j’ai un soucis d’installation du plugin Odace SFSP
Config Jeedom Atlas, plugin Odace version stable
Log Beagle_update
* Installation des dépendances *
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 http://armbian.16z.eu/apt buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
rfkill is already the newest version (2.33.1-0.1).
0 upgraded, 0 newly installed, 0 to remove and 42 not upgraded.
bluetooth is already the newest version (5.50-1.2~deb10u2).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u2).
build-essential is already the newest version (12.6).
libffi-dev is already the newest version (3.2.1-9).
libssl-dev is already the newest version (1.1.1d-0+deb10u7).
python3-dev is already the newest version (3.7.3-1).
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.26.0)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests) (3.2)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (1.26.7)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.6)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2021.10.8)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.4)
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.22.0)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from pyudev) (1.16.0)
Requirement already satisfied: wheel in /usr/local/lib/python3.7/dist-packages (0.37.0)
Requirement already satisfied: cryptography==2.6.1 in /usr/lib/python3/dist-packages (2.6.1)
Collecting pybluez
Using cached https://files.pythonhosted.org/packages/08/9f/e9d93b266d2d1ea988780a52a696073ba0a65df65a532165fdf6ff90d0ed/PyBluez-0.23.tar.gz
Complete output from command python setup.py egg_info:
error in PyBluez setup command: use_2to3 is invalid.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-l8xfgf8c/pybluez/
* Installation terminée *
Pouvez-vous m’aider svp ?
