[Partage] Solid Gauge en 4.1?
tu as un moyen pour ne pas jouer avec le core jeedom
tu attribues une variable css root, celle-ci sera par dessus .highcharts-color-0 du core
concretement
<style>
    :root{
 --link-colorX:white;
.cmd[data-cmd_uid=#uid#] .highcharts-color-0 {
     fill: var(--link-colorX);
et ensuite dans le script à la suite de l’update
  jeedom.cmd.update['#id#'] = function(_options) {
    var cmd = $('.cmd[data-cmd_uid=#id#]');
    var cmd2 = $(".cmd[data-cmd_id=#id#] .gaugearnog23");
    var val = _options.display_value;
       if (val <= 5){
cmd2.css({'--link-colorX': color1});
   } else if (val <= 20){
cmd2.css({'--link-colorX': color2});
     } else {
cmd2.css({'--link-colorX': color3});
si tu veux peaufiner
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#" title="Date de valeur : #valueDate#<br/>Date de collecte : #collectDate#" >
<div class="title #hide_name#">
  <span class="cmdName">#name_display#</span>
</div>
<div class="content-sm">
  <div class="gaugearnog23 cursor #history#" data-cmd_id="#id#"></div>
</div>
<div class="value">
  <span class="timeCmd label label-default #history#" data-type="info"></span>
</div>
<div class="cmdStats #hide_history#">
  <span title='{{Min}}' class='tooltips'>#minHistoryValue#</span>|<span title='{{Moyenne}}' class='tooltips'>#averageHistoryValue#</span>|<span title='{{Max}}' class='tooltips'>#maxHistoryValue#</span> <i class="#tendance#"></i>
</div>
<style>
    :root{
  .gaugearnog23 {
    width: 105px;
    height: 105px;
.gaugearnog23 .highcharts-pane {
 /*   fill: var(--el-defaultColor);
 */  fill: #333333;
  body[data-theme="core2019_Dark"] .gaugearnog23 .highcharts-tick {
    stroke: rgb(38, 38, 38);
  body[data-theme="core2019_Light"] .gaugearnog23 .highcharts-tick {
    stroke: rgb(249, 249, 250);
  .gaugearnog23 .highcharts-container .highcharts-axis-line {
stroke: transparent;
/*        stroke: none !important; */
  .gaugearnog23 .highcharts-yaxis-grid .highcharts-grid-line {
</style>
<script>
  var color1 = ('#color1#' != '#'+'color1#') ? '#color1#' : 'rgb(0, 255, 0)';
  var color2 = ('#color2#' != '#'+'color2#') ? '#color2#' : 'rgb(255, 255, 0)';
  var color3 = ('#color3#' != '#'+'color3#') ? '#color3#' : 'rgb(255, 0, 0)';
       if (val <= 5){
     } else {
    cmd.attr('title','{{Date de valeur}} : '+_options.valueDate+'<br/>{{Date de collecte}} : '+_options.collectDate)
    $('.cmd[data-cmd_uid=#uid#] .gaugearnog23').highcharts().series[0].points[0].update(_options.display_value)
    if('#time#' == 'duration'){
	  jeedom.cmd.displayDuration(_options.valueDate, cmd.find('.timeCmd'));
    else {
      cmd.find('.timeCmd').parent().remove();
  if (is_numeric('#state#')) {
    $('.cmd[data-cmd_uid=#uid#] .gaugearnog23').empty().highcharts({
      chart: {
        style: {
          fontFamily: 'Roboto',
        type: 'solidgauge',
        plotBackgroundColor: null,
        plotBackgroundImage: null,
               backgroundColor: null,
        plotBorderWidth: 0,
        plotShadow: false,
        height: 106,
        spacingTop: 0,
        spacingLeft: 0,
        spacingRight: 0,
        spacingBottom: 0,
        borderWidth : 0
      title: null,
      pane: {
        center: ['50%', '50%'],
        startAngle: 0,
        endAngle: 360,
        background: {
    innerRadius: '0%',
          outerRadius: '100%',
          shape: 'arc',
          borderWidth: 0
      tooltip: {
        enabled: false
      // the value axis
      yAxis: {
        lineWidth: 0,
        tickPositions: [],
        labels : {enabled: false},
		min: ('#minValue#' == '') ? 0 : parseInt('#minValue#'),
        max: ('#maxValue#' == '') ? 100 : parseInt('#maxValue#'),
        zIndex: 6,
        title: {
          text: ''
      plotOptions: {
        solidgauge: {
          dataLabels: {
            y: 9,
            borderWidth: 0,
            useHTML: true
          rounded: true
      credits: {
        enabled: false
      exporting : {
        enabled: false
      series: [{
        data: [Math.round(parseFloat('#state#') * 10) / 10],
        radius: '90%',
        innerRadius: '70%',
        dataLabels: {
          y: -30,
          format: '<span style="color: white!important; font-size: 34px !important;">{y}</span> <span style="color: white!important; font-size: 12px; position: relative; top: -8px;">#unite#</span>'
  } else {
    $('.cmd[data-cmd_uid=#uid#] .gaugearnog23').append('<center><span class="label label-danger">#state#</span></center>')
</script>
</div>
l’inspiration « allociné »
