jeedom stable 4.3.17
plugin stable à jours
je me permet d’ouvrir ce sujet car je pense que j’ai trouvé d’ou vient mon probléme de remontée d’info des certains de mes écocompteurs.
Pour que les valeurs remontes, je suis obliger le lancer le cron manuellement
on peut voir que j’ai une valeur le 14/04 à 18h30 et aujourdhui à 21h05 quand j’aii lancé le cron.
Exemple de log toutes les minutes
[2023-04-17 20:50:05][DEBUG] : getInformations http://192.168.1.36/data.json
[2023-04-17 20:50:05][DEBUG] : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.49/inst.json
[2023-04-17 20:50:06][DEBUG] : Array ( [data1] => 0 [data2] => 0 [data3] => 13 [data4] => 116 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 50 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1681764605 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.49/data.json
[2023-04-17 20:50:06][DEBUG] : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => PrisesdeCourant [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.46/inst.json
[2023-04-17 20:50:06][DEBUG] : Array ( [data1] => 0 [data2] => 2 [data3] => 5 [data4] => 0 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 50 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1681764605 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.46/data.json
[2023-04-17 20:50:06][DEBUG] : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.45/inst.json
[2023-04-17 20:50:06][DEBUG] : Array ( [data1] => 0 [data2] => 0 [data3] => 1 [data4] => 44 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 44 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1681764297 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.45/data.json
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.36/inst.json
[2023-04-17 20:50:06][DEBUG] : Array ( [data1] => 11 [data2] => 0 [data3] => 130 [data4] => 55 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 46 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1681764400 )
[2023-04-17 20:50:06][DEBUG] : getInformations http://192.168.1.36/data.json
[2023-04-17 20:51:03][DEBUG] : getInformations http://192.168.1.36/inst.json
merci
personne n’a eu le meme probléme?
la derniere collecte date du 17/04.
en relancer le cron, les valeurs remontents.
Bison
Mai 8, 2023, 5:42
3
Il n’y a vraiment que ça dans les logs ou tu en a mis qu’une partie ?
Ça tient combien de temps en fin de compte ?
Essai de :
désactiver l’ensemble des équipements du plugin
supprimer les lignes de logs
relancer le cron
Puis :
Active l’équipement 1 et attend 2mn pour voir 2 interrogation (inst.json)
Recommence en activant l’équipement 2
Etc…
Le but étant de voir s’il n’y en a pas un qui poserait problème et bloquerait le processus.
Compteur 1 :
[2023-05-09 20:25:56]INFO : getConso http://192.168.1.49/LOG2.CSV
[2023-05-09 20:26:02]DEBUG : getInformations http://192.168.1.49/inst.json
[2023-05-09 20:26:02]DEBUG : Array ( [data1] => 0 [data2] => 0 [data3] => 252 [data4] => 167 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 26 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683663962 )
[2023-05-09 20:26:03]DEBUG : getInformations http://192.168.1.49/data.json
[2023-05-09 20:26:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => PrisesdeCourant [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:27:02]DEBUG : getInformations http://192.168.1.49/inst.json
[2023-05-09 20:27:02]DEBUG : Array ( [data1] => 0 [data2] => 2 [data3] => 253 [data4] => 175 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 27 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664022 )
[2023-05-09 20:27:03]DEBUG : getInformations http://192.168.1.49/data.json
[2023-05-09 20:27:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => PrisesdeCourant [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:28:03]DEBUG : getInformations http://192.168.1.49/inst.json
[2023-05-09 20:28:03]DEBUG : Array ( [data1] => 0 [data2] => 0 [data3] => 253 [data4] => 184 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 28 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664083 )
[2023-05-09 20:28:03]DEBUG : getInformations http://192.168.1.49/data.json
[2023-05-09 20:28:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => PrisesdeCourant [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
Compteur 2 :
[2023-05-09 20:29:07]INFO : getConso http://192.168.1.46/LOG2.CSV
[2023-05-09 20:30:06]DEBUG : getInformations http://192.168.1.46/inst.json
[2023-05-09 20:30:06]DEBUG : Array ( [data1] => 0 [data2] => 0 [data3] => 0 [data4] => 0 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 30 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664205 )
[2023-05-09 20:30:06]DEBUG : getInformations http://192.168.1.46/data.json
[2023-05-09 20:30:06]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:31:03]DEBUG : getInformations http://192.168.1.46/inst.json
[2023-05-09 20:31:03]DEBUG : Array ( [data1] => 0 [data2] => 0 [data3] => 0 [data4] => 0 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 31 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664263 )
[2023-05-09 20:31:03]DEBUG : getInformations http://192.168.1.46/data.json
[2023-05-09 20:31:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
Compteur 3 :
[2023-05-09 20:35:03]DEBUG : getInformations http://192.168.1.45/inst.json
[2023-05-09 20:35:03]DEBUG : Array ( [data1] => 0 [data2] => 3 [data3] => 2 [data4] => 45 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 28 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664130 )
[2023-05-09 20:35:04]DEBUG : getInformations http://192.168.1.45/data.json
[2023-05-09 20:35:04]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:36:03]DEBUG : getInformations http://192.168.1.45/inst.json
[2023-05-09 20:36:03]DEBUG : Array ( [data1] => 0 [data2] => 2 [data3] => 0 [data4] => 45 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 29 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664190 )
[2023-05-09 20:36:03]DEBUG : getInformations http://192.168.1.45/data.json
[2023-05-09 20:36:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:37:03]DEBUG : getInformations http://192.168.1.45/inst.json
[2023-05-09 20:37:03]DEBUG : Array ( [data1] => 0 [data2] => 0 [data3] => 0 [data4] => 44 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 30 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664249 )
[2023-05-09 20:37:03]DEBUG : getInformations http://192.168.1.45/data.json
[2023-05-09 20:37:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
Compteur 4 :
[2023-05-09 20:38:21]INFO : getConso http://192.168.1.36/LOG2.CSV
[2023-05-09 20:39:02]DEBUG : getInformations http://192.168.1.36/inst.json
[2023-05-09 20:39:02]DEBUG : Array ( [data1] => 18 [data2] => 0 [data3] => 14 [data4] => 54 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 34 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664490 )
[2023-05-09 20:39:03]DEBUG : getInformations http://192.168.1.36/data.json
[2023-05-09 20:39:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:40:05]DEBUG : getInformations http://192.168.1.36/inst.json
[2023-05-09 20:40:05]DEBUG : Array ( [data1] => 19 [data2] => 0 [data3] => 14 [data4] => 54 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 35 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664553 )
[2023-05-09 20:40:06]DEBUG : getInformations http://192.168.1.36/data.json
[2023-05-09 20:40:06]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
[2023-05-09 20:41:03]DEBUG : getInformations http://192.168.1.36/inst.json
[2023-05-09 20:41:03]DEBUG : Array ( [data1] => 16 [data2] => 1 [data3] => 14 [data4] => 54 [data5] => 0 [data6] => 0 [data6m3] => 0 [data7] => 0 [data7m3] => 0 [heure] => 20 [minute] => 36 [CIR1_Nrj] => 0 [CIR1_Vol] => 0 [CIR2_Nrj] => 0 [CIR2_Vol] => 0 [CIR3_Nrj] => 0 [CIR3_Vol] => 0 [CIR4_Nrj] => 0 [CIR4_Vol] => 0 [Date_Time] => 1683664610 )
[2023-05-09 20:41:03]DEBUG : getInformations http://192.168.1.36/data.json
[2023-05-09 20:41:03]DEBUG : Array ( [option_tarifaire] => 4 [tarif_courant] => 11 [isousc] => 0 [conso_base] => 0 [conso_hc] => 0 [conso_hp] => 0 [conso_hc_b] => 0 [conso_hp_b] => 0 [conso_hc_w] => 0 [conso_hp_w] => 0 [conso_hc_r] => 0 [conso_hp_r] => 0 [type_imp_0] => 0 [type_imp_1] => 1 [type_imp_2] => 1 [type_imp_3] => 1 [type_imp_4] => 1 [type_imp_5] => 1 [label_entree1] => Chauffage [label_entree2] => Refroidissement [label_entree3] => Eauchaude [label_entree4] => PrisesdeCourant [label_entree5] => PrisesdeCourant [label_entree_imp0] => Gaz [label_entree_imp1] => Eau [label_entree_imp2] => Eau [label_entree_imp3] => Eau [label_entree_imp4] => Eau [label_entree_imp5] => Eau [entree_imp0_disabled] => 0 [entree_imp1_disabled] => 0 [entree_imp2_disabled] => 1 [entree_imp3_disabled] => 1 [entree_imp4_disabled] => 1 [entree_imp5_disabled] => 1 )
j’ai l’impression que c’est cette foutu memoire du ecocompteur qui me fait chier sauf que j’ai mis un scenario tout les mois pour les reseter mais tant que je relance pas le cron il prend pas en compte la modif.
comment je pourrais rajouter le lancement du cron au code deja aprés le reset :
// Mise à jour de la formule de calcul de la commande [csv - energie_circuit1]
$index1 = cmd::byString('#[COMPTAGE][Compteur 4][Total Chauffage T-one]#')->execCmd();
$scenario->setLog('Valeur [Total Chauffage T-one] avant reset : '.$index1);
cmd::byString('#[COMPTAGE][Compteur 4][Total Chauffage T-one]#')->setConfiguration('calculValueOffset', "#value#+$index1")->save();
// Mise à jour de la formule de calcul de la commande [csv - energie_circuit2]
$index2 = cmd::byString('#[COMPTAGE][Compteur 4][Total Seche Serviette]#')->execCmd();
$scenario->setLog('Valeur [Total Seche Serviette] avant reset : '.$index2);
cmd::byString('#[COMPTAGE][Compteur 4][Total Seche Serviette]#')->setConfiguration('calculValueOffset', "#value#+$index2")->save();
// Mise à jour de la formule de calcul de la commande [csv - energie_circuit3]
$index3 = cmd::byString('#[COMPTAGE][Compteur 4][Total Chauffe Eau]#')->execCmd();
$scenario->setLog('Valeur [Total Chauffe Eau] avant reset : '.$index3);
cmd::byString('#[COMPTAGE][Compteur 4][Total Chauffe Eau]#')->setConfiguration('calculValueOffset', "#value#+$index3")->save();
// Mise à jour de la formule de calcul de la commande [csv - energie_circuit4]
$index4 = cmd::byString('#[COMPTAGE][Compteur 4][Totale Garage]#')->execCmd();
$scenario->setLog('Valeur [Totale Garage] avant reset : '.$index4);
cmd::byString('#[COMPTAGE][Compteur 4][Totale Garage]#')->setConfiguration('calculValueOffset', "#value#+$index4")->save();
// Mise à jour de la formule de calcul de la commande [csv - energie_circuit5]
$index5 = cmd::byString('#[COMPTAGE][Compteur 4][csv - energie_circuit5]#')->execCmd();
$scenario->setLog('Valeur [csv - energie_circuit5] avant reset : '.$index5);
cmd::byString('#[COMPTAGE][Compteur 4][csv - energie_circuit5]#')->setConfiguration('calculValueOffset', "#value#+$index5")->save();
// Requêtes pour réinitialiser les compteurs "csv - energie_circuit" 1 à 5 de l'ecocompteur
$req1 = 'curl "http://192.168.1.36/wp.cgi?wp=536+2+12724+-1+-1+4+0.0"';
$req2 = 'curl "http://192.168.1.36/wp.cgi?wp=536+4+12724+-1+-1+4+0.0"';
$req3 = 'curl "http://192.168.1.36/wp.cgi?wp=536+6+12724+-1+-1+4+0.0"';
$req4 = 'curl "http://192.168.1.36/wp.cgi?wp=536+8+12724+-1+-1+4+0.0"';
$req5 = 'curl "http://192.168.1.36/wp.cgi?wp=536+10+12724+-1+-1+4+0.0"';
$scenario->setLog('DEBUG REQUETE : '.$req1);
$output1 = shell_exec($req1);
$scenario->setLog('DEBUG RETOUR : '.$output1);
$scenario->setLog('DEBUG REQUETE : '.$req2);
$output2 = shell_exec($req2);
$scenario->setLog('DEBUG RETOUR : '.$output2);
$scenario->setLog('DEBUG REQUETE : '.$req3);
$output3 = shell_exec($req3);
$scenario->setLog('DEBUG RETOUR : '.$output3);
$scenario->setLog('DEBUG REQUETE : '.$req4);
$output4 = shell_exec($req4);
$scenario->setLog('DEBUG RETOUR : '.$output4);
$scenario->setLog('DEBUG REQUETE : '.$req5);
$output5 = shell_exec($req5);
$scenario->setLog('DEBUG RETOUR : '.$output5);
