Suite a un plantage de Jeedom
J’ai effectué la restauration du backup : sudo php /var/www/html/install/restore.php
[END Restore Success]
Mais, depuis, dans mon browser j’ai cette page qui s’affiche à la place de l’acceuil jeedom
<?php
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
try {
//no config, install Jeedom!
if (!file_exists(__DIR__ . '/core/config/common.config.php')) {
header("location: install/setup.php");
//dunno desktop or mobile:
if (!isset($_GET['v'])) {
$useragent = (isset($_SERVER["HTTP_USER_AGENT"])) ? $_SERVER["HTTP_USER_AGENT"] : 'none';
$getParams = (stristr($useragent, "Android") || strpos($useragent, "iPod") || strpos($useragent, "iPhone") || strpos($useragent, "Mobile") || strpos($useragent, "WebOS") || strpos($useragent, "mobile") || strpos($useragent, "hp-tablet"))
? 'm' : 'd';
foreach ($_GET AS $var => $value) {
if(is_array($value)){
continue;
$getParams .= '&' . $var . '=' . $value;
$url = 'index.php?v=' . trim($getParams, '&');
if (headers_sent()) {
echo '<script type="text/javascript">';
echo "window.location.href='$url';";
echo '</script>';
} else {
exit(header('Location: ' . $url));
die();
require_once __DIR__ . "/core/php/core.inc.php";
if (isset($_GET['v']) && $_GET['v'] == 'd') {
if (isset($_GET['modal'])) {
try {
include_file('core', 'authentification', 'php');
if (!isConnect()) {
throw new Exception('{{401 - Accès non autorisé}}');
include_file('desktop', init('modal'), 'modal', init('plugin'));
} catch (Exception $e) {
ob_end_clean();
echo '<div class="alert alert-danger div_alert">';
echo translate::exec(displayException($e), 'desktop/' . init('p') . '.php');
echo '</div>';
} catch (Error $e) {
ob_end_clean();
echo '</div>';
} elseif (isset($_GET['configure'])) {
include_file('plugin_info', 'configuration', 'configuration', init('plugin'));
} elseif (isset($_GET['ajax']) && $_GET['ajax'] == 1) {
try {
$title = config::byKey('product_name');
if (init('m') != '') {
try {
$plugin = plugin::byId(init('m'));
if (is_object($plugin)) {
$title = $plugin->getName() . ' - '.config::byKey('product_name');
include_file('desktop', init('p'), 'php', init('m'));
ob_end_clean();
echo '</div>';
ob_end_clean();
echo '</div>';
} else {
include_file('desktop', 'index', 'php');
//page title:
try {
if ( init('p') != 'message' && !isset($_GET['configure']) && !isset($_GET['modal']) ) {
$title = pageTitle(init('p')) . ' - ' . config::byKey('product_name');
echo '<script>';
echo 'document.title = "' . $title . '"';
echo '</script>';
} elseif (isset($_GET['v']) && $_GET['v'] == 'm') {
$_fn = 'index';
$_type = 'html';
$_plugin = '';
$_fn = init('modal');
$_type = 'modalhtml';
$_plugin = init('plugin');
} elseif (isset($_GET['p']) && isset($_GET['ajax'])) {
$_fn = $_GET['p'];
$_plugin = isset($_GET['m']) ? $_GET['m'] : $_plugin;
include_file('mobile', $_fn, $_type, $_plugin);
} else {
echo "Erreur : veuillez contacter l'administrateur";
echo $e->getMessage();
J’ai restauré un fichier plus ancien en pensant que jeedom était déjà corrompu lors du dernier backup, mais même problème
j’ai supprimer, reinstaller apache et les dépendance, pas de changement.
Je suis sous raspberri pi3+ avec raspbian.
Le reste fonctionne, comme Motioneye sur le port 8765
Quelqu’un aurait une idée?
D’avance, merci
