Thermostat","setup_date":1638375378,"room_id":"3289441794","bridge":"70:ee:50:86:9a:38","firmware_revision":76,"anticipating":false,"battery_level":3953,"boiler_status":false,"boiler_valve_comfort_boost":false,"reachable":true,"rf_strength":61,"battery_state":"high","config":[],"battery_percent":92,"rfpower":"high"}],"therm_relay":"70:ee:50:86:9a:38","true_temperature_available":true,"anticipation_type":"optimized","measure_offset_NAPlug_temperature":0,"measure_offset_NAPlug_estimated_temperature":1,"open_window":false,"reachable":true,"therm_setpoint_mode":"hg","therm_setpoint_start_time":1692805619,"A_syncTime":"24-08-2023 10:10","Rqst_stauts":"ok","naCat":"energy","room_modetech":"hg","room_modesp":false,"temperature_control_mode":"therm","relay_type":"NAPlug","relay_infos":"70:ee:50:86:9a:38|NAPlug|Relais","modulesCount":1,"eqmodules":"[{\"id\":\"04:00:00:86:bc:0a\",\"type\":\"NATherm1\",\"name\":\"Thermostat\",\"setup_date\":1638375378,\"room_id\":\"3289441794\",\"bridge\":\"70:ee:50:86:9a:38\",\"firmware_revision\":76,\"anticipating\":false,\"battery_level\":3953,\"boiler_status\":false,\"boiler_valve_comfort_boost\":false,\"reachable\":true,\"rf_strength\":61,\"battery_state\":\"high\",\"config\":[],\"battery_percent\":92,\"rfpower\":\"high\"}]","batterie":92,"room_rf":"high","listprofil":"Comfort;19|Nuit;17|Confort +;19|\u00c9co;18","nextprofil":"\u00c9co-18","nowprofil":"\u00c9co","nowprofil_name":"\u00c9co;18","nowprofil_temp":"18","nowprofil_mode":null,"nextprofil_temp":"18","profil_endtime":"28-08-2023 00:00","nextprofil_delay":5149,"nextprofil_tendance":0,"spRoom_starttime":"23-08-2023 17:46","spRoom_endtime":"Nouvel Ordre","temperature":26.8,"consigne":7,"room_anticipating":false,"powerRequest":0,"actif":false,"statustr":"Eteint"}},"apiHome":{"618434773f6d57509f4042b6":{"Data":{"capabilities":[{"name":"peak_and_off_peak_electricity_times","available":true}],"id":"618434773f6d57509f4042b6","name":"Home","altitude":193,"coordinates":[7.388303,48.009225],"country":"FR","timezone":"Europe\/Paris","city":"Sainte-Croix-en-Plaine","currency_code":"EUR","invitation_code":["91A0vw2ucVBcEcf6Mt","lCC3YXsNDq70xFvsGe"],"nb_users":2,"data_versions":{"users":0},"place_improved":false,"trust_location":false,"home_type":"house","therm_absence_notification":true,"therm_absence_autoaway":false,"rooms":[{"id":"2128202097","name":"Salon","type":"custom","module_ids":["04:00:00:86:e4:4c"],"modules":["04:00:00:86:e4:4c"],"therm_relay":"70:ee:50:86:d7:6e","true_temperature_available":true,"anticipation_type":"optimized","measure_offset_NAPlug_temperature":0,"measure_offset_NAPlug_estimated_temperature":1},{"id":"3289441794","name":"Entr\u00e9e","type":"lobby","module_ids":["04:00:00:86:bc:0a"],"modules":["04:00:00:86:bc:0a"],"therm_relay":"70:ee:50:86:9a:38","true_temperature_available":true,"anticipation_type":"optimized","measure_offset_NAPlug_temperature":0,"measure_offset_NAPlug_estimated_temperature":1},{"id":"1428766227","name":"Cuisine","type":"custom","anticipation_type":"default"},{"id":"644512910","name":"Chambre1","type":"custom","anticipation_type":"default"},{"id":"1863021600","name":"Ext\u00e9rieur","type":"custom","anticipation_type":"default"}],"modules":[{"id":"70:ee:50:86:d7:6e","type":"NAPlug","name":"Relais","subtype":"TPG","setup_date":1638356890,"reachable":true,"modules_bridged":["04:00:00:86:e4:4c"],"schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"}],"firmware_revision":236,"hardware_version":229,"outdoor_temperature":24,"outdoor_temperature_time":1692860400,"last_energy_bilan_month":7,"last_energy_bilan_year":2023,"homekit_compatible":true,"max_modules_nb":21,"behavior":0,"therm_heating_algorithm":"simple_algo","pid_algo_period":18,"simple_heating_algo_deadband":4},{"id":"04:00:00:86:e4:4c","type":"NATherm1","name":"Thermostat","setup_date":1638356891,"room_id":"2128202097","bridge":"70:ee:50:86:d7:6e","firmware_revision":76},{"id":"70:ee:50:86:9a:38","type":"NAPlug","name":"Relais","subtype":"TPG","setup_date":1638375378,"reachable":true,"modules_bridged":["04:00:00:86:bc:0a"],"schedule_limits":[{"nb_zones":16,"nb_timeslots":150,"type":"therm"}],"firmware_revision":236,"hardware_version":229,"outdoor_temperature":24,"outdoor_temperature_time":1692860400,"last_energy_bilan_month":7,"last_energy_bilan_year":2023,"homekit_compatible":true,"max_modules_nb":21,"therm_heating_algorithm":"simple_algo","simple_heating_algo_deadband":4},{"id":"04:00:00:86:bc:0a","type":"NATherm1","name":"Thermostat","setup_date":1638375378,"room_id":"3289441794","bridge":"70:ee:50:86:9a:38","firmware_revision":76}],"temperature_control_mode":"heating","therm_schedules":[{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}]}],"name":"Vacance","default":false,"away_temp":18.5,"hg_temp":7,"id":"618434773f6d57509f4042b7","type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":600},{"zone_id":1,"m_offset":1380},{"zone_id":0,"m_offset":2040},{"zone_id":1,"m_offset":2820},{"zone_id":0,"m_offset":3480},{"zone_id":1,"m_offset":4260},{"zone_id":0,"m_offset":4920},{"zone_id":1,"m_offset":5700},{"zone_id":0,"m_offset":6360},{"zone_id":1,"m_offset":7140},{"zone_id":0,"m_offset":7800},{"zone_id":1,"m_offset":8580},{"zone_id":0,"m_offset":9240},{"zone_id":1,"m_offset":10020}],"zones":[{"name":"Confort2","id":6088,"type":4,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3289441794","temp":19.5},{"room_id":"2128202097","temp":19.5}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18.5}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}]}],"name":"Present","default":false,"away_temp":18,"hg_temp":7,"id":"61a402a968713727636d7a84","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":17},{"room_id":"2128202097","temp":17}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}]}],"name":"Absent","default":false,"away_temp":18,"hg_temp":7,"id":"61aa85d9ca12ef4c305fd5b8","selected":true,"type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}]}],"name":"Nuit","default":false,"away_temp":12,"hg_temp":7,"id":"63712f345e74b6344b0f8a90","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}]}],"name":"Teletravail","default":false,"away_temp":12,"hg_temp":7,"id":"63e5397299e8fd1b5c088f6f","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":18},{"room_id":"3289441794","temp":18}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":15},{"room_id":"3289441794","temp":15}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":18}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}]}],"name":"Eco","default":false,"away_temp":12,"hg_temp":7,"id":"63e75618c7fd63cf1d01d0e0","type":"therm"}],"therm_mode":"hg","therm_heating_energy":"elec","home_size":114,"therm_setpoint_default_duration":120,"anticipation":false,"outdoor_temperature_source":"gefs","therm_heating_priority":"eco","open_window_detection":false,"schedules":[{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":17},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":16},{"id":"3289441794","therm_setpoint_temperature":16}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":17},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":16},{"id":"3289441794","therm_setpoint_temperature":16}]}],"name":"Vacance","default":false,"away_temp":18.5,"hg_temp":7,"id":"618434773f6d57509f4042b7","type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":600},{"zone_id":1,"m_offset":1380},{"zone_id":0,"m_offset":2040},{"zone_id":1,"m_offset":2820},{"zone_id":0,"m_offset":3480},{"zone_id":1,"m_offset":4260},{"zone_id":0,"m_offset":4920},{"zone_id":1,"m_offset":5700},{"zone_id":0,"m_offset":6360},{"zone_id":1,"m_offset":7140},{"zone_id":0,"m_offset":7800},{"zone_id":1,"m_offset":8580},{"zone_id":0,"m_offset":9240},{"zone_id":1,"m_offset":10020}],"zones":[{"name":"Confort2","id":6088,"type":4,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":19},{"id":"2128202097","therm_setpoint_temperature":19}]},{"name":"Confort","id":0,"type":0,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":19},{"id":"2128202097","therm_setpoint_temperature":19}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3289441794","temp":19.5},{"room_id":"2128202097","temp":19.5}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":19.5},{"id":"2128202097","therm_setpoint_temperature":19.5}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18.5}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18.5}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18}]}],"name":"Present","default":false,"away_temp":18,"hg_temp":7,"id":"61a402a968713727636d7a84","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":19},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":17},{"room_id":"2128202097","temp":17}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":17},{"id":"2128202097","therm_setpoint_temperature":17}]},{"name":"Confort +","id":3,"type":8,"rooms_temp":[{"room_id":"3289441794","temp":19},{"room_id":"2128202097","temp":19}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":19},{"id":"2128202097","therm_setpoint_temperature":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18}]}],"name":"Absent","default":false,"away_temp":18,"hg_temp":7,"id":"61aa85d9ca12ef4c305fd5b8","selected":true,"type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":19},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":17},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":16},{"id":"3289441794","therm_setpoint_temperature":16}]},{"name":"Nuit","id":1,"type":1,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18}]}],"name":"Nuit","default":false,"away_temp":12,"hg_temp":7,"id":"63712f345e74b6344b0f8a90","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":19},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":19},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":16}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":16},{"id":"3289441794","therm_setpoint_temperature":16}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":17},{"room_id":"3289441794","temp":19}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":17},{"id":"3289441794","therm_setpoint_temperature":19}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18}]}],"name":"Teletravail","default":false,"away_temp":12,"hg_temp":7,"id":"63e5397299e8fd1b5c088f6f","type":"therm"},{"timetable":[{"zone_id":4,"m_offset":0}],"zones":[{"name":"Comfort","id":0,"type":0,"rooms_temp":[{"room_id":"2128202097","temp":18},{"room_id":"3289441794","temp":18}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":18},{"id":"3289441794","therm_setpoint_temperature":18}]},{"name":"Night","id":1,"type":1,"rooms_temp":[{"room_id":"2128202097","temp":15},{"room_id":"3289441794","temp":15}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":15},{"id":"3289441794","therm_setpoint_temperature":15}]},{"name":"Comfort+","id":3,"type":8,"rooms_temp":[{"room_id":"2128202097","temp":16},{"room_id":"3289441794","temp":18}],"rooms":[{"id":"2128202097","therm_setpoint_temperature":16},{"id":"3289441794","therm_setpoint_temperature":18}]},{"name":"\u00c9co","id":4,"type":5,"rooms_temp":[{"room_id":"3289441794","temp":18},{"room_id":"2128202097","temp":18}],"rooms":[{"id":"3289441794","therm_setpoint_temperature":18},{"id":"2128202097","therm_setpoint_temperature":18}]}],"name":"Eco","default":false,"away_temp":12,"hg_temp":7,"id":"63e75618c7fd63cf1d01d0e0","type":"therm"}]},"Status":{"id":"618434773f6d57509f4042b6","modules":[{"boiler_cable":false,"firmware_revision":236,"hardware_version":229,"id":"70:ee:50:86:d7:6e","rf_strength":107,"type":"NAPlug","wifi_strength":25},{"anticipating":false,"battery_level":3979,"boiler_status":false,"boiler_valve_comfort_boost":false,"firmware_revision":76,"id":"04:00:00:86:e4:4c","reachable":true,"rf_strength":43,"type":"NATherm1","bridge":"70:ee:50:86:d7:6e","battery_state":"high"},{"boiler_cable":false,"firmware_revision":236,"hardware_version":229,"id":"70:ee:50:86:9a:38","rf_strength":109,"type":"NAPlug","wifi_strength":25},{"anticipating":false,"battery_level":3953,"boiler_status":false,"boiler_valve_comfort_boost":false,"firmware_revision":76,"id":"04:00:00:86:bc:0a","reachable":true,"rf_strength":61,"type":"NATherm1","bridge":"70:ee:50:86:9a:38","battery_state":"high"}],"rooms":[{"anticipating":false,"heating_power_request":0,"id":"2128202097","open_window":false,"reachable":true,"therm_measured_temperature":26.4,"therm_setpoint_mode":"hg","therm_setpoint_start_time":1692805619,"therm_setpoint_temperature":7},{"anticipating":false,"heating_power_request":0,"id":"3289441794","open_window":false,"reachable":true,"therm_measured_temperature":26.8,"therm_setpoint_mode":"hg","therm_setpoint_start_time":1692805619,"therm_setpoint_temperature":7}]}}}}
[2023-08-24 10:10:35][DEBUG] : postSave CONFIG temperature_ext cmd Avalaible ...
[2023-08-24 10:10:37][DEBUG] : postSave CONFIG temperature_ext cmd Avalaible ...
[2023-08-24 10:10:39][DEBUG] : | getDataRoom [Gateway Netatmo] temperature_control_mode Undefined cmd
[2023-08-24 10:10:39][DEBUG] : | getDataRoom Setting Home-cmd [Gateway Netatmo] Success...
[2023-08-24 10:10:39][WARNING] : syncMeteoCmds No meteoData avalaible
[2023-08-24 10:10:39][DEBUG] : ┌─cronJob Thermostat Local
[2023-08-24 10:10:39][DEBUG] : └─cronJob Thermostat Local end
[2023-08-24 10:10:39][DEBUG] : ┌─cronJob Gateway Netatmo
[2023-08-24 10:10:39][DEBUG] : └─cronJob Gateway Netatmo end
[2023-08-24 10:10:39][DEBUG] : ┌─cronJob Thermostat Salon
[2023-08-24 10:10:39][DEBUG] : └─cronJob Thermostat Salon end
[2023-08-24 10:10:39][DEBUG] : **** cronJob End...
[2023-08-24 10:11:12][INFO] : na_whook Webhook Notif : Home|618434773f6d57509f4042b6 ** Mode set to schedule
[2023-08-24 10:11:15][DEBUG] : triggerEvent start : {"naEnergie_id":"Home|618434773f6d57509f4042b6","event_id":"262516","value":"Home|618434773f6d57509f4042b6 ** Mode set to schedule","datetime":"2023-08-24 10:11:12","listener_id":"24"}
[2023-08-24 10:11:20][DEBUG] : triggerEvent Msg : Gateway Netatmo[Mode set to schedule]
[2023-08-24 10:11:20][DEBUG] : triggerEvent others action In progress :
[2023-08-24 10:11:21][DEBUG] : ******getDataRoom _Homeglobal: {"618434773f6d57509f4042b6":{"Home|618434773f6d57509f4042b6":{"naCat":"energy","home_name":"Home","boiler_anticipating":false,"boiler_status":false,"home_status":true,"temperature_control_mode":"heating","spm_duaration":120,"home_modetech":"schedule","home_type":"house","therm_heating_energy":"elec","home_size":114,"thermPriority":"eco","anticipation_enabled":false,"home_modesp":false,"temperature_outdoor":22,"reachable":true,"home_rf":64,"home_rfstatus":"high","wifi_strength":24,"modules":{"70:ee:50:86:d7:6e":{"id":"70:ee:50:86:d7:6e","type":"NAPlug","name":"Relais","subtype":"TPG","setup_date":1638356890,"reachable":true,"modules_bridged":["04:00:00:86:e4:4c"],"schedule_limits": [data trop long pour le forum]
[2023-08-24 10:11:26][DEBUG] : | getDataRoom Setting Home-cmd [Gateway Netatmo] Success...
Si je passe en hors gel via panel :
[2023-08-24 10:13:13][DEBUG] : 🔹 execute Action : setmode sur: Gateway Netatmo
[2023-08-24 10:13:13][DEBUG] : changeHomeTherm action: hg- endtime: - sur: Gateway Netatmo
J’avais mis 1mn pour test en scénario. Oui Gateway Netatmo est mon Home.
