Nouveau module zigbee
Bonjour à tous
est-il possible d’ajouter ce module :
Capteur d’eau TUYA :
    "ieee": "cc:86:ec:ff:fe:bc:10:aa",
    "nwk": 38887,
    "status": 2,
    "lqi": "199",
    "rssi": "-69",
    "last_seen": "1620040868.3777566",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "_TZ3000_qdmnmddg",
            "model": "TS0207",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_qdmnmddg"
                            "id": 5,
                            "name": "model",
                            "value": "TS0207"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                160,
                                153,
                                6,
                                255,
                                255,
                                46,
                                33,
                                0
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 30
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 200
    "signature": {
        "model": "TS0207",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    10,
                    1280,
                    1
                    25
    "class": "zigpy.device"
merci
ou me dire comment créer la commande pour récupérer le status : 1 = pas d’eau, 2 = eau
Pour ce module il faudrait le mettre dans l’eau puis le sortir et m’envoyer le log zigbee (tout cours)
Bonjour @Loic
Voici le log
[2021-05-03 18:58:55][DEBUG] : {"devices":{"cc:86:ec:ff:fe:bc:10:aa":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"255","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-05-03 18:58:55][DEBUG] : Search command for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1
[2021-05-03 18:58:55][DEBUG] : Search command for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::1280::cmd::1.1 => bitmap8.0
[2021-05-03 18:58:55][DEBUG] : Search command for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::1280::cmd::1.2 => 255
[2021-05-03 18:58:55][DEBUG] : Search command for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::1280::cmd::1.3 => 0
[2021-05-03 18:58:57][DEBUG] : {"devices":{"cc:86:ec:ff:fe:bc:10:aa":{"1":[{"1":{"value":"65","cluster_name":"Basic"},"65506":{"value":"28","cluster_name":"Basic"}}]}}}
[2021-05-03 18:58:57][DEBUG] : Search attribut for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::0::1 => 65
[2021-05-03 18:58:57][DEBUG] : Search attribut for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::0::65506 => 28
[2021-05-03 18:58:57][DEBUG] : {"devices":{"cc:86:ec:ff:fe:bc:10:aa":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"},"32":{"value":"30","cluster_name":"Power Configuration"}},"0":{"65503":{"value":"","cluster_name":"Basic"}}}}}}
[2021-05-03 18:58:57][DEBUG] : Search attribut for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::0::65503 =>
[2021-05-03 18:58:58][DEBUG] : {"devices":{"cc:86:ec:ff:fe:bc:10:aa":{"1":[{"65503":{"value":"","cluster_name":"Basic"}}]}}}
[2021-05-03 18:58:58][DEBUG] : Search attribut for cc:86:ec:ff:fe:bc:10:aa logicalId : 1::0::65503 =>
Ca sera dans la beta de demain
merci @Loic
je pourrais pas tester, je suis en stable
