J’ai mis à jour mes deux ESP32 (v1.70) et j’ai alors rencontré le problème évoqué ici
J’ai supprimé l’un de mes deux ESP32 (« Salon ») et relancé le démon : l’équipement est bien recréé mais avec un nombre de commandes infos réduit, et sans aucune commande action
Pas de commande des topic « bt/Salon/RLStoMQTT » ni de « bt/Salon/BTtoMQTT » (que je visualise bien avec MQTT Explorer)
(N’ayant pas encore supprimé mon autre ESP32 il m’est facile de comparer)
Le fichier configuration :
{"binary_sensor":{"E05AXXXXXXXX-connectivity":{"stat_t":"bt/Salon/LWT","avty_t":"bt/Salon/LWT","name":"SYS: Connectivity","uniq_id":"E05AXXXXXXXX-connectivity","pl_on":"online","pl_off":"offline","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}}},"sensor":{"E05AXXXXXXXX-uptime":{"stat_t":"bt/Salon/SYStoMQTT","avty_t":"bt/Salon/LWT","dev_cla":"duration","unit_of_meas":"s","name":"SYS: Uptime","uniq_id":"E05AXXXXXXXX-uptime","val_tpl":" value_json.uptime ","pl_avail":"online","pl_not_avail":"offline","state_class":"measurement","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}},"E05AXXXXXXXX-freemem":{"stat_t":"bt/Salon/SYStoMQTT","avty_t":"bt/Salon/LWT","dev_cla":"data_size","unit_of_meas":"B","name":"SYS: Free memory","uniq_id":"E05AXXXXXXXX-freemem","val_tpl":" value_json.freemem ","pl_avail":"online","pl_not_avail":"offline","state_class":"measurement","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}},"E05AXXXXXXXX-ip":{"stat_t":"bt/Salon/SYStoMQTT","avty_t":"bt/Salon/LWT","name":"SYS: IP","uniq_id":"E05AXXXXXXXX-ip","val_tpl":" value_json.ip ","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}},"E05AXXXXXXXX-rssi":{"stat_t":"bt/Salon/SYStoMQTT","avty_t":"bt/Salon/LWT","dev_cla":"signal_strength","unit_of_meas":"dB","name":"SYS: RSSI","uniq_id":"E05AXXXXXXXX-rssi","val_tpl":" value_json.rssi ","pl_avail":"online","pl_not_avail":"offline","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}},"E05AXXXXXXXX-tempc":{"stat_t":"bt/Salon/SYStoMQTT","avty_t":"bt/Salon/LWT","dev_cla":"temperature","unit_of_meas":"°C","name":"SYS: Internal temperature","uniq_id":"E05AXXXXXXXX-tempc","val_tpl":" value_json.tempc | round(1)","pl_avail":"online","pl_not_avail":"offline","state_class":"measurement","device":{"ids":["E05AXXXXXXXX"],"name":"Salon","mdl":"[\"WebUI\",\"BT\"]","mf":"OMG_community","cu":"http://192.168.1.108/","sw":"v1.7.0"}}}}
Merci par avance !
