Origine de ce log http.error?
helloo. comme ca, vous sauriez de quoi pourrait provenir ces (nouvelles) entrées trèèès régulières dans le log http.error? mercii
0000|[Tue Feb 28 07:41:53.123619 2023] [php7:notice] [pid 2534195] [client 127.0.0.1:58326] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0001|[Tue Feb 28 07:41:53.422474 2023] [php7:notice] [pid 2211873] [client 127.0.0.1:58328] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0002|[Tue Feb 28 07:41:54.311809 2023] [php7:notice] [pid 2270628] [client 127.0.0.1:58336] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0003|[Tue Feb 28 07:42:18.345141 2023] [php7:notice] [pid 2270530] [client 127.0.0.1:58530] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0004|[Tue Feb 28 07:42:18.641079 2023] [php7:notice] [pid 2534195] [client 127.0.0.1:58534] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0005|[Tue Feb 28 07:42:19.539029 2023] [php7:notice] [pid 2211873] [client 127.0.0.1:58538] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0006|[Tue Feb 28 07:43:20.849501 2023] [php7:notice] [pid 2006187] [client 127.0.0.1:58932] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0007|[Tue Feb 28 07:43:21.440048 2023] [php7:notice] [pid 2545039] [client 127.0.0.1:58940] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0008|[Tue Feb 28 07:43:22.641103 2023] [php7:notice] [pid 2305761] [client 127.0.0.1:58958] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0009|[Tue Feb 28 07:44:45.294394 2023] [php7:notice] [pid 2532604] [client 127.0.0.1:59412] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0010|[Tue Feb 28 07:44:45.592994 2023] [php7:notice] [pid 2545039] [client 127.0.0.1:59414] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0011|[Tue Feb 28 07:44:46.497140 2023] [php7:notice] [pid 2270628] [client 127.0.0.1:59488] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
Plugins : broadlink[stable, market, 2022-10-01 01:01:04], ics[stable, market, 2022-05-01 21:18:19], camera[stable, market, 2022-02-11 01:17:03], cloudsyncpro[stable, market, 2020-04-06 03:14:16], googlecast[stable, market, 2020-12-24 01:10:04], gsl[stable, market, 2022-10-21 01:15:42], gsh[stable, market, 2022-09-13 08:41:31], heatzy[stable, market, 2020-02-18 04:53:53], luna[stable, market, 2023-01-27 01:11:33], maillistener[stable, market, 2022-07-09 14:02:26], mqtt2[stable, market, 2023-01-14 17:02:45], ntfy[stable, market, 2022-10-29 01:05:14], nuki[stable, market, 2022-03-10 11:55:42], openvpn[stable, market, 2023-02-17 18:18:17], rfxcom[stable, market, 2022-09-27 01:02:45], script[stable, market, 2022-10-19 01:17:56], switchbot[stable, market, 2021-01-19 01:06:00], tahoma[stable, market, 2023-02-04 10:20:44], viessmannIot[stable, market, 2023-02-18 15:46:45], virtual[stable, market, 2022-10-19 01:18:07], wifilightV2[stable, market, 2023-02-23 20:02:11], xiaomihome[stable, market, 2022-06-06 01:02:25], zwavejs[stable, market, 2023-02-15 01:03:17], zigbee[stable, market, 2023-01-26 19:51:24],
Service Pack : Service Pack Power Zigbee
Page : index.php?v=d&p=log
Jeedom_version : 4.3.15
Uname : Linux JeedomLuna 4.4.194 #101 SMP Wed Sep 14 01:49:23 UTC 2022 aarch64 GNU/Linux
En attendant une meilleur réponse,
Vous pouvez essayer ceci
Réglages > Système > Configuration
>_OS/DB
Vérifications Système
'>_Rétablissement des droits des dossiers et fichiers
en attendant une vrai réponse, vous pourriez trouver quelle source génère ce message en cherchant quel fichier contient ce message.
Réglages / Système / Configuration
Onglet tout à droite : >_OS/DB
2ème bouton rouge : Administration système
Dans le champ de saisie tapez :
grep -rn --include=*.php 'file created in the system' /var/www/html/plugins
Grep est un outil de recherche de chaine de caractères. Cette commande recherche « file created in the system » dans les fichier *.php sous le répertoires « /var/www/html/plugins » et ses sous-répertoires et renvoie le nom de fichier avec le numéro de ligne où il trouve ça.
merci pour vos indications. j’ai passé les logs non plus en warning mais en debug et j’obtiens peutetre l’origine de ces entrées vu que c’est au même moment et trèèès souvent. je vais donc creuser dans cette direction. je clos
0163|[Wed Mar 01 10:02:33.961504 2023] [php7:notice] [pid 2285135] [client 192.168.1.29:43643] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0164|[Wed Mar 01 10:02:34.068216 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0165|[Wed Mar 01 10:02:34.286239 2023] [php7:notice] [pid 1106040] [client 192.168.1.65:48439] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0166|[Wed Mar 01 10:02:35.056292 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0167|[Wed Mar 01 10:02:35.178417 2023] [php7:notice] [pid 2285135] [client 192.168.1.29:43643] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0168|[Wed Mar 01 10:02:35.576255 2023] [php7:notice] [pid 793944] [client 127.0.0.1:48904] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0169|[Wed Mar 01 10:02:35.871199 2023] [php7:notice] [pid 2219789] [client 127.0.0.1:48906] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0170|[Wed Mar 01 10:02:36.173363 2023] [php7:notice] [pid 2285135] [client 192.168.1.29:43643] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0171|[Wed Mar 01 10:02:36.324480 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0172|[Wed Mar 01 10:02:36.770052 2023] [php7:notice] [pid 1483710] [client 127.0.0.1:48910] PHP Notice:  Unknown: file created in the system's temporary directory in Unknown on line 0
0173|[Wed Mar 01 10:02:37.308887 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0174|[Wed Mar 01 10:02:37.383039 2023] [php7:notice] [pid 2113498] [client 192.168.1.29:43641] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0175|[Wed Mar 01 10:02:37.485372 2023] [php7:notice] [pid 1106040] [client 192.168.1.65:48439] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0176|[Wed Mar 01 10:02:38.387759 2023] [php7:notice] [pid 2113498] [client 192.168.1.29:43641] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0177|[Wed Mar 01 10:02:38.585356 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
0178|[Wed Mar 01 10:02:39.619945 2023] [php7:notice] [pid 2113498] [client 192.168.1.29:43641] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=3
0179|[Wed Mar 01 10:02:39.624304 2023] [php7:notice] [pid 2176519] [client 192.168.1.65:48440] PHP Notice:  ob_clean(): failed to delete buffer. No buffer to delete in /var/www/html/plugins/camera/core/php/snapshot.php on line 30, referer: http://192.168.1.77/index.php?v=d&p=plan&plan_id=2&fullscreen=1
etc
Ce message d’erreur est lié à une mauvaise configuration de php dans l’installation jeedom. En effet, le upload_tmp_dir est défini à « /userdata », et cet emplacement n’a des droits d’écriture qu’en tant que root, pas en tant que www-data (qui est utilisé lors des appels http).
Du coup, on a ce message qui indique, lors d’un upload de fichier, que l’upload est redirigé vers le sys_temp_dir si défini (ce qui n’est pas le cas), ou vers le dossier temporaire défini sur l’OS lui-même.
En d’autres termes, à moins d’un fix du php.ini (ex. pour mettre une localisation dans /var/www/html/) ou des permissions par défaut pour www-data sur /userdata, on aura ce genre de message pour tout upload, quelque soit le plugin utilisé (voire le core).
Pas terrible…
En attendant, individuellement, vous pouvez faire l’une des corrections indiquées ci-dessus. A vos risques et péril en terme de sécurité bien sûr.
