Je continue de faire le tour de mon jeedom après maj en debian 11. Dans la vérification des des packages systeme j’ai le pack libavcodec-extra qui est NOK.
Quand je veux corrigé j’ai le log suivant :
+ sudo apt update
Hit:1 http://ftp.fr.debian.org/debian bullseye InRelease
Hit:2 http://ftp.fr.debian.org/debian bullseye-updates InRelease
Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libavcodec-extra
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libavcodec-extra58 : Depends: libavutil56 (= 7:4.3.5-0+deb11u1) but 7:4.3.6-0+deb11u1 is to be installed
Depends: libswresample3 (= 7:4.3.5-0+deb11u1) but 7:4.3.6-0+deb11u1 is to be installed
Conflicts: libavcodec58
E: Unable to correct problems, you have held broken packages.
Cela n’a pas l’ai d’empêcher Gcast de fonctionner.
