La dernière version du plugin permet l’utilisation des certificats/clefs client.
J’utilise un server VPN Unifi (UDM), la connection VPN nécessite une connection TLS avec clef.
Pourriez vous m’aider en expliquant comment configurer la clef TLS dans le plugin ?
Fri Dec 22 09:31:21 2023 WARNING: file '/var/www/html/plugins/openvpn/core/class/../../data/key_U4S3ePiluZGnQmCTSIDYvAT01QJLbQ.key' is group or others accessible
Fri Dec 22 09:31:21 2023 WARNING: file '/tmp/jeedom/openvpn/openvpn_auth_Uxxf' is group or others accessible
Fri Dec 22 09:31:21 2023 OpenVPN 2.4.7 aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Apr 28 2021
Fri Dec 22 09:31:21 2023 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10
Fri Dec 22 09:31:21 2023 TCP/UDP: Preserving recently used remote address: [AF_INET]109.89.134.153:64252
Fri Dec 22 09:31:21 2023 Socket Buffers: R=[212992->212992] S=[212992->212992]
Fri Dec 22 09:31:21 2023 UDP link local: (not bound)
Fri Dec 22 09:31:21 2023 UDP link remote: [AF_INET] XX.XX.XX.XX:64x2
Fri Dec 22 09:32:21 2023 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Dec 22 09:32:21 2023 TLS Error: TLS handshake failed
Fri Dec 22 09:32:21 2023 SIGUSR1[soft,tls-error] received, process restarting
Fri Dec 22 09:32:21 2023 Restart pause, 5 second(s)
Fri Dec 22 09:32:26 2023 TCP/UDP: Preserving recently used remote address: [AF_INET] XX.XX.XX.XX:64x2
Fri Dec 22 09:32:26 2023 Socket Buffers: R=[212992->212992] S=[212992->212992]
Fri Dec 22 09:32:26 2023 UDP link local: (not bound)
Fri Dec 22 09:32:26 2023 UDP link remote: [AF_INET] XX.XX.XX.XX:64x2
