Bonjour, suite à un plantage de ma Smart box j’ai du la restaurer, depuis j’ai des problèmes avec mes Nut3. Au bout de qq heures ils ne sont plus détectés et reste bloqués à leur dernier valeur.
J’utilise la clef usb SENA UD100. Une idée ? Merci
Requirement already satisfied: cryptography in /usr/local/lib/python3.7/dist-packages (42.0.2)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: pycrypto in /usr/local/lib/python3.7/dist-packages (2.6.1)
* Installation terminée
[because last connection or last learn was too soon
[2024-02-15 18:29:20.782]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:20.782]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:21.784]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:21.784]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:21.784]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:21.785]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:22.786]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:22.787]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:22.787]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:22.787]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:23.788]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:23.789]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:23.789]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:23.790]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:24.791]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:24.792]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:24.792]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:24.793]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:25.794]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:25.795]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:25.795]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:25.795]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:26.797]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:26.797]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:26.798]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:26.798]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:27.799]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:27.800]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:27.800]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:27.801]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:28.802]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:28.803]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:28.803]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:28.803]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:29.805]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:29.805]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:29.806]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:29.806]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:30.808]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:30.808]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:30.808]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:30.809]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:31.810]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:31.811]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:31.811]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:31.811]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:32.812]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:32.813]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:32.813]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:32.813]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:33.815]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:33.815]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:33.816]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:33.816]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:34.818]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97
[2024-02-15 18:29:34.819]INFO : Not SEEEEEEEEEN------ since 80s 69:D1:22:D9:21:97 but not sendig because last connection or last learn was too soon
[2024-02-15 18:29:34.819]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8
[2024-02-15 18:29:34.819]INFO : Not SEEEEEEEEEN------ since 80s 61:E4:48:A2:E7:E8 but not sendig
