OK merci, je comprend mieux mon problème. Du coup j’ai trouvé la correspondance avec les nouveaux paramètres. Malheureusement impossible d’envoyer 300 sur le paramètre 5 par exemple cela fait planter le plugin. J’ai voir pour essayer de bidouiller le config.
| Param ID V1 | Param ID V2 | Description | Size | Values | Units | Default value | Remark |
| 1 | 6 | Plug meter reporting on/off | 1 | 0 (disable) or 1 (enable) | - | 1 | Enable or disable the reporting function |
| 2 | 7 | Plug meter reporting interval | V1: 2 | 1–65535 | Seconds | 300 | Time in seconds between every report to the host |
| V2: 2 | 30–32767 | Seconds | 300 | ||||
| 3 | 8 | Maximum current output | 1 | 1–16 | Amp | 16 | Maximum current the plug will supply. V1 will stay on and turn yellow, V2 will cut-off |
| 4 | 10 | Maximum current alarm threshold | 1 | 1–15 | Amp | 15 | Value must be less that the maximum output value! LED will turn yellow and alarm sent |
| 5 | 3 | Led Display Enable | 1 | 0 (disable) or 1 (enable) | - | Enable or disable the LED indicator | |
| 6 | 9 | Plug meter report on current change | V1: 1 | 1–100 | % | 5 | Percentage of current change that will trigger report |
| V2: 2 | 1–1600 | Amp | 50 | Amount of current change that will trigger report where 1 = 0.01A, 1600 = 16A | |||
| 7 | 1 | Remember Relay ON/OFF status | 1 | 0 (No) or 1 (Yes) | - | 1 | Enable or disable the previous state after power loss |
| 8 | 4 | Configure Plug Time switch Function | 1 | 0 (disable) or 1 (enable) | - | 0 | Enable or disable the switching timer function |
| 9 | 5 | Configure Time switch Period | 2 | 0–32767 | Seconds | 120 | Specify the switching timer value |
| 10 | 2 | Button On/Off Enable | 1 | 0 (disable) or 1 (enable) | - | 1 | Enable or disable the manual switch button |
