BugReport
Bonjour, je suis en Jeedom Alpha 4.5 sur Debian 11.11 et tout fonctionne bien.
Sauf que j’ai voulu mettre le core à jour à l’instant (pas fait depuis le 15 septembre) et après avoir installé la nouvelle version 4.5 j’ai un bug sur la page de « Mises à jour » dans l’onglet Core et plugins elle reste vierge avec le message suivant :
core/ajax/update.ajax.php : TypeError /error: Cannot read properties of undefined (reading ‹ changelog ›) /async:true /type:POST /dataType:json /action:all
Unknown error
Page : index.php?v=d&p=update#coreplugin
Voici le log de la mise à jour :
[START UPDATE]
[PROGRESS][1]
****Update from 4.5 (2024-10-02 12:47:09)****
Parameters : {"preUpdate":"0","backup::before":"0","core":"1","force":"0","plugins":"0","update::reapply":""}
Send begin of update event...OK
[PROGRESS][5]
Check rights...OK
[PROGRESS][10]
[PROGRESS][15]
Download url : https://github.com/jeedom/core/archive/alpha.zip
Download in progress...--2024-10-02 12:47:10-- https://github.com/jeedom/core/archive/alpha.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/alpha [following]
--2024-10-02 12:47:10-- https://codeload.github.com/jeedom/core/zip/refs/heads/alpha
Resolving codeload.github.com (codeload.github.com)... 140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K ........ ........ ........ ........ ........ ..
...... 6.89M
3072K ........ ........ ........ ........ ........ ........ 8.12M
6144K ........ ........ ........ ........ ........ ........ 7.02M
9216K ........ ........ ........ ...
..... ........ ........ 10.1M
12288K ........ ........ ........ ........ ........ ........ 5.43M
15360K ........ ........ ........ ........ ........ ........ 9.78M
18432K ........ ..
...... ........ ........ ........ ........ 10.3M
21504K ........ ........ ........ ........ ........ ........ 29.1M
24576K ........ ........ ........ ........ ........ ........ 17.5M
27648K ........ ........ ........ ........ ........ ........ 46.5M
30720K ........ ........ ........ ........ ........ ........ 33.4M
33792K ........ ........ ........ ........ ........ ........ 26.5M
36864K ........ ........ ........ ........ ........ ........ 24.1M
39936K ........ ........ ........ ........ ....
.... ........ 16.0M
43008K ........ ........ ........ ........ ........ ........ 5.35M
46080K ........ ........ ........ ........ ........ ........ 19.2M
49152K ........ ........ ........ ........ ........ ........ 17.6M
52224K ........ ........ ........ ..
...... ........ ........ 28.9M
55296K ........ ........ ........ ........ ........ ........ 16.7M
58368K ........ ........ ........ ........ ........ ........ 34.9M
61440K ........ ........ ........ ........ ........ ........ 17.3M
64512K ........ ........ ........ ........ ........ ........ 29.7M
67584K ........ ........ ........ ........ ........ ........ 25.2M
70656K ........ ........ ........ ........ ........ ........ 20.0M
73728K ........ ........ ........ ........ ........ ........ 26.9M
76800K ......
.. ........ ........ ........ ........ ........ 19.6M
79872K ........ ........ ........ ........ 22.0M=5.7s
2024-10-02 12:47:16 (14.1 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [83943831]
[PROGRESS][25]
OK
Cleaning folders...OK
[PROGRESS][30]
Create temporary folder...OK
[PROGRESS][35]
Unzip in progress...OK
[PROGRESS][40]
Clean temporary files (tmp)...OK
Disable all task
kill: (23942): No such process
kill: (23515): No such process
kill: (23888): No such process
kill: (23911): No such process
kill: (23810): No such process
kill: (45231): No such process
kill: (23935): No such process
. OK
Disable all scenario................................................
..................................................................... OK
[PROGRESS][45]
Remove vendor folder (not use anymore)...OK
[PROGRESS][46]
Update modification date of unzip file...OK
[PROGRESS][47]
Moving files...Ignore file /tmp/jeedom_unzip/core-alpha///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/pt_PT/noteVersion.md because size is 0
OK
[PROGRESS][50]
Remove temporary files...OK
[PROGRESS][52]
Remove useless files...
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install/../script/*': No such file or directory
OK
[PROGRESS][53]
Update composer file...
OK
[PROGRESS][58]
Update jeedom information date...
OK
[PROGRESS][59]
[PROGRESS][60]
Check jeedom consistency...
[START CONSISTENCY]
[START CHECK AND FIX DB]
[END CHECK AND FIX DB]
Check jeedom package...OK
Check jeedom database...OK
Check crons...
Check filesystem right...
OK
Check jeedom object...
OK
Check jeedom cmd...
OK
Set cache hour...OK
Check composer...OK
Check nodejs...
npm warn using --force Recommended protections disabled.
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (2.2.4).
lsb-release is already the newest version (11.1.0).
git is already the newest version (1:2.30.2-1+deb11u3).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
[Check Version NodeJS actuelle : v20.17.0 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Clean npm cache
OK
Check apache security file...[END CONSISTENCY]
OK
Check update...OK
***************Jeedom is up to date in 4.5***************
[PROGRESS][75]
[PROGRESS][90]
Check update
OK
[PROGRESS][95]
Enable scenario : OK
Enable task : OK
Check Network Conf : OK
[PROGRESS][100]
Launch cron dependancy plugins...OK
Send end of update event...OK
Update duration : 23s
[END UPDATE SUCCESS]
une idée ?
