Not correct link
The Jeedom Connect application does not correctly save the link address.
https://xxxx1.eu.jeedom.link.
When the client wants to connect, he can’t because the address has changed to https://xxxx.eu.jeedom.link.
We have uninstalled the app but it continues the same.
What I can do?
Jeedom Core : 4.3.12
Version JC : 1.6.0+ stable
DNS Jeedom : oui
Statut Démon : Stoppé - ()
Equipements :
  Ready Systems : v1.6.0 stable sur android [os : 31] (polling)
  Ricardo Leal : v1.6.0 stable sur android [os : 31] (polling)
All your posts start the same way …
There’s still no « hello » word in your city/country …?
hello tomitimas
I’m Rafa and I’m dedicated to systems integration. I chose Jeedom as server for my wireless home automation and Knx works.
I’m from Barcelona and my favorite sport is EUC Enduro #atomicwheel
Sorry to be short on words.
Thanks
bad luck … :sweat_smile:
I was just saying that it doesnt cost a lot to start a new topic with a first « hello » (like any civilized people), instead of « I have a probleme. what to do. » which seems a bit rude.
if you want to, you can make a full presentation of yourself and your solution in the right place :
Sujets Récents sur Présentation et Vitrine d’installations - Communauté Jeedom
no matter what you’re set manually in the application itself to initiate the connection. The application will get back the setup define on the plugin settings page :
so the real url has to be correctly set up here, which might not be the case on your side
perfect tomitimas.
Everything working.
Thank you
still not the good one …! :confused:
don’t forget to set as solution the previous message.
thanks
