Bonjour à tous
j’ai commandé un module TS0207 capteur inondation, ca semble être une variante du module déjà dispo
il fonctionne comme le TS0207 déjà présent, pour la commande action c’est bon
c’est pour les infos que ca remonte mal, surtout BATTERIE
Nouveau modèle :
Infos brutes :
"ieee": "a4:c1:38:a2:24:16:91:bc",
"nwk": 1311,
"status": 2,
"lqi": "255",
"rssi": "-58",
"last_seen": "1652858254.859102",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TZ3000_upgcbody",
"model": "TS0207",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 16,
"name": "cie_addr",
"value": [
160,
153,
6,
255,
255,
46,
33,
0
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_upgcbody"
"id": 5,
"name": "model",
"value": "TS0207"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"signature": {
"model": "TS0207",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
1,
3,
1280,
0
25,
10
"class": "zigpy.device"
Json :
"name": "TZ3000_qdmnmddg.TS0207",
"configuration": [],
"commands": [
"logicalId": "1::1280::cmd::1",
"generic_type": "FLOOD",
"name": "Innondation",
"type": "info",
"subType": "binary",
"isHistorized": "0",
"configuration": {
"repeatEventManagement": "always"
"template": {
"dashboard": "core::flood",
"mobile": "core::flood"
"display": {
"invertBinary": "1"
"isVisible": "1"
"ref": "TZ3000_qdmnmddg.TS0207"
logs :
0000|[2022-05-18 09:50:33]DEBUG : {"devices":{"a4:c1:38:a2:24:16:91:bc":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.0","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
0001|[2022-05-18 09:50:33]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1 => ZoneStatus.0 convert to 0
0002|[2022-05-18 09:50:33]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
0003|[2022-05-18 09:50:33]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.2 => 0 convert to 0
0004|[2022-05-18 09:50:33]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.3 => 0 convert to 0
0005|[2022-05-18 09:50:33]DEBUG : {"devices":{"a4:c1:38:a2:24:16:91:bc":{"1":{"1":{"33":{"value":"142","cluster_name":"Power Configuration"}}}}}}
0006|[2022-05-18 09:50:33]DEBUG : Search attribut for a4:c1:38:a2:24:16:91:bc logicalId : 1::1::33 => 142 convert to 142
0007|[2022-05-18 09:50:40]DEBUG : {"devices":{"a4:c1:38:a2:24:16:91:bc":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
0008|[2022-05-18 09:50:40]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1 convert to 1
0009|[2022-05-18 09:50:40]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
0010|[2022-05-18 09:50:40]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.2 => 0 convert to 0
0011|[2022-05-18 09:50:40]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.3 => 0 convert to 0
0012|[2022-05-18 09:50:42]DEBUG : {"devices":{"a4:c1:38:a2:24:16:91:bc":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.0","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
0013|[2022-05-18 09:50:42]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1 => ZoneStatus.0 convert to 0
0014|[2022-05-18 09:50:42]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
0015|[2022-05-18 09:50:42]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.2 => 0 convert to 0
0016|[2022-05-18 09:50:42]DEBUG : Search command for a4:c1:38:a2:24:16:91:bc logicalId : 1::1280::cmd::1.3 => 0 convert to 0
merci pour l’ajout
essaye les 2 versions
